Old 07-16-2017, 11:32 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Drivers side rattle/vibration near A pillar?
post installing my flexfuel kit I seem to be hearing a rattle vibration that changes with speed that appears to be coming from the drivers side A pillar/dash area. My wife noticed it as well and believes it to be on the drivers side.
I have checked all the pieces of the flex fuel kit and I don't think it is the issue as I've made sure everything is well secured and zip tied (even with rubber spacers on the sensor itself).
I have searched and most of what I see or read is related to the rear deck. I did see a thread related to the headliner. I've checked under the hood and can find nothing that would seem to be the issue.
Suggestions or thoughts on what could be the issue? I believe all the panels removed for the install of the flex fuel kit are reinstalled correctly.
Many thanks.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-17-2017, 12:15 AM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
Smack it...
Old 07-17-2017, 12:32 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
it will go away once you drift around in it.
check speaker grill and smack it
Old 07-17-2017, 01:11 AM   #4
Speaker/speaker grille. TSB for early 2013 production runs. IIRC, some wires interfere with how the grille seats in its socket.
Worth a look.
Old 07-20-2017, 06:40 PM   #5
brillo
So do I just pop the speaker grille out and secure the wires? What is the DIY fix in this instance? I tried slapping the grille a few times to see if it would seat better but no luck.
What tool are you using to pop out the grille?
Old 07-26-2017, 08:59 AM   #6
brillo
bump for help.
Old 07-26-2017, 09:48 AM   #7
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I've had the same issue. Pull your A pillar trim and look and see if the metal brackets holding the curtain airbags to the actual A pillar of the chassis are loose. There's also one higher up by the headliner.
ApexEight is offline   Reply With Quote
Old 07-26-2017, 10:57 AM   #8
brillo
how do you pull the A pillar trim? can I find that in the service manual?
Old 07-26-2017, 11:06 AM   #9
D-rek07
Just pull on it. It is held in with metal clips
D-rek07 is offline   Reply With Quote
Old 08-08-2017, 12:47 PM   #10
trakfloater07
trakfloater07's Avatar
Drives: 2015 Scion FRS Firestorm Red
Did this work? I have a rattle in the same area. I have a 2015 FRS as well :/
trakfloater07 is offline   Reply With Quote
Old 08-08-2017, 01:52 PM   #11
ApexEight
Worked on my car. Mine sounded like a persistent squeaky rattle while driving that would go away if I pressed on the A pillar trim.
Drivers side pillar rattle! (With links) Weeber Issues | Warranty | Recalls / TSB 9 01-02-2020 03:15 PM
rattle and vibration when braking? dokterdewe Issues | Warranty | Recalls / TSB 19 09-01-2019 09:44 AM
engine rattle/vibration sound @ coldstart beat1 Issues | Warranty | Recalls / TSB 7 04-12-2017 10:59 AM
Help with rattle on Window Pillar? ray7792 Issues | Warranty | Recalls / TSB 3 11-15-2014 10:04 PM
Rattle in drivers side headliner-help! meadowz06 Issues | Warranty | Recalls / TSB 5 09-18-2013 11:44 PM
