Old 07-18-2017, 09:27 AM   #4089
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
Got real lucky this weekend!! Brackets broke right off...It did not grind right threw my oil reservoir!
Think I remember seeing @KraftWerks have made some new brackets?
Freeze2196 is offline   Reply With Quote
Old 07-18-2017, 09:38 AM   #4090
John92
Drives: White scion frs
Think I remember seeing @KraftWerks have made some new brackets?[/QUOTE]
Yes they did! Same thing happened to mine a while back.
Follow me on IG:@john9207
John92 is offline   Reply With Quote
Old 07-18-2017, 01:47 PM   #4091
Freeze2196
Freeze2196's Avatar
Cant seem to find them on the website? how did you get them?
Old 07-18-2017, 05:28 PM   #4092
John92
Call and talk to CJ Weidl he can help you.
Old 07-19-2017, 08:45 AM   #4093
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
You can buy two large "P" clamps with rubber cushion and be done with it. They look like this:
http://www.homedepot.com/p/Gardner-B...7795/100160272
You'll need to find the correct size/ diameter to wrap around the whole reservoir though.
Helios is offline   Reply With Quote
Old 07-21-2017, 11:25 AM   #4094
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
CJ doesn't work for the company anymore. Seems like a lot of people are having that issue. I would make your own brackets from home depot and put rubber washers to absorb the vibrations. Good luck getting someone to help out. KW customer service has been REALLY difficult to work with recently with myself and a few others on the FB group. Good luck.
pgranberg11 is offline   Reply With Quote
Old 07-21-2017, 11:54 PM   #4095
86socal
86socal's Avatar
Drives: White frs
Which vendor has the best deals for this supercharger?
86socal is offline   Reply With Quote
Old 07-31-2017, 08:51 AM   #4096
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
My pulley bearings all have play after 8000kms (belt tension was checked throughout). I'm pretty sure I saw someone else with the same problems. It looks like the bearing loose their grease and wear themselves out prematurely. I started to hear a knocking sound so I took the belt off to check. I'm so glad it wasn't coming from my motor though.
They appear to be generic 6203-2RS no-name bearings. I love the kit but the cost savings that KW made seems to be biting us in the behind.
Also, does anyone else hate the fasteners that KW supplied? They look like sh*t after a few years turning a rusty colour.
Originally Posted by D-VO View Post
This just happened to me today while driving. I thought a hose popped off because of the pressure dispersal sound, but after inspecting the pulley was leaning against the compressor. Taking it apart right now.
Output shaft broke. Factory 30T-75 pulley on a C38. =( Its been almost exactly 3 years since install.
Sound like me 2 years ago. That pulley should come pre-installed with larger fasteners and loctite-red.
projek_01 is offline   Reply With Quote
Old 08-01-2017, 01:18 AM   #4097
projek_01
projek_01's Avatar
Well, replacing the bearing has only helped a little bit... Seems like the actual bearings in the blower are shot. Just stumbled upon this video and Tommy is seems like he has already experienced what I'm seeing.
[ame="https://www.youtube.com/watch?v=4K-uYgy679w"]Opening the Rotrex C30-94 Supercharger. - YouTube[/ame]
Old 08-04-2017, 12:15 AM   #4098
JoeeStacks
Drives: Brz
What is everyone running for an oil cooler? Just picked up this kit, looking for something thermostatic.
JoeeStacks is offline   Reply With Quote
Old 09-05-2017, 04:18 PM   #4099
hyrixx1
Drives: S2000
I am looking for the stock 95mm (30 wide) Cog style pulley. Any chance anyone has one laying around and would sell it to me? Kraftwerks is on back order for 60+ days.
I have a 90mm if anyone would like to trade
Thank you in advance.
hyrixx1 is offline   Reply With Quote
Old 09-07-2017, 10:29 AM   #4100
Grozniy
Drives: GT86
Originally Posted by pgranberg11 View Post
I would never buy that thing again after my first mistake of buying it. There's no way that thing will hold any type of oil from leaking. I had to custom make an oil cooler with stacking spacers together. Pain in the ass.
Hi
What's problem do you have with this sandwich plate ?
Grozniy is offline   Reply With Quote
Old 09-07-2017, 12:35 PM   #4101
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by Grozniy View Post
Hi
The rubber o ring that they supply is too big for the ring groove at the bottom of the sandwich plate. So what will end up happening is once it gets hot enough; the rubber will deteriorate and cause an oil leak.
also if you check my build thread, found in my sig, you can see how i stacked a perrin spacer and the mocal spacer and mocal thermostat together to make something to clear....
Old 09-14-2017, 04:02 PM   #4102
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
if anyone is looking for a kit. get it. 3000 plus shipping:
i don't mind doing quotes just let me know your zip.
http://www.ft86club.com/forums/showthread.php?t=121711
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
