Old 06-19-2017, 03:11 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
STI JDM Short Shifter
Has anyone on the forum actually installed one of these? They don't seem to be very common since they're a JDM part. Was considering the Kartboy shifter until I read about all the buzzing and rattling issues. Thought this might be a better alternative, even though it's more expensive. Can't find much info on it other than it's physically 4mm shorter than stock though. Would love to hear some feedback from anyone who's actually used one.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
JDM4E (06-19-2017)
Old 06-19-2017, 07:44 PM   #2
jcw99
Drives: swp mt '14 brz premium
There's a member who lives in Italy that put one in about a year ago and he likes it better than the Kartboy that he had installed earlier. It's written up in a thread that mentions a lot of other JDM BRZ parts. I don't remember the member's name . You'll need to do a search.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
smg1138 (06-19-2017)
Old 06-19-2017, 07:57 PM   #3
jcw99
The member is Trap63. His post is Nov. 17, 2015.
The Following 3 Users Say Thank You to jcw99 For This Useful Post:
smg1138 (06-19-2017), Teseo (06-20-2017), Ultramaroon (06-20-2017)
Old 06-19-2017, 10:38 PM   #4
bhmax
Drives: 13 BRZ, 17 Focus RS
Not sure I have much good info, but I just installed mine and like it. However, I didn't come directly from stock to it. I liked the stock shifter, but just wished it had slightly shorter throws. I went to the IRP shifter for a bit and didn't like the amount of effort it required. Also, there was the noise issue that I mostly solved, but still persisted in 3rd gear especially. I'm enjoying the reduced effort going to the STI shifter. I think it costs more than it should, but the other options didn't appeal to me. I can't compare shift throw distance directly since I haven't had the stock installed for a while, but the stock was about 10-15mm longer throw (measured at the top of the knob on the pattern diagram) than my 05 WRX with a Perrin shift adapter installed. Now it's only about 2-3mm longer throw.
bhmax is offline   Reply With Quote
The Following 2 Users Say Thank You to bhmax For This Useful Post:
JohnJuan (08-15-2017), smg1138 (06-19-2017)
Old 06-19-2017, 11:28 PM   #5
tjohnson104
Drives: brz
I have one. I went from a trd usa short shifter to this. So it was a big improvement due to the known issues with the trd one. Right away, I was very satisfied and could tell the throws were very precise and smooth. Very minimal effort. I do not have any vibration noises or chattering at all. I would recommend this product, but as mentioned, it is pretty pricey for what it is... It would go great with a heavy shift knob. I use the sti duracon knob and that is very light weight. Stock knob would fell awesome or aftermarket heavy one.
tjohnson104 is offline   Reply With Quote
The Following 2 Users Say Thank You to tjohnson104 For This Useful Post:
Old 06-20-2017, 11:03 AM   #6
smg1138
smg1138's Avatar
Thanks for the replies on this. Sounds like this is a pretty good part. I guess my main question now is just how much shorter are the throws compared to the stock shifter? I know the Kartboy is advertised as being 28.5% shorter. Based on what I've been reading, would you guys say the STI is at least 20% shorter throws?
Old 06-20-2017, 11:46 AM   #7
bhmax
I'll measure again when I get a chance, but I think the throw is around 85mm measured on the top of the stock shift knob, from 3rd to 4th gear.
The Following User Says Thank You to bhmax For This Useful Post:
smg1138 (06-20-2017)
Old 06-21-2017, 07:15 AM   #8
jmark
Drives: '97 NSX-T, '18 Type R
Where can the STI part be bought? Does it increase the effort to shift?
jmark is offline   Reply With Quote
Old 06-21-2017, 09:23 AM   #9
bhmax
I got mine from japanparts.com. I can't give a great comparison on effort since I ran the IRP for a month or two. I guess theoretically it should be slightly higher, but I have the Mtec shift springs with it and am very happy with the shift feel.
Old 06-21-2017, 12:03 PM   #10
bhmax
Just measured again. Getting about 77mm on the sti shifter measured on the top of the stock knob from 3rd to 4th. Anyone have a stock shifter measurement?
Old 06-21-2017, 01:17 PM   #11
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Just measured my stock shifter, 3rd to 4th (2017 BRZ) -approx. 87mm
JSube is offline   Reply With Quote
The Following User Says Thank You to JSube For This Useful Post:
bhmax (06-21-2017)
Old 06-21-2017, 01:43 PM   #12
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
I have the JDM TRD, love it, slightly shorter throw then the JDM STI I believe as well.
Vides990 is offline   Reply With Quote
The Following User Says Thank You to Vides990 For This Useful Post:
bhmax (06-21-2017)
Old 06-21-2017, 02:54 PM   #13
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I believe the JDM TRD and JDM STI short shifters, like many parts in these cars, are identical and would be unprofitable/counter-intuitive for them to be different parts.
I have the JDM STI shifter with TRD shift knob (which also shortens another few mm, I think 2mm). I felt it could be shorter so I added the TRD USA short shifter bracket. Shifting requires a noticeable bit more effort but feels perfect now.
I haven't had issues with the TRD USA short shifter and made queries on this forum on why people have problems. Seems like the vocal few who have had problems either mis-installed (instructions are not that clear) or got a defective part (may have been revised). Seems like most owners who correctly install this part (I would say an overwhelming majority because TRD hasn't pulled this part off the shelves) have had no problems but they don't post so the problem gets blown up when only people with problems post on the forum.
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
bhmax (06-21-2017), Wally86 (04-26-2021)
Old 06-21-2017, 04:38 PM   #14
bhmax
Thanks, mind measuring what the STI plus USA TRD gives you for throw length for comparison?
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
cae ultra shifter vs short shifter jdmblood Engine, Exhaust, Transmission 22 01-14-2016 12:19 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
Wtb twm short shifter ikeryder13 Want-To-Buy Requests 1 05-18-2014 03:12 PM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
