| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: '13 FRS - STX
Here's what others have dug up.
http://www.ft86club.com/forums/showthread.php?t=8267 tl;dr due to the high compression direct injection nature of the FA20 it requires a specific uncommon plug design to operate well. NGK has some good info on why different plugs matter and the tl;dr there is that different combustion environments need a different kind of spark to operate at the way it was intended to. https://www.ngksparkplugs.com/about-...rk-plug-basics Some conclusions you can draw from that: spark plugs are cheap because of economies of scale, there are literally hundreds of millions of spark plugs manufactured every year and I'd bet most of them fall into a few categories. When you make tens of millions of widgets per year you can get production costs very low, but for the FA20/BRZ/FRS/86 they're only making maybe a few hundred thousand per year. Take the spark plug in a Toyota Camry, instead of making 50 million of those every year you only make 5 million. It doesn't cost any less to setup the factory and maintain the machinery but you are all of a sudden selling 1/10th of before, therefore prices must go up nearly 10-fold to maintain profitability. And that's how what "should be a $2 spark plug" is now a "$20 spark plug" (except now rare metals increase base cost but don't necessarily translate into lost profit margin based on economies of scale so we're comparing a $20 plug to a $8 plug) Why do I think this is true at all? Because if there was any other engine using this spark plug it would have been known years ago and yet every parts website lists it as the only option for this car and nobody else uses it. If you can find something that does then I'll re-evaluate my hypothesis. |
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: |
#16 |
Brand new. The old 440 Magnum was just really hard on them. Not as hard as it was on fuel pumps though. Anybody that invested in Mopar parts stock then must have made a killing on me.
#17 | |
#18 | |
![]() ![]() humfrz |
#19 |
Mechanical. The heavy cam I had in it would rip them apart. Happened so often that I could change one on the side of the road in 5 minutes. Eventual went electric and just blanked off the hole in the block. Never had an issue again.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (08-17-2017) |
#20 | |
![]() You go and put a big, hairy, long duration, high lift cam in the engine, which the lobe that pushed the arm on the fuel pump, waaay to far and punctured the rubber diaphragm, when it was trying to feed all those carburetors, no doubt linked in series, with enough gas to get your 3 MPG ..... 1/4 mile at a time....... ![]() Damn hot rodder! humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (08-17-2017) |
#21 | |
That is the perfect description!
#22 |
Famous Potatoes
Drives: '15 ultramarine
#23 | |
Famous Potatoes
So does this mean if/when they stop making the twins we all better go out and buy a few sets of plugs? |
| The Following User Says Thank You to Sapphireho For This Useful Post: | Tcoat (08-17-2017) |
#24 |
^^ When the engine design changes appreciably I think it would be a good idea.
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (08-17-2017) |
#25 | |
But that might be true for all spark plugs at that point. And hey, maybe plug manufacturing becomes a niche industry and they build to order anyway. Predicting the future is hard. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (08-17-2017) |
#26 | |||
Mind you anybody with NOS ones in 30 years can make a killing.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (08-17-2017), strat61caster (08-17-2017) |
#27 |
#28 | |
SupaSter
Drives: 13' BRZ
| Spark plug failure | BRZ68 | Issues | Warranty | Recalls / TSB | 9 | 06-12-2017 08:44 AM |
| Spark Plug Replacement | Dacfrs | Rocky Mountains / Great Plains | 4 | 03-21-2017 01:16 AM |
| P0351 bad spark plug... | Jaden | Engine, Exhaust, Transmission | 3 | 01-02-2016 11:19 AM |
| Spark Plug Time !!!! | RFB | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 11-24-2014 08:46 PM |
| Spark plug question | Wilsonk227 | BRZ First-Gen (2012+) — General Topics | 19 | 07-03-2013 01:57 AM |
