Old 08-30-2017, 12:31 PM   #1
reynierpm
Drives: Toyota 86 2017 Black
Any guide for install this Badge in a new 86 2017?
I would like to add this to my car https://www.86speed.com/products/gt86-badge-toyota.html but I don't have a clue in how to do it since it appears to be for those with a badge on such area, any?
reynierpm is offline   Reply With Quote
Old 08-30-2017, 01:23 PM   #2
StraightOuttaCanadaEh
Wes
You peel the adhesive backing and stick it on. That's it.
Old 08-30-2017, 01:36 PM   #3
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
http://www.ft86club.com/forums/showt...=diy+rebadging
is your friend.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-30-2017, 01:56 PM   #4
LancePower
Drives: 2020 BRZ tS
I always thought you had to lick it before you stick it.
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
pcporo (08-31-2017)
Old 08-30-2017, 02:08 PM   #5
Wes
That would work if you want a GT86 badge stuck to your tongue lol
Old 08-30-2017, 02:59 PM   #6
Azurewrath
I actually used the install guide that's on the website you linked.
http://ft86tech.com/g886-badge-install/
It was pretty straight forward except the American 86 don't have the Toyota badge on the left so I measured the entire trunk and guestimated where the badge would be equal between left and right side.
Azurewrath is offline   Reply With Quote
Old 08-30-2017, 03:05 PM   #7
Make sure you get it right the first shot. There is often no going back once that adhesive hits the surface.
Spyder Headlight install wiring guide. sk900 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-05-2018 10:54 PM
Need a Frs Side Skirt install guide... Captain.K Southern California 2 03-31-2015 01:14 PM
Install guide for Cusco Dif Brace? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-01-2014 06:11 PM
Is there a guide to install oem armrest? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-12-2014 12:06 AM
Seat belt guide install BRZranger BRZ First-Gen (2012+) — General Topics 28 06-09-2012 10:51 PM
