Old 07-10-2017, 02:00 PM   #1
imnotsureaboutbrz
Drives: between cars...
What is this noise? Brake 'lsd'?
I had this posted in the track forum but thought I might get more feedback here.
So first of all everything below is about the 2017 BRZ with the newly configured traction/stability control system. Below in the manual it states that if you hold the 'off' button for 3 seconds it disables traction and stability control AND in a manual car the Brake LSD is also disabled (i.e. no need for pedal dances).
https://view.joomag.com/subaru-brz-m...028204?page=11
So...
I've heard this noise at a couple of events but this is the best one that got captured on video. I'm running my 2017 Brz with Traction Control 'OFF' which I thought disables the brake lsd thing? So what do you think it is? It can be heard at: ~:35 and ~:45
[ame="https://www.youtube.com/watch?v=Ao3HYMnGQhk"]July 9th Alaska SCCA Autocross C-Street 2017 Subaru BRZ - YouTube[/ame]
imnotsureaboutbrz is offline   Reply With Quote
Old 07-10-2017, 02:02 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
your ABS is kicking in.
Only way ABS is disabled on this car is if you pull the ABS fuse.
Old 07-10-2017, 02:04 PM   #3
Pho20
Drives: 2013 Subaru BRZ
Vsc is still enabled you need to do the pedal dance
http://thenewswheel.com/how-to-unloc...ur-subaru-brz/
Pho20 is offline   Reply With Quote
Old 07-10-2017, 02:28 PM   #4
imnotsureaboutbrz
VSC is disabled in this mode see page 102
https://stis.subaru.com/proxy/125807...706ASTIS_5.pdf
Old 07-10-2017, 02:29 PM   #5
imnotsureaboutbrz
I was thinking that may be it, but why is it engaging? is it a function of the Brake LSD? I have braked HARD (in straight lines) in this car and have not had the abs kick in before
Old 07-10-2017, 02:37 PM   #6
mav1178
mav1178's Avatar
Braking + turning in.
Your tires can only give you so much traction... if you are braking then turning in, the changes in wheel speed will make the car think you are locking up your wheels.
If pedal dance (diagnostic mode) does not resolve this behavior, you just need to learn to drive smoother to not engage this.
Old 07-10-2017, 02:41 PM   #7
Pho20
Even when it's "off" parts of it are still on the only way to turn it off completely is to do the pedal dance
http://www.ft86club.com/forums/showthread.php?t=25494
Old 07-10-2017, 02:54 PM   #8
imnotsureaboutbrz
that kinda makes sense... I really thought I could avoid the pedal dance non-sense by going with a 2017 model... I guess we will see next month if I feel/hear any differences at the next event.
Mods please close
Old 07-10-2017, 03:01 PM   #9
Mods please close
Good luck!
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 11:14 PM
Diagnosing a brake noise, need help.. Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2017 03:47 AM
What is this noise? Brake 'lsd'? imnotsureaboutbrz Tracking / Autocross / HPDE / Drifting 20 07-11-2017 05:20 PM
Brake pedal release noise FR-YES Issues | Warranty | Recalls / TSB 4 10-19-2014 05:39 AM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 04:25 PM
