Old 08-01-2017, 01:41 PM   #1
dvniemela
dvniemela's Avatar
Traction Control Kicks On Around Corner
2013 FR-S. When cornering to the right, the traction control will kick on and car will act strange. Does not do that when turning to the left. Any ideas?
dvniemela is offline   Reply With Quote
Old 08-01-2017, 01:52 PM   #2
StraightOuttaCanadaEh
Wes
you mean to the left?
Old 08-01-2017, 02:02 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
How are your tires?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-01-2017, 03:04 PM   #4
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Wrong place for the thread. This needs to me moved to the Suspension | Chassis | Brakes section in Technical Topics.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-01-2017, 03:13 PM   #5
BabaYaga
BabaYaga's Avatar
Drives: FRawSome Hot Lava
Originally Posted by dvniemela View Post
2013 FR-S. When cornering to the right, the traction control will kick on and car will act strange. Does not do that when turning to the right. Any ideas?
Same thing. Oversteer only on right turns, fine on left.
Michelin supersport tires 225/45/17.
BabaYaga is offline   Reply With Quote
Old 08-01-2017, 03:32 PM   #6
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
The trac off button doesn't fully turn off the TC you need to do the pedal dance to fully turn it off.
DandoX is offline   Reply With Quote
Old 08-01-2017, 04:13 PM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I'm assuming it's with the TC still on?
A few possibilities come to my mind.
- driver weight on one side? (This may be invalid if this is already accounted for when setting the car up from the factory)
- alignment differences from L/R?
- If it's not the same place, maybe the road surface is different?
BigTuna is offline   Reply With Quote
Old 08-01-2017, 05:47 PM   #8
dvniemela
dvniemela's Avatar
Originally Posted by 8RZ View Post
How are your tires?
Tires are in excellent condition.
Old 08-01-2017, 08:54 PM   #9
stevesnj
stevesnj's Avatar
If the tires are a different height width or you have different wheels from stock sizes you need to do a Zero Point Calibration.
My 2016 Build thread
Old 08-02-2017, 12:22 AM   #10
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
As noted, it could well be just driver weight. Turning right, you are adding more load to the left side (including driver weight), and lightening the right side. Turning left, you are reducing load on driver side and adding to (lighter) passenger side. I can tell the difference when I track my car with, and without, my son riding along (about same size).
If you have some spot that is repeatable, try it with, and without, a similar-sized friend riding shotgun.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 08-02-2017, 01:34 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Is this test being performed on a skidpad?
On a public road what are the odds you're actually performing exactly the same turn right vs. left? I'd say pretty slim unless you're in a parking lot.
ineedyourdiddly
wparsons (08-03-2017)
Old 08-02-2017, 03:01 PM   #12
Chronology
Drives: 13' Satin White Pearl BRZ
I did google it, cant find anything. Can you explain the process? I assume ill need some type of interface into ODB2?
Thanks!
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 08-02-2017, 04:54 PM   #13
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
See if you can get a big empty parking lot with consistent, fairly fresh asphalt and try both left and right hand turns. Bring a passenger along to see if it's truly repeatable. Snap the wheel 1/8 turn each time, then 1/4 turn and see if both times it was identical.
I think the previous posters are onto something with either inconsistent turns, passenger weight, or a super screwy alignment.
Have you had the car aligned? Has it always done this or is this new behavior? (Or is the car new to you?)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
strat61caster (08-02-2017)
Old 08-02-2017, 05:32 PM   #14
strat61caster
^ +1 on alignment if there truly is a problem
ineedyourdiddly
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
corner exit traction autobrz BRZ First-Gen (2012+) — General Topics 50 06-09-2013 02:55 AM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
