Old 09-13-2017, 09:54 AM   #1
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Side Marker Fix?
I know this has been going on since the start of time, but after all these years has anyone come up with a trick to get the side markers to stay in place?
I've been using 3M double-sided tape for a while but am tired of having to fix the tape every week or so (long bumpy commute)...
*I was originally missing the "A " clip on one side marker so I ordered another pair but after adding the clip the light was still loose. Somewhere in the process of jigging things around a "B" or "C" clip fell off and I got so frustrated I ended up reinstalling with whatever clips I still had and tape (best part was I found the "missing" clip after reinstall)
**Going to try gorilla double sided tape when I get the chance but doubt it'll make too much of a difference.
***I also tried something similar to this:
http://www.ft86club.com/forums/showthread.php?t=69388
Drilled a hole in the side marker and slid a toothpick into it, the toothpick is still there - but the top of the side marker keeps popping out.
02.ACCORD.DUDE is offline   Reply With Quote
Old 09-13-2017, 10:07 AM   #2
KDad2
KDad2's Avatar
Drives: 2013 Raven
Gorilla tape does work, even when wet. Used it for about a month until I found a set of used markers for $10. But, I like that thread you referenced.
KDad2 is offline   Reply With Quote
Old 09-13-2017, 10:59 AM   #3
02.ACCORD.DUDE
Car N00B
Yeah it's great, and I think for some people it will work. With the holes + toothpick I have no worries of the light fully popping out...
It's just like most I want the markers flush as possible :P
Old 09-13-2017, 05:21 PM   #4
NRXRaptor
I drilled a hole through my side marker and used that to zip tie it to the hole in the fender you stick the screwdriver through to pry the A clip loose. I've never been able to pry it loose properly and end up just ripping it off. No video shows/can show how to do it properly. When I order off of 86speed I'll add some A clips and see if that does anything
NRXRaptor is offline   Reply With Quote
Old 09-13-2017, 10:56 PM   #5
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
JDM ZIP TIES! what the previous post said. works like a charm
IG: @OMGFRS
Old 09-14-2017, 12:23 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Take a note though, that JDM zip ties bring just half the power gains that real JDM stickers of +5whp each.
Old 09-14-2017, 10:49 PM   #7
NRXRaptor
I'm using USDM zip ties though. +4 WHP per
Old 09-15-2017, 09:42 PM   #8
Nonstopper0
Nonstopper0's Avatar
Drives: 2013 Grey Varis Widebody FR-S
Go widebody, you just cut it out
Nonstopper0 is offline   Reply With Quote
Old 09-19-2017, 06:32 PM   #9
02.ACCORD.DUDE
Car N00B
Can you take a picture and share?
I just want to see where the hole was drilled and see if I can replicate :- P
Old 09-22-2017, 01:59 AM   #10
FirstWinter
Drives: Car
I just use 3M double sided tape. I just replace it if it starts to come loose or I have to do work with the bumper off. Been thinking about drilling a hole and using safety wire or cutting up some command strips so I just velcro it.
FirstWinter is offline   Reply With Quote
Old 09-22-2017, 02:05 AM   #11
e1_griego
e1_griego's Avatar
Drives: Many
I drilled a hole where the a-clip goes, popped the marker in, and then snake a small ziptie in and catch the bracket. It's a slight bit of finesse (have to move the fender liner out of the way) but I'm tired of replacing A-clips and this seems to work perfectly.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
02.ACCORD.DUDE (09-30-2017)
Old 09-30-2017, 10:10 AM   #12
02.ACCORD.DUDE
Car N00B
So the gorilla tape kind of melts and turns real gooey when the temperature gets too hot... So I went back to 3M an low and behold the marker had stayed in place despite a ridiculous amount of jolts and jumps (pot holes / crappy north NJ speed bumps, etc.)... I think the trick this time was that I 1) more thoroughly cleaned the area and 2) cut the tape using a straight razor so it exactly fit the side marker...
I have to get around to doing the other side marker like this now...
Command strips (not sure if I'll go with the velcro or sticky type) were going to be my next option. Once this tape stops holding I'll give them a try.
Old 09-30-2017, 03:42 PM   #13
FirstWinter
Drives: Car
Yeah I usually prep the area with isopropyl alcohol and use a utility knife to cut it to shape. I try to have at least 2 areas with 3m double sided tape cut to fit and that usually does the trick. You want flat spots on the sidemarker and the part of the car where it is gonna be taped onto. It's not exactly flush due to the thickness of the tape but at least it stays on.
Old 10-02-2017, 01:15 AM   #14
BuffDriver
Drives: 2016 Subaru BRZ
What great timing... was looking for a fix on this.
Ran over a cone at the track today in oversteer and it went through the right wheel well and popped the marker light out. Used painters tape to hold it in and continued racing so now I know how to fix.
Thanks guys!
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
WTB: passenger side amber side marker NJ-JDM Want-To-Buy Requests 4 05-18-2016 05:37 PM
Side Marker came out HKSpadez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 10-31-2015 11:16 AM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 08:56 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 04:46 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 04:29 AM
