Old 07-07-2017, 12:52 AM   #1051
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
on the pc log in as admin
delete the C:\openflash directory and all subdirectories
download and reinstall openflash manager from here
http://www.openflashtablet.com/downloads/
as admin
plug in oft and see if update completes
Did this, worked for about 5 seconds then froze again.
Did it 4 more times...still nothin.
Really hoping @Shiv@Openflash can chime in or respond to my emails.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 07-11-2017, 02:38 AM   #1052
PDXsuperfly
Drives: 2013 FRS
The OFH specific tunes were done with 91 OCT... I just got an email back.
Tunes loaded in oft default datavase are 93 octane I believe.
The ofh specific tunes were done for 93 fuel, and top brand 93 they are more agresive than the standard 93 tune
PDXsuperfly is offline   Reply With Quote
The Following User Says Thank You to PDXsuperfly For This Useful Post:
nikitopo (07-11-2017)
Old 07-11-2017, 04:24 AM   #1053
steve99
Drives: FT86
G
I think the wording in the tune read.me file was something like
Openlash Header
-Stock air box (any filter is fine)
-91 or (better yet) 93oct fuel from a quality Top Tier brand (Shell, Chevron, 76, etc,.)"
Yes it will run on 91 but will be much better on 93,,. Id like to see a log of the ofh specific tune on 91 i suspect their would be some knock, especially when pushed hard
Its a more agressive tune than the older 93 tune timing and fueling wise
Old 07-11-2017, 11:20 AM   #1054
alxtheoreo
alxtheoreo's Avatar
If I can remember the folder/files correctly, there's a tune for each octane - so 91 and 93. I know I've tested 91, yet I have 93 everywhere.
The engine doesn't feel lively with the 91 tune on 93 octane, nor did it increase gas mileage.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 07-11-2017, 08:59 PM   #1055
PDXsuperfly
Drives: 2013 FRS
You are correct I just pulled the read me file up... I will throw that OFH tune on and do some logging... Granted here in Portland the highest I can get is 92OCT
G
Openlash Header
Old 07-12-2017, 06:16 PM   #1056
RedZaku
Drives: 2013 brz
Is open flash tablet manager mac compatibly yet?
RedZaku is offline   Reply With Quote
Old 07-12-2017, 08:04 PM   #1057
jubella2
jubella2's Avatar
Drives: DGM BRZ
I just bought a used tablet and when I plug it to the car nothing happens. If I plug it into the computer the screen turns on and everything seems fine. Any ideas? I tried googling but couldn't find any similar issues.
jubella2 is offline   Reply With Quote
Old 07-12-2017, 08:31 PM   #1058
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
If it works with the comp, but not the car it could likely be the cable. The connector on the Tablet side has small open square sockets, if they get stretched open they won't make contact or will make poor contact causing a flicker/reset. (which is what mine was doing). look with a magnifying glass and light, If they are even slightly bent open, I would bet this is the issue. If you have a small jewlers screwdriver, or pick/scribe you can try to gently bend the sockets closed again.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
jubella2 (07-12-2017)
Old 07-12-2017, 11:46 PM   #1059
jubella2
jubella2's Avatar
Drives: DGM BRZ
Problem solved. There is an OBD fuse on the inside panel that was blown. Replaced that and the tablet booted right up. @Target70 thanks for your response.
The Following User Says Thank You to jubella2 For This Useful Post:
Target70 (07-13-2017)
Old 07-15-2017, 11:36 PM   #1060
Teseo
Drives: frs
How accurate is the oil temp on OFT? Mine's are on 203 - 228 on spirited driving
Old 07-16-2017, 01:22 AM   #1061
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I could be mistaken, but I thought it just read the temperature off the CAN bus. Are you asking how accurate the sensor is?
Old 07-16-2017, 06:31 AM   #1062
Teseo
Drives: frs
Yes
Old 07-16-2017, 11:18 AM   #1063
Spuds
The Dictater
Spuds's Avatar
Yes
I recommend finding the part number in the tech manual, then looking that up. I haven't read through it, but the manual might have the basic specifications for the sensor in there too.
http://www.ft86club.com/forums/showthread.php?t=12135
Old 07-16-2017, 08:53 PM   #1064
PDXsuperfly
Drives: 2013 FRS
I went ahead and tried to do a 3rd gear WOT but ran out of room before I could get to redline. BTW this is on 92oct OFT & OFH using the OFH tune. I just got a K&N drop in filter so after I read up on tuning and logging I will be doing another. I realized how little I know about tuning and the OFT has got me really interested in learning more...
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
