#757 |
StreetKart
Drives: 2014 Scion FR-S Monogram
is there any reasoning that my car would make a large number of output files? some are minutes long while others are only 4 frames of data?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#758 | |
Drives: FT86
Usually two reasons 1. Your using triggers and the trigger condition is being set on and off 2. The connection to obd port is not good and the communications keeps getting interrupted or power to unit is interruped Try bending the two rows of pins on tactrix inwards very slightly like 0.5 mm, try using an old full size SD memory card or similar so pins stay aligned |
#759 |
Drives: 86
Hi ..
Tactrix op2 log the ram from 0xFFF8000 TO 0XFFF8FFF DO YOU KNOW HOW TO READ OTHER AREA? |
#760 |
Drives: 2014 Dark Grey Metallic GT86
#761 |
Drives: 86
#762 | |
Drives: 2015 Scion FR-S ZN6
(Warning: loaded question ahead)
How do I go about making these corrections myself? The idle ignition timing tables for my ZA1JD00C are a bit messy; the same that we've seen for B01C and others. I tried using basic math (calculating the differences between start/end of tables and axes), but they seem to differ quite a bit between the various definition files. Any chance I could get some help on this? The definition file I'm using as a base for this is the latest from OFT. In the example below, I'm missing the X axis for the "Base Timing Idle (In-Gear)(Above Speed Threshold)" table. D00C ![]() 700C ![]() 3D Definition contains the coolant temp like it's supposed to, but the storage address is not defined, and it seems like the Y axis is incorrectly defined as well. 2D and 3D Definitions in D00C ![]() RomRaider with ZA1JD00C ![]() Quote:
#763 | |
Drives: FT86
Unless your prepared to learn how to reverse engineer the ecu code, its going to be much easier to just flash your D00C ecu with the B01C rom it will work fine and the defs for B01C are much better |
#764 |
Drives: 86
HERE YOU ARE
ZA1JF00C i dont know if i work or not Code: <table name="Base Timing Idle (In-Gear)(Above Speed Threshold)" storageaddress="118EFC"> <table type="X Axis" storageaddress="118ECC" /> <table type="Y Axis" storageaddress="118EF4" /> Code: <table type="3D" name="Base Timing Idle (In-Gear)(Above Speed Threshold)" category="Ignition Timing - Advance" storagetype="uint8" endian="big" sizex="10" sizey="2" userlevel="4"> <scaling units="Base Ignition Timing (degrees BTDC)" expression="(x*.3515625)-20" to_byte="(x+20)/.3515625" format="0.00" fineincrement=".2" coarseincrement="1" /> <table type="X Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8"> <scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" /> </table> <table type="Y Axis" name="Coolant Temperature" storagetype="float" endian="little" logparam="P2"> <scaling units="Degrees F" expression="x" to_byte="x" format="#" fineincrement="1" coarseincrement="5" /> </table> <description>This is the base timing in idle mode when vehicle speed is greater than the 'Base Timing Idle Vehicle Speed Threshold' and transmission is not in neutral.</description> |
#765 |
I actually am quite prepared! For the time being, I'll see about using the B01C. But if you could point me in the right direction, that would be awesome!
#766 | |
Drives: FT86
Best place for rom dissassembly help is the www.romraider.com forums Ask a guy called tdd he does a lot of dissassembly think hes a moderator on that forum , they hould be able to hook you up with the ida and instruction sets for the sh72531 processor our ecu uses, vood luck im sure those guys will apreciate people helping with dissassembly |
#767 | |
Unfortunately it did not! However, I got a little curious and, assuming the tables are the same size for each MAP, I used some basic 16-bit math to calculate the location of the table in my D00C def.
Here's what I came up with: Code:
</table>
![]() Quote:
#768 |
Drives: 86
This is what you looking for
#769 |
Drives: 86
#770 |
Drives: Toyota GT86
When we log "load", which load is it exactly?
Is it just MAF*60/rpm? Or is it the final load after all corrections are applied? Also, where does "load_abs" come from? Thanks!
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
