Old 08-22-2017, 10:03 PM   #1
Dennett_
Dennett_'s Avatar
Drives: Sprintex Supercharged FRS
FA20Club Flex Fuel Kit
Hi I have a FA20Club flex fuel kit and I can't find instructions anywhere on how to install it. I know it's pretty basic and plug and play I just do not now how to connect it to the ECU because there's nothing to connect it to the O2 sensor. If anyone can help or can point me in the right direction towards instructions or a video that would be great
Dennett_ is offline   Reply With Quote
Old 08-23-2017, 12:12 AM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Get rid of it, that's one of the worst brands you can get for our platform. They are a disgraced company.
Dr. BRZ is offline   Reply With Quote
The Following 5 Users Say Thank You to Dr. BRZ For This Useful Post:
Alltezza (08-28-2017), cdrazic93 (08-26-2017), JohnJuan (08-23-2017), weederr33 (08-26-2017), wparsons (08-26-2017)
Old 08-23-2017, 11:06 PM   #3
srfrja
Flex Fuel Kit for FR-S
What flex fuel kit would you say is the best to get for a FR-S in your opinion.
srfrja is offline   Reply With Quote
Old 08-24-2017, 03:34 AM   #4
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Have you tried just calling the company and asking for a set of instructions?
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
Old 08-24-2017, 06:47 AM   #5
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
lol good luck with that
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
Decay107 (08-28-2017)
Old 08-24-2017, 07:09 PM   #6
Hawk77FT
Drives: GTS 86
Moto- East and Delicious Tuning. I have the Moto East one and is great. Great customer service and easy plug and play kit. I have the Evap harness too and it has been on the car for about a year with no issues whatsoever!
Hawk77FT is offline   Reply With Quote
Old 08-25-2017, 11:54 PM   #7
Dennett_
Dennett_'s Avatar
Well that doesn't really help me FA20CLUB is a bad company and they did bad things but the flex fuel kit is fine it has had no problems I just need instructions (: I just can't figure out the ECU part if anyone can help me with that.
Old 08-26-2017, 09:27 AM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Are you sure you have all the parts? Based on the Moto-East flex-fuel setup, besides the actual sensor part that taps into the fuel line, do you have something like this for all the electrical connections? (Sensor input, gauge output, Signal output which what goes over to my O2 sensor connector)
BirdTRD is offline   Reply With Quote
Old 08-27-2017, 04:42 PM   #9
Dennett_
Dennett_'s Avatar
Yeah I do but instead of having something that will connect to the O2 sensor it wants to go straight to the ECU. I've got the car running but I can smell gas in the cabin and it's really shaky/ the rpms are freaking out. I don't know if it should be like that because I haven't flashed my ECU w the tune yet.
Old 08-27-2017, 04:46 PM   #10
Dennett_
Dennett_'s Avatar
https://download.documentslide.com/g...NzyWIS9w%3D%3D I'm having trouble w the last page of the instructions which deals w the ECU.
Old 08-27-2017, 09:29 PM   #11
BirdTRD
Simply Forgotus
BirdTRD's Avatar
***If you are smelling fuel, stop what you are doing***
You should not be running your car unless everything is connected properly, both the fuel lines and the electrical connections and the correct tune is flashed. You either have a fuel leak or the ECU is dumping fuel into the cylinders because it's not connected/tuned properly.
I looked at those instructions and they're crap. From what I gather, if you have the latest version of the kit, they want you to cut whatever wire is currently going to pin C20 on the ECU connector (shown in purple as "flex fuel input") and connect the White/Blue wire from the analyzer unit to the wire on the connector side of the cut. It appears that you are basically disconnecting whatever is currently going to pin C20 and replacing it with the analyzer output (White/Blue wire). That's how I am reading it.
Maybe try to contact your tuner or perhaps another tuner that may have experience with this kit that can give you some better info.
Read through this thread which refers to the Visconti FF kit but it may be similar or even the same. http://www.ft86club.com/forums/showthread.php?t=40404
Old 08-27-2017, 10:11 PM   #12
Dennett_
Dennett_'s Avatar
Sweet I think you are right that should make things a whole lot easier. Everything was connected and there was no fuel leaking so it's probably the ECU not being connected properly. I'll try connecting it to the right wire on the ECU and let you know how it goes. I'm going to have to wait to flash the tune because my ecutek liscense USB isn't able to be read by any computer I try.
Old 08-28-2017, 03:24 AM   #13
QTR FMS
Drives: brz
instead of cutting any of the stock wiring use the rear o2 connectors and depin the wires and use the rear o2 for power ground and signal.
i can help you with few things i have made my own kit it was mostly premade didnt have to do lots of work except the wiring from the gauge.
QTR FMS is offline   Reply With Quote
Old 08-28-2017, 08:15 AM   #14
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Looks like pin C20 is from the Evap pressure sensor not the O2 sensor. Good info below.
http://www.ft86club.com/forums/showthread.php?t=94751
http://www.ft86club.com/forums/showthread.php?t=109995
*SOLD* FA20Club Flex Fuel Kit with ECU Harness UncleFester Engine, Exhaust, Bolt-Ons 2 03-13-2014 10:23 AM
FA20CLUB Offical ECUTEK Flex Fuel Kit Andy@FA20Club Engine, Exhaust, Bolt-Ons 116 01-15-2014 12:12 AM
FA20CLUB Tuned Flex Fuel Kit N/A FR-S 204whp 156tq Andy@FA20Club Engine, Exhaust, Transmission 31 10-16-2013 10:42 AM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 12:04 PM
FA20CLUB EUTEK True Flex Fuel Kit On Sale FA20Club.com Engine, Exhaust, Bolt-Ons 38 03-15-2013 01:09 AM
