Old 07-02-2017, 07:14 PM   #1
BCFRS
Drives: 2017 86
Seat Bolster Question - Potential New Owner
Hello all,
I finally test drove a 2015 FRS and fell in love with it! Currently I drive a 2015 GTI PP with DSG. I was very close to making the trade but I found the side bolsters were jabbing into my ribs. I'm 6' 200lbs with athletic build (spend lots of time mountain biking, hiking and skiing). I've done some searching and found a thread about bending the bolster supports with brute force but I'm concerned about the airbags. Which also leads into a no go with aftermarket seats.
So, initially I find the seat really good but after about 30min the pressure on my ribs really starts to get bad. There doesn't feel to be much material between the support and the seat fabric so I'm not sure the seat will 'break in'.
I've also read of people using some back support to give them some room. I just don't want to get into a new vehicle and get setup for heartbreak when I realize the seats aren't gonna work. I talked with one local auto upholstery shop and it didn't sound promising with the airbags involved.
Any advice/words of wisdom? I'd love to make this work!
Thanks!
BCFRS is offline   Reply With Quote
Old 07-02-2017, 08:48 PM   #2
Hello BCFRS and welcome to our forum ..........
The only thing that I might suggest, would be to get a seat pad that would fit just in the center section of the back of the seat.
That may position your body "away" from the bolsters far enough that they won't bother you.
That worked for some folks over on the Miata forum.
NOTE: I'll call on our resident "big guy" @Ultramaroon for his input (although, I'm not sure he has an "athletic" build) .....
Old 07-02-2017, 10:31 PM   #3
Oh, there are plenty of big guys here. Your build must be just different enough to make it an issue. I'm 6-5 and notice the cavity down the middle but it doesn't feel uncomfortable at all. My shoulders are actually above and outside the bolsters.
Try what @humfrz recommends. Maybe start with a good stiff sofa pillow or cut out a strip of memory foam. If it seems to work, you can take the plunge and strap a good custom device in there.
humfrz (07-02-2017)
Old 07-02-2017, 10:47 PM   #4
Teseo
Drives: frs
Teseo is online now   Reply With Quote
The Following User Says Thank You to Teseo For This Useful Post:
trvth (07-07-2017)
Old 07-02-2017, 11:02 PM   #5
BCFRS
Drives: 2017 86
Thanks for the info guys! I'll give it a try with some cushioning down the middle to see if it lifts me out a bit. There's one more auto upholstery place I'll contact and see what they say.
I'll report back when I find out more.
Old 07-02-2017, 11:53 PM   #6
What I used in my Miata was a section of "closed cell" foam from a roll that backpackers use to sleep on. I cut a section to fit in between the bolsters (maybe two layers for you) that I covered with a black pillow case.
The only difference is, that I used it on the bottom of the seat, in the center section, to cushion my old tail bone and arthritic hips.
No athletic build here ......
spike021 (07-03-2017), Ultramaroon (07-03-2017)
Old 07-03-2017, 12:53 AM   #7
I think that's better than my memory foam suggestion. That stuff has too much give to it.
humfrz (07-03-2017)
Old 07-03-2017, 09:22 AM   #8
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
I might add that most people are not used to the aggressive side bolstering these seats provide. They really are good seats. Just takes a little time to mold your body into the tight space.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
The Following User Says Thank You to Braces For This Useful Post:
Scrappydoo (07-04-2017)
Old 07-03-2017, 09:16 PM   #9
Decep
Drives: 2013 FR-S Series 10
Honestly, my upper back felt sore for the first week driving it because of the bolsters (have a fairly wider build in the upper body) but you get used to it. Just keep at it OP before you change anything.
Old 07-03-2017, 11:14 PM   #10
Zhangy
Drives: 2015 FRS
just buy a seat cushion
Zhangy is offline   Reply With Quote
Old 07-04-2017, 02:02 AM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
New seats always are uncomfortable. Took about 2 months farting on them to shape it.
I suggest you eat lots of gas rich foods and go on a long drive. By the end of your drive you'll have the perfect body molded seats.
Just don't take a passengers or small animals. And please do not smoke and crack a widow.
The Following User Says Thank You to Mr.ac For This Useful Post:
funwheeldrive (07-05-2017)
Old 07-05-2017, 12:47 AM   #12
airjonny
airjonny's Avatar
Drives: Nissan Murano
I love the seats. I'm just about your size with the same build and I love the hugging feeling that I get when I've sat in the 86/BRZ. I haven't sat in them for long periods of time tho. But my weight is more in my legs than up top. I get thrown around in my Murano.
airjonny is offline   Reply With Quote
Old 07-05-2017, 11:58 AM   #13
Dake
Dake's Avatar
I'm 6'2" and 195, and I definitely felt the bolsters compressing my lats if I really settled back into the seat. I don't know if it was the seats, me, or a combination of both breaking in, but now it feels completely natural, and most other car seats feel sloppy.
I did a six hour round trip within a month of ownership and a thirty hour round trip a couple months after that - one of the most comfortable cars I've owned.
Dake is offline   Reply With Quote
Potential new FR-S owner Kutanks Scion FR-S / Toyota 86 GT86 General Forum 38 05-02-2017 01:37 PM
Potential Owner - FRS/BRZ ABS question DINOsaur51 Tracking / Autocross / HPDE / Drifting 4 11-07-2016 01:07 PM
Driver Seat Bolster Worn/ Fuel Pump Chirp QuagmireBRZ Issues | Warranty | Recalls / TSB 11 04-21-2016 12:18 AM
Seat bolster modification Roadstercycle Cosmetic Modification (Interior/Exterior/Lighting) 7 07-11-2012 07:47 PM
Potential New Owner Here declivity NY / NJ / CT / PA 4 06-27-2012 12:21 PM
