#29 |
Drives: Not Yet
wow runfile15 is nice (170hp)
#30 | |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
First, I only run shell and chevron 93 octane, so it is likely that the motor is not having to pull any timing for knock response. Toyota's ECUs actually start at Maximum timing, and then they use a long term and short term knock trim to pull timing back out to the currently desired level. You can reset this value by resetting the ecu (disconeccting the battery). Those values both exist in the FRS ECU when viewed with a Toyota Techstream scantool, so I suspect it is the same as the rest in that respect. Now there MAY have been some fuel related timing reduction for the first pull, but it did have 93 in the tank from an Exxon station across from the dealer. And a good deal of it is from break in. We actually felt a huge difference after we took it to the drag strip at @300 miles or so. We made over 16 runs, and about the first 12 were literally back to back. The next day there was a definite increase in power. I have also seen a corresponding increase in fuel economy even when driving hard. It should be noted the ambient temps were warmer on the more recent pulls as well. |
#31 |
#32 |
Spaceman
Drives: 2013 Firestorm Scion FR-S
So, this means ~15% drivetrain loss assuming the engine is truly putting out 200hp at the crank?
Not too shabby. Eh?
#33 | |
After ecu reset the car does not run maximum advance. Car needs to e given a drive cycle and go thru some things in order for the advance multiplier to jump up allowing maximum advance. By default the advance multiplier is at .7. Car won't see full advance until the advance multiplier jumps up to 1.0 John |
| The Following User Says Thank You to Visconti For This Useful Post: | jedibow (07-05-2012) |
#34 |
Kuruma Otaku
I thought they both use Denso?
Because titanium. |
#35 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Not bad numbers at all.
#36 |
Drives: Not Yet
I wonder if a full exhaust on this car would raise the HP from
170 to maybe about 5-10 more horses or just stay the same ? |
#37 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
#38 |
Drives: 99' M3, 13' SWP Brz
haven't been reading much, Nameless has seen >20whp from their full exhaust and Vtune has another 18wp gain from tuning, I'm sure if you tuned in the full exhaust and an intake you could see >40whp gains
#39 | |
N7 Spectre
Drives: 2017 Toyota 86 (Ablaze - 6MT)
I would be seriously impressed with the boxer & DI if it could manage that =D Here's to hoping for the best results!
GT 6/ Sport PSN: Koji_Online
#40 |
#41 | |
#42 | |
Drives: Not Yet
It would be awesome if a tune by it self would offer just 20-25whp. We just have to wait and see. Oh and thanks for message Boosted2.0 |
| BRZ on the dyno | Symbiont | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 05-22-2012 02:17 PM |
| When will magazines start testing the performance? | swift996 | BRZ First-Gen (2012+) — General Topics | 10 | 03-23-2012 03:10 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
