Old 08-23-2017, 03:19 AM   #1
Donovan34
Donovan34's Avatar
Drives: 2014 Turbo Monogram Frs
*Automatic* Second Gear Issue!!
Hey guys be having a issue that's been going on for couple weeks. It only happens in second gear in manual mode. The Rpms seem to freak out when I'm above 5000-6000. It's doesn't happen all the time but enough to have me worried. If any one has any thoughts what it could be would help a lot.
Donovan34 is offline   Reply With Quote
Old 08-23-2017, 10:53 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
What do you mean freak out?
1974 TA22 Celica
2013 86 GT
Old 08-23-2017, 11:57 PM   #3
Donovan34
Donovan34's Avatar
It's hard to explain. It basically jumps up real quick and then goes back to where it was before. I'll try to see if I can get a video of it.
Old 08-24-2017, 04:27 AM   #4
Donovan34
Donovan34's Avatar
Here a link to the video.
Old 08-24-2017, 02:36 PM   #5
arxm
Drives: 2013 FR-S, 2023 BRZ
it looks and sounds almost like its hitting the limiter but the rpms are way too low. my best bet would be to see if its throwing any codes and take it to the dealer ive never worked on an automatic before
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 08-24-2017, 04:57 PM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Try asking to have your transmission ecu reflashed at the dealership.
tyler_win_photo is offline   Reply With Quote
Old 08-24-2017, 09:09 PM   #7
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
it may be the factory tune? not sure...ive seen in a past thread that the tune is even more neutered top end in the automatic not totally sure.
mizzta21 is offline   Reply With Quote
Old 08-24-2017, 09:54 PM   #8
Donovan34
Donovan34's Avatar
So would tuning get rid of the issue? I was just concerned that it was my transmission going out but if it's just a ecu or tune problem. I'm about to get tune for my turbo when ever it comes in.
Old 08-24-2017, 11:35 PM   #9
Euro7R
Drives: 2013 Subaru BRZ
Maybe try unplugging the car battery and then plugging back on to see if that fixes it?
Euro7R is offline   Reply With Quote
Old 08-25-2017, 03:16 AM   #10
tyler_win_photo
In an automatic the engine ecu is separate from the transmission ecu. Try asking to have your transmission ecu reset at the dealership.
Old 08-25-2017, 11:01 AM   #11
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Agreed, looks like it's hitting the rev limiter, but earlier. Have you taken other gears to the limiter (past just 5-6k), does it feel the same as you're talking about?
Pointmutation is offline   Reply With Quote
Old 08-25-2017, 11:40 AM   #12
arxm
ive taken 1st, 2nd and 3rd to the limiter and its not like hondas where it will bounce off the limiter it completely cuts power for like a second which is very annoying btw. I dont pay too much attention to when the limiter comes in as i shift at redline when im playing around BUT i think its around 8k, much much higher than in the video posted above. Now back when I played around with hondas they would do this at like 4k rpm (where vtec usually engages) due to a clogged solenoid screen filter preventing vtec activation and thus preventing the car from going above 4k. I have almost no experience with subaru boxers so I have no idea what goes on at around 6k rpm in these cars that could be causing your issue besides perhaps the change in fuel injection but that happens during our torque dip at 4-5k so i really have no clue what could be going on
Automatic gear selector wiring pinout Scikotic Engine, Exhaust, Transmission 7 11-17-2016 05:31 PM
Automatic Gear Ratio change Toyota86.ir Engine, Exhaust, Transmission 31 05-10-2016 04:10 AM
Automatic Transmission Issue or ECU? OpteronO3 Issues | Warranty | Recalls / TSB 8 09-15-2015 01:04 AM
Manual gear shift in Automatic 86 djmm Scion FR-S / Toyota 86 GT86 General Forum 21 07-30-2014 08:08 PM
5th gear issue squizzbeat Scion FR-S / Toyota 86 GT86 General Forum 3 02-24-2014 06:02 AM
