Old 09-14-2017, 03:04 PM   #1
djghez
Drives: Subaru BRZ WRB
Cracking Header
Hello All,
This is my first time posting but I've tried going through all the trends for help but have not found what I'm looking for.
I have a supercharged BRZ and keep getting cracks in my header. First header was a Borla UEL which cracked once, I welded it and then cracked in another spot. I then cracked the stock header and then an Invidia header.
I'm trying to find a better header that has a thicker gage wall, 304 or better stainless steel, TIG welded and back purged but its hard to find info on these headers without just buying and seeing the parts.
Does anyone have recommendations on better headers or a way to prevent cracking? Side Note - I have added panels to protect my header from water but there is just as much airflow so the header can cool properly. I also have not used exhaust wrap.
Any help would be greatly appreciated especially that I'm spending way too much on headers.
djghez is offline   Reply With Quote
Old 09-14-2017, 03:16 PM   #2
celek
Resident Gear Head
celek's Avatar
This is what people get with inexpensive parts.
I am not mocking you BTW just stating a fact.
Yes they are sub $700 headers but you have already had to buy 2 instead of 1 at the same cost
I would recommend Tomei, JDL, ACE, Nameless they are a quality part
celek is offline   Reply With Quote
Old 09-14-2017, 03:27 PM   #3
CSG Mike
CSG Mike's Avatar
How are your EGTs?
Old 09-14-2017, 03:39 PM   #4
djghez
celek - Ill definately take a look at the brands you suggested.
CSG Mike - I have not tried measuring the temps.
Old 09-14-2017, 05:21 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Out of curiosity what are the engine mods?
Is it just a lot of track time because cracking three headers including OE is insane, even if you can blame the quality of the aftermarket headers, cracking the OE ones is rare but not unheard of if tracked and with FI.
ineedyourdiddly
Old 09-14-2017, 06:53 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Spend better money on a tune, then work on fixing any header problems.
Old 09-14-2017, 07:19 PM   #7
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
JDL are known for having thicker metal which incidentally makes it a tad quieter. Also what kind of supercharger are you using? I was Edelbrock supercharged and never had an issue for 6 months (before i took off the SC). my friend is JRSC boosted and he cracked his OEM header, but that was after a full year of track days
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 09-15-2017, 06:40 PM   #8
djghez
Hello All,
Sorry I have been busy today and haven't been very responsive.
Engine Mods have just been adding a Edelbrock E Force supercharger with the standard pulley.
The tune was custom and done by P Tuning without flashing and was not cheap. I saw all the setting and charts and no issues there.
I decided to buy a Tomei and a JDL to see which has better welds and material thickness.
Thank you all for the help. Let me know if you have other suggestions to prevent cracking.
Old 09-15-2017, 06:50 PM   #9
Teseo
Drives: frs
When you say was not cheap sounds you was ripped of
Old 09-15-2017, 06:55 PM   #10
djghez
I have all the data from the tune so what should I see wrong that would cause header cracking? I'm asking so that if they screwed up I can go back and have it fixed.
Old 09-15-2017, 07:12 PM   #11
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Would LOVE to hear how you "tuned" the car without flashing.
Old 09-15-2017, 08:21 PM   #12
djghez
Sorry should have said we didnt just flash a premade tune.
The Following User Says Thank You to djghez For This Useful Post:
x808drifter (09-16-2017)
Old 09-15-2017, 08:28 PM   #13
Xxyion
Lowly Cartuber
Xxyion's Avatar
Surprised you have a heating issue with the Edelbrock. that kit is known for its incredible heat managment. Methinks the tune might be the issue. While you might have been tuned for best performance...that . might have come at a cost
Old 09-15-2017, 08:42 PM   #14
djghez
What's the best way to adjust the tune for lower exhaust temp? Running rich, lower compression?
borla, crack, exhaust, header, invidia
The cracking shounds Tofu-86 Engine, Exhaust, Transmission 19 10-11-2016 08:25 PM
Paint Stain/Cracking? nimble Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 11-26-2015 01:13 AM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 09:59 PM
Paint Cracking? Heero Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 01-29-2014 01:53 PM
exhaust cracking and leaking driver01 Engine, Exhaust, Transmission 80 09-17-2013 04:25 AM
