#491 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
It can be done with adb commands, but that would obviously involve getting it connected to a PC :/ Some of them will do do adb over wifi...maybe see if that's available under 'developer settings'? |
#492 |
Drives: Asphalt FR-S
You have to hold power down for a good 5 seconds until you see the backlight flashing. Also if you load the ROM into the GPS SD card root location you should be able to go into settings under check for update. Should work that way.
Sent from my Pixel XL using Tapatalk |
#493 |
TRACKBREAD
Got it!
To get into recovery Hold power until lights flash > let go > short press power TWICE |
#494 |
#495 |
Thinking of upgrading to this unit https://www.carjoying.com/joying-new...leep-mode.html reposted
Sent from my Pixel XL using Tapatalk Last edited by Rican_D; 07-08-2017 at 08:31 PM. |
#496 | |
Time Traveller
#497 |
Weird, don't know why it comes up with error. Well it's on the main page https://www.carjoying.com 7" universal. Model: JY-UM135N2
#498 |
Switched from the malaysk ROM to the Booroondook 5.1 ROM and I'm much happier. Also installed the sound Xposed module. Much better EQ control with preamp. I do eventually want to upgrade to the new units that run marshmallow. They seem to run so much quicker.
#499 |
Drives: 2015 Subaru BRZ Series.Blue
I wonder if Viper for Android would improve the audio output even more.
#500 |
#501 |
Viper is packaged with most (all?) of the custom ROMS.
Another alternative to buying a new unit or soldering RAM is replacing the board...Witson sells PX5/2GB RAM/32GB ROM boards for ~$120: https://www.aliexpress.com/item/WITS...ddresstype=600 People over on XDA have been installing those on many different brands of MTCD units. |
#502 | |
#503 |
Was looking on XDA, looks like 7.1 units are coming out. https://m.aliexpress.com/s/item/3280...98daa#autostay
#504 | |
Discussion about replacing the whole board starts around page 10 or 11 of this: https://forum.xda-developers.com/and...o-px5-t3581741 |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
