Old 09-17-2017, 08:28 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Original brake pads lasting forever
I am up to 115k miles on my 2013 BRZ (bought new in 2013 with 5 miles). I drive 100 miles per day for work 5 days a week, hitting heavy stop and go traffic each way. In addition to that, I drive a decent amount for personal use. Probably ~26k/year
Last week I started hearing a squeak when I applied the brakes and thought I was finally due for new pads so I go out to my local dealership yesterday to pick up pads. I flipped up my caliper today to find my current pads have almost half of pad meat left; both sides have identical wear. Has anyone else had pads this long? On my prior cars (Integra GSR, S2000) I've replaced pads twice within similar mileage.
B-R-Z is offline   Reply With Quote
Old 09-17-2017, 08:30 PM   #2
n0thing
Drives: Subaru BRZ
By 20k km (12.4k miles), I had my brakes changed twice.
n0thing is offline   Reply With Quote
Old 09-17-2017, 08:43 PM   #3
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
At 36k after dozens of autocrosses and canyon runs my pads still had 75+% left
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 09-17-2017, 10:15 PM   #4
Turdinator
Seρor Member
Turdinator's Avatar
I have replaced a motor before I have replaced discs or pads....
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
zc06_kisstherain (09-27-2017)
Old 09-18-2017, 02:18 AM   #5
JamesK
Drives: 2013 - Toyota 86
I have gone 65000km on my 86 just recently got my car serviced and was told I have 50% left on my front pads 70-75% rear
JamesK is offline   Reply With Quote
Old 09-18-2017, 08:27 PM   #6
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
2.5 years, nearly 20k miles with majority of it being city driving - 80% pad life left...
If you think about it these stock pads are pretty damn economical. Nothing to brag about, but hey they certainly give you a crap ton of service before kaput.
KalbiCool88 is offline   Reply With Quote
The Following 2 Users Say Thank You to KalbiCool88 For This Useful Post:
dowroa (10-01-2017), strat61caster (09-18-2017)
Old 09-18-2017, 10:09 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
It's not stock pads that last long. It's not driving on track that makes pads last long hence putting 5-20 times less wear on them, depending how often. Most going to track had upgraded to non-stock pads after all, be it right away, or after quick wearing down of stockers.
alex.s (09-19-2017), strat61caster (09-18-2017)
Old 09-19-2017, 12:09 AM   #8
renfield90
The Stig's German cousin
Brakes make you go slow. Good on you for not using them.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
lantsalot (09-29-2017), Myriad (04-04-2019)
Old 09-19-2017, 02:15 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
But i guess it might be applicable only for past, when brakes were so bad that couldn't be much relied upon anyway. Unless it's straight like eg. dragstrip, one cannot lap faster without using brakes. There are other ways to bleed speed too, eg. sliding sideways, but they'll make one's lap speed worse aswell vs proper driving. And even in rally driving on gravel or ice sliding everywhere stages, brakes are used for mass transfer / turning a lot, not just for primary function. If one drives fast enough, one needs to slow down enough .. and at right point, right amount and in right fashion.
Old 09-25-2017, 12:40 PM   #10
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
I have a 2013 FR-S with 131k miles on it. 150 miles a day, daily driver.
And yeah, at 125k I bought new pads, pulled the driver's side caliper off and there was so much pad left I just bolted 'em back on.
I do a lot of hypermiling though and use gears to drop my speed in a lot of the twisties. And on i-65 I don't need to brake much.
BTW, I haven't replaced the plugs yet, either.
LotsaMiles is offline   Reply With Quote
Old 09-25-2017, 12:44 PM   #11
LotsaMiles
I'm not a fan of the brakes on this car, though.
At about 80k I was coming off the freeway, dropping from 80 to about 50 and they started rumbling pretty bad. I thought they were worn out, but they were not. It must just be the modern material in the brakes because I notice my wife's car does it too. It's not the pulsating of a warped rotor. It's a weird rumbling. I hate it.
I thought about getting slotted discs when I DO replace the pads, but even that doesn't look like it will do the trick. (drilled are obsolete according to every single "knowledgeable" brake rundown I read).
Old 09-25-2017, 05:15 PM   #12
wparsons
wparsons's Avatar
I wouldn't get slotted pads, they just wear pads out faster. I'd check the rotors for deposits of pad material, that could make them feel a bit funny.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Racecomp Engineering (10-02-2017), strat61caster (09-25-2017)
Old 09-30-2017, 05:20 PM   #13
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
I'm at 36.7k @ 3.5 years, with about 210 miles a week for work.
I'm almost over 75% use of pads. I think due to all the stopping I do (imagine going only 10 miles an hour across 20 miles).
So I'm researching new pads now since I'd probably use the rest by Valentines day.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 09-30-2017, 05:50 PM   #14
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
My wife's Camry did the same thing. The pads were fine and disc runout didn't seem to be the problem. I bet on the hunch it was a bedding issue. Took the car out to a back road and did threshold level 65-15 mph stops until the brakes faded just a bit. Problem solved.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Racecomp Engineering (10-02-2017), strat61caster (09-30-2017)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
swapping brake fluid: taking FOREVER to bleed the air!! snuff58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 11-02-2015 04:09 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
