Old 08-24-2017, 10:50 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by churchx View Post
Hmm, but in such case these longer springs + longer bumpstops seem will be like stock springs + topmount lift spacers in what user gets as ground clearance and how suspension will behave, or i am wrong? :/
You gotta look at it from Chuhatsu's perspective.
They made these from an OEM point of view. The question you should ask is: are top mount lift spacers approved for road use? If not, lift springs are the best alternative if you want to have zero issues with a vehicle on public roads.
This is mostly an issue in area(s) where key items on the car requires regulatory approval. It's why KW sells most of their road coilovers without top hats, as it won't meet TUV standards with pillowball or solid upper mounts.
Old 08-24-2017, 10:58 PM   #16
Somerandom18
Drives: 2017 manual BRZ
Rally is life.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 08-25-2017, 12:50 PM   #17
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Hey @mav1178
I'd love to be the test guy for these, if at all possible!
I run ST's in winter, and stock suspension with a 10mm lift shim in winter. I live in New England where we get oodles of snow, and run a Forester size winter so I can prove out just how much clearance difference there is.
I also do my own DIY string alignments with access to a rack, and installs so there shouldn't be any issue with confirming a proper setup.
(And have access to the @LiftedBRZ for back to back comparisons :P )
JazzleSAURUS is offline   Reply With Quote
Old 08-25-2017, 02:25 PM   #18
Yoniyama
Drives: BRZ 2018
Finally, taller springs! I have been looking for them forever.
Hope to see the spring rates for the different sets. The spring rate of the set offered by TRD is too stiff, I am hoping for spring rates closer to the OEM rates.
Please let us know when you hear from Chuhatsu about the spring rates.
Thanks for the tip.
Yoniyama is offline   Reply With Quote
The Following User Says Thank You to Yoniyama For This Useful Post:
why? (09-07-2017)
Old 08-30-2017, 02:49 PM   #19
Racecomp Engineering
The taller bumpstops might also just be a different and softer spring rate, so that instead of hitting a shorter, sharper ramp up in spring rate farther down in the travel with OEM bumpers, you have a more progressive change earlier on. But, I don't know.
These would be fun with some custom valved Bilstein B6.
- Andrew
Old 09-06-2017, 05:46 PM   #20
Student Driver
Drives: 2013 Scion FRS Series 10
any update on these? anyone get to test them yet? any dealers in the US? I am very interested in these..
Student Driver is offline   Reply With Quote
The Following User Says Thank You to Student Driver For This Useful Post:
why? (09-07-2017)
Old 09-06-2017, 06:09 PM   #21
imnotsureaboutbrz
Drives: between cars...
I got a set from them to test. I still have 2 autocrosses left this and next weekend. Then I'm gonna start my winter lift!
imnotsureaboutbrz is offline   Reply With Quote
Old 09-07-2017, 01:21 PM   #22
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
so you can run these with stock everything else? I'd be very interested, I seem to rub on absolutely everything, If the spring rate is oem or higher and the handling won't be destroyed anyways.
why? is offline   Reply With Quote
Old 09-07-2017, 01:40 PM   #23
Takumi788
JHerbert Racing
Takumi788's Avatar
Things like this make me really excited for the twins to be around $5-10k in the future. The twins are going to be everywhere and at that price point I would not hesitate to install these springs and make a ice racer out of one.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Shark_Bait88 (12-08-2017), strat61caster (09-07-2017)
Old 09-07-2017, 02:53 PM   #24
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The new 240sx
At <$10k engine swaps and suspension setups galore. But because you can find out how good they are on the internet, not word of mouth like the old days I don't think we'll see flatline <$5k prices for a long time, maybe never, kinda like WRX's there will always be demand for the chassis, at least where I live now. Some regions though I see people having trouble selling 86's at $13k in decent condition.
I just went and looked at WRX's and the only ones under $5k are 15 years old, nearing 200k miles and have problems. Ridiculous.
ineedyourdiddly
Old 09-07-2017, 03:39 PM   #25
Takumi788
JHerbert Racing
Takumi788's Avatar
The new 240sx
^Thats what I have been calling them. lol
We live in opposite worlds. In upstate NY there will never be a demand for the twins. People just buy WRX's bc they only want one car so it better be AWD. (We are #1 in the states for annual snowfall.) You rarely see the twins around here and yet you can throw a rock, skip it off one wrx and bank it into two others. Ill bet in the next 5-10 years they will be under 10k. At least in my miserable part of the world.
Old 09-07-2017, 03:46 PM   #26
mav1178
mav1178's Avatar
I'm waiting for Japan to reply about the spring rates.
MSRP $420 and raises the car approx. 15-20mm.
Waiting for a reply on the spring rates. They are meant to be reused with stock shocks.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
strat61caster (09-07-2017), why? (09-07-2017), Yoniyama (09-08-2017)
Old 12-08-2017, 09:59 AM   #27
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Have you put them on and tested them yet? I'd love to know how they feel and perform.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-08-2017, 05:01 PM   #28
mav1178
mav1178's Avatar
http://www.ft86club.com/forums/showthread.php?t=123508
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Spawn_Of_Creation (12-09-2017), why? (04-05-2020)
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 09:51 AM
Anyone in the DMV with a lift? Rifle Mid-Atlantic 5 06-06-2016 04:35 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 12:51 PM
