Old 06-29-2017, 10:59 AM   #15
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
But I already have a 2017?!
I hate this forum. Just full of trolls and you're killing the community. That's why no one is on this forum anymore.
You bought a 2017 and are already out of washer fluid?
If you put a full bottle in, its ~8.5lbs. Definitely not enough to produce noticeable oversteer.
BigTuna is offline   Reply With Quote
Old 06-29-2017, 11:02 AM   #16
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've had it since December.
I'm pretty sure that's more than enough.
Old 06-29-2017, 11:55 AM   #17
It's gotta be at least 10lbs of fluid at the very front of the car.
You obviously need to drive your car more if you can't feel it.
Better either full or empty than only half full.
If half full it will slosh around at every turn and could cause snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer,then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer,
Old 06-29-2017, 12:01 PM   #18
STV3
Señor Member
STV3's Avatar
I once switched to a heavier weight oil in my FRS and it caused massive understeer. I was plowing into every corner I took...
STV3 is offline   Reply With Quote
Old 06-29-2017, 12:54 PM   #19
Wait until you wear half the pads off your front brakes! Total chaos ensues.
Old 06-29-2017, 02:20 PM   #20
If half full it will slosh around at every turn and could cause snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer,............,
...... OK, lift the needle .......
Old 06-29-2017, 02:23 PM   #21
My washer fluid reservoir was empty for about 6 months, so I finally filled it and now my car over steers like crazy.
Did I throw off the weight balance from front to rear and have too much tread on my front tires from the lack of weight? Will rotating my tires fix this?
....... you should ALWAYS keep your car's fluids topped off ...... I don't care if you do live where it rains every day, all day long, for 11 months out of the year.
Old 06-29-2017, 02:27 PM   #22
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
SHHHH this thread was not meant for logic
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 06-29-2017, 02:40 PM   #23
Nor are many threads on this forum ......
Andrew025 (06-29-2017), yelsew (06-29-2017)
Old 06-29-2017, 02:47 PM   #24
Andrew025
Andrew025's Avatar
I usually fill the engine with enough oil that I can see it at the cap.
The Following User Says Thank You to Andrew025 For This Useful Post:
humfrz (06-29-2017)
Old 06-29-2017, 05:27 PM   #25
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
But I thought only Mustangs attacked people.......or could this also be the result of the washer fluid sloshing around???
IceFyre13th is offline   Reply With Quote
The Following User Says Thank You to IceFyre13th For This Useful Post:
Tcoat (06-29-2017)
Old 06-29-2017, 05:41 PM   #26
Clearly!
Old 06-29-2017, 06:10 PM   #27
Teseo
Drives: frs
Put coolant on washer fluid tank so cant evaporate in the meantime
Old 06-29-2017, 06:22 PM   #28
new2subaru
Weight Weenie
Drives: 15 FR-S
I can't believe you got away with that much weight off of the nose. It makes the car dangerously light on the front end!
I heard that's how this one went airborne. Talk to your dealer and read the damn manual!
The Following User Says Thank You to new2subaru For This Useful Post:
Tcoat (06-29-2017)
Washer fluid not spraying out btan219 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 09-16-2019 06:35 PM
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 07:12 PM
Window washer fluid light? husker741 Scion FR-S / Toyota 86 GT86 General Forum 14 10-20-2013 01:15 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 05:02 PM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 05:18 PM
