#673 |
Drives: GT 86
Hey Guys,
I have the Sprintex 210 kit on my 86. I am using the tune that was supplied with the car from Bullet/MRT in Australia. Knowing that you guys helped them with their tune, is there much difference between their tune and your tune? |
#674 | |
PhoneFlash by EcuTeK
I haven't run across any Bullet/MRT tunes, but I have had a few guys from your side of the pond purchase our tune after running theirs for awhile. Try it out, I'm sure you'll like it. ![]() Sincerely, Zach Delicious Tuning |
#675 |
Stuck In a Sandbox
Drives: FRS RS1.0
Possibly a dumb question. But im running this FnG tune on my FRS. How do I enable the extra goodies like Flat foot shifting and autoblip? I haven't been able to find where I do that at...
| The Following User Says Thank You to Super Dave For This Useful Post: | CHMBRZ (02-15-2017) |
#676 | |
Drives: 13 FRS - Boosted
With the car on, pull the cruise control towards you and hold. you'll notice the rpm needle go to a stand still on what setting you're on. By default it should be on one, release the cruise control and move it up or down. My settings inorder is : 1 - auto blip 2 - Flat foot shifting 3 - launch control 4 - Trac control. Sent from my SAMSUNG-SM-G935A using Tapatalk |
#677 |
Drives: 2013 Firestorm FRS
also, as far as maps go I'd do this: flat foot shift and launch control on EVERY MAP
You have to be very deliberate to activate either one, so you might as well have them on all maps! But up to you of course |
#678 |
We've been getting a few folks lately running into specific CELs, namely P0201-P0204. These are injector hard circuit codes, and are not related to the tune, no matter who your tuner is. As the description of the code suggests, these are a faulty circuit between the fuel injector and the chassis's electrical harness. When this code occurs, your fuel injectors are losing power and connection with the ecu, and this will cause the injector to shut off.
This problem occurs solely on aftermarket injectors with adapter harnesses in place. Luckily, we have a fix for this issue in the form of hard connectors that eliminate the need for any poorly wired, aftermarket adapter harnesses. These connectors are available here: https://www.delicioustuning.com/node/437 As a general reminder, check engine lights are not always, and really rarely an indication of a tuning issue. Check engine lights exist to warn the driver of a mechanical issue. If you run into a light and you aren't sure what is causing it, the best course of action is to ask your tuner what might be the cause, so they can give you guidance in diagnosing and fixing the issue. Sincerely, Zach Delicious Tuning |
| The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post: | -Phil (02-17-2017), 86 South Africa (09-18-2017), BigFatFlip (02-17-2017), Irace86 (02-18-2017), Jasonbot (02-17-2017), Kris86 (02-20-2017) |
#679 | ||
Drives: 2015 86 GTS + Mitsi Lancer GSR
MRT do all their own tuning. Bullet claim to do their own tuning but I believe they source their base map from a different tuner in Brisbane. The non-EcuTek tune you can get from Sprintex was actually developed by them using Alientech software. I wouldn't use the MRT tune, notoriously bad name. I used the Sprintex tune and it was alright but hesitated (found the reason, load cell was mis-scaled). I swapped to the Delicious tune and boy oh boy I did not regret it!! Had a lot of people drive my car and say how amazing it was and couldn't believe it was supercharged with the amount of power it was putting down. Quote:
| The Following User Says Thank You to COO86L For This Useful Post: |
#680 | |
Drives: RHD Gt86
Ordering these for my build
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 02-20-2017 at 06:53 PM. |
#681 |
Drives: 86
quick question.
coming from NA with UEL headers, if I decide to install my c30 JRSC kit and upload the stock JRSC Delicious tune you guys sent me, would the car be drivable? I know i'll need to get revisions to get the most out of my headers, but would it be safe to drive on the stock JRSC tune even if I already have headers installed? |
#682 | |
-Zach |
#683 |
Drives: Sprintex carbon fiber wide body
Hey delicious. I have an intercooled innovate SC with your 69mm pulley, flex fuel, 700cc injector kit and tune. My car has hunting and stalling lately when shifting into nuetral on both 91 and e85, but more so 91. Seems to be more frequent as the outside temp rises. I am in AZ so its been pretty hot lately. The car drives and pulls like normal otherwise. Also, when cold or warm starting the car cranks for a while then barely starts. Have you guys encountered this at all or got any tips?
It threw one mis fire code on cylinder 1 and I swapped injectors hope something would change. Vacuum seems to be fine and boost holds like normal. I plan to do a smoke test and check the battery today. Sent from my Nexus 6P using Tapatalk Last edited by leets4uc3; 07-12-2017 at 10:45 AM. |
#684 | |
-Zach |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | leets4uc3 (07-12-2017) |
#685 | |
Sent from my Nexus 6P using Tapatalk |
| The Following User Says Thank You to leets4uc3 For This Useful Post: |
#686 |
Update:
Our tunes specific for Edelbrock, Cosworth, Harrop, and Innovate/Sprintex superchargers have all been updated. Changes are as follows: - Improved VVT for stronger and more consistent low end response. - Refined throttle mapping in low end and mid range. - Further optimized Front 02 scaling for better accuracy. - Finer control over custom closed loop fueling during WOT. - RaceROM 9.1 added for EcuTek Bluetooth Connect compatibility, with more custom features to come. - (2017 Specific) - Standard RaceROM features now patched and working appropriately. Latest version numbers are now as follows: Edelbrock/Cosworth/Harrop V22.00 Innovate/Sprintex Non-Intercooled - V10.00 Innovate/Sprintex Intercooled - V11.50 Zach Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | frsq5 (10-04-2017), Kenny_LongWrench (10-04-2017) |
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 02:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 12:36 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 01:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 01:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 12:36 PM |
