Old 08-07-2017, 10:37 AM   #1
paulca
Drives: Toyota GT86 Coupe Red (UK)
2017 Dynamic Shift indicator.
I've been playing with the shift indicator in the 2017 Pro.
In the 2012 all it seemed to do was display the shift up ^ beside the gear at about 2,000 rpm. So it was pretty static and it never seemed to tell you to downshift. (Note you have to enable the "Gear display" mode when stopped in the 2012, it isn't on be default.
The 2017 adds a bit more intelligence to it. If you are accelerating slowly, such as following a slow car or van, it gets you into 3rd at 15mph, 4th just past 20 and in to 6th at about 35mph.
However if you squeeze in the power it will not suggest a shift up until much higher.
Also if you are sitting in 6th at anything less than 45mph and floor it, it will suggest a downshift. Actually flooring it in any gear under 3 or 4k it suggests a downshift.
It's fairly pointless and not wise to sit and watch it, but it has the right idea about shifting and new-to-manual drivers could learn a thing or two from it.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-08-2017, 08:31 AM   #2
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
I just turned mine on to see what gear I'm currently at and just shift on my own.
IDFWU 420 is offline   Reply With Quote
Old 08-08-2017, 12:23 PM   #3
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
on my 2017 BRZ it isn't dynamic. It has one shift point really low in the rev range and then one higher and displays both no matter how I'm driving.
mjanmohammad is offline   Reply With Quote
Old 08-08-2017, 11:14 PM   #4
arxm
Drives: 2013 FR-S, 2023 BRZ
^in the non dynamic ones u can change when the shift light blinks at least on my 2013
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 08-09-2017, 03:00 AM   #5
paulca
Do you guys get the colour TFT screen or the old 2012 EU spec red LED one?
Old 08-09-2017, 08:05 AM   #6
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Shift light and shift indicator are two different things. The big red shift light can be adjusted, however, what's being talked about here is the gear indicator. It tells you what gear you're in, as well as displays an arrow when it's most economical/fuel efficient to shift (at least that's what I've read).
Link to turn on and play with settings:
http://www.ft86club.com/forums/showthread.php?t=8628
BigTuna is offline   Reply With Quote
Old 08-09-2017, 08:44 AM   #7
BboyRuda
BboyRuda's Avatar
Drives: Series.Yellow BRZ
wait how do you turn that on? It'd be nice to see on the display what gear I'm in. lol
Edit: Idk how to turn it on for the 2017 model
BboyRuda is offline   Reply With Quote
Old 08-09-2017, 09:35 AM   #8
mitsurugi_78
Drives: 17' Toyota 86 Halo
I have it enabled on my 17 but it's not dynamic...it's somewhere around 2200 rpm when it flashes pretty much no matter what gear I believe. Occasionally when down shifting and then getting on the gas it will flash right away as well but I don't think it's dynamic. And I'm not talking about the redline light/buzzer. Just the little ^ next to gear indicator.
mitsurugi_78 is offline   Reply With Quote
Old 08-09-2017, 10:01 AM   #9
arxm
bruh i had mine on and somehow it turned itself off and even after reading how to get it back i couldnt i forgot there were 2 different ones
Old 08-10-2017, 06:22 AM   #10
paulca
I'm gathering the USA 2017 is not the same as the EU/UK one.
Do you still have the Red LED Speedo and trip read out? The EU/UK one has colour screen with cool stuff like:
G meter instant
G meter peak (in 2D chart)
Water and oil temp + battery voltage.
Trip with average speed, total time, total distance.
Fuel including miles to go
Messages (includes low fuel, TPMS, faults etc.)
Lap timer / stop watch
Settings page (for rev limiter etc.)
Old 08-10-2017, 06:49 AM   #11
What RPM Is Your Shift Light Indicator Set To? j0sch Scion FR-S / Toyota 86 GT86 General Forum 47 03-12-2016 05:28 PM
Shift indicator set-up Concorazon Scion FR-S / Toyota 86 GT86 General Forum 15 10-22-2015 11:13 AM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 01:50 PM
shift indicator sticker Juurian Cosmetic Modification (Interior/Exterior/Lighting) 27 05-25-2013 01:03 AM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 07:24 AM
