Old 07-02-2012, 09:16 AM   #1
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
GRD turbo system
Hi guys,
Im currently designing a turbo system for the 86 running a GTX3071R with a .63 Tial sports stainless v-band housing.
I am currently fiddling around with position of the turbo at the moment and just have a quick question to anyone out there thats removed headers.
Does anyone know the inside diameter of the exhaust ports? As my 86 is on order and my current donor car is being daily driven i cant remove the stock headers to measure it up.
Will be releasing a few teaser pics in the next few days depending on how long i can borrow my donor car for.
Thanks
Kal
jet86 is offline
Old 07-02-2012, 08:48 PM   #2
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Kal, hit Jason up from nameless performance. He would probably answer in a PM.
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline
Old 07-02-2012, 08:53 PM   #3
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
I already have, Im thinking of just going with 1.5" sch10.
jet86 is offline
Old 07-02-2012, 10:54 PM   #4
jedibow
How far away are you mounting the turbo? What are your end goals, max power, or maximum useable range?
jedibow is offline
Old 07-03-2012, 02:05 AM   #5
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
At the moment I am waiting for some cnc flanges, turbo will hopefully be mounted by next week. At this stage it will be running 7psi (standard 7psi spring in the turbo smart 40mm waste gate). Eventually once cp finishes their low comp pistons and haltech finishes their PNP ecu I hope to be running around 350-450hp.
It's actually the first horizontally opposed engine I've ever stuck a turbo on so it's a bi of a learning curve for me.
Kal
jet86 is offline
Old 07-03-2012, 02:49 AM   #6
Visconti
Drives: 05 STi
Kal
Haltech... for what?
Flash the factory computer!
Visconti is offline
Old 07-03-2012, 02:57 AM   #7
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
That is definitely an option but I'm going to see what haltech comes out with first. They have been good to me since I bought my first e11 off them and will continue to use them as much as I can.
Kal.
jet86 is offline
Old 07-03-2012, 07:00 AM   #8
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Eagerly awaiting some pics!
spiller is offline
Old 07-03-2012, 07:32 AM   #9
os86
Drives: 2jz
Kal.
I can recommend an awesome ECU, but it has limited support here in Australia.
however give Solaris a try. its Uk based
os86 is offline
Old 07-03-2012, 09:16 AM   #10
Visconti
Drives: 05 STi
Syvecs would be the best option if you were to go standalone
Visconti is offline
Old 07-03-2012, 09:54 AM   #11
os86
Drives: 2jz
Yeah that's what I meant. It used to be called solaris.
I had the Syvecs S6 full stand alone and highly recommend it.
Cheers
os86 is offline
Old 07-03-2012, 04:28 PM   #12
Visconti
Drives: 05 STi
Cheers
Been thinking about putting it on my Subaru .. Ryan is a good guy
Visconti is offline
Old 07-05-2012, 12:10 AM   #13
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Something commonly used on a Global scale for Subaru cars is the Vipec V44
Tradewind is offline
Old 07-05-2012, 01:42 AM   #14
jedibow
It sounds like you are after useable power?
So I would utilize small to medium size equal length primaries (4 into 1 with possibly one step to increase velocity to the snail) with a proper merge collector, and then mount the turbo 4 to 6 inches after the collector on the flange, looks like you will be running an oil pump also.
jedibow is offline
Security system: BRZ vs. FR-S Sport-Tech CANADA 16 05-30-2012 01:02 AM
Oil System? swift996 BRZ First-Gen (2012+) — General Topics 5 04-13-2012 09:44 PM
BRZ Navigation System Guaruja BRZ First-Gen (2012+) — General Topics 15 04-13-2012 08:52 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
