#29 |
Drives: Stock
So I'm curious? In for an upgrade and I think I'm going ebc yellow stuff. Anybody tried them? Maybe also thinking of a rotor upgrade. Are the cheap slotted eBay rotors bad like Eline or power slot? Are they just as good a stock because they say oem spec in the descriptions? Anybody tried them?
#30 | |
Drives: '13 FRS - STX
Yellow Stuff have mixed reviews depending on your purpose, hardcore track usage they probably won't hold up. "spirited driving in the twisties" ( ) they might be fine if a little noisy and dusty. There's tons of reviews on them if you have the patience to google for them.
#31 | |
Drives: Stock
#32 |
Drives: 2014 GT86
As far as reliability goes blank > slotted > drilled > drilled and slotted. On track reliability matters so much more, so +1 to what strat61caster wrote, best bet would be blank disks, or not more then slotted ones. If you need more bite, better use more oriented track pads, then compromising reliability/upping chances of cracking under heavy abuse.
From not that cheap stuff there are also DBA disks. IIRC one could get even two piece ones of OE sizing. BTW, if you think of getting most out of OEM brakes, worth considering installing airducts. Extra cooling may help with increasing heat capacity of even stockers. For example something like Velox/Touge Factory/APR kits. |
#33 |
Drives: '15 BRZ RA
#34 | |
Drives: 2013 Subaru BRZ
Years ago I decided turning rotors was a waste of time and money. So I fit new rotors with new pads. Car makers agree. They now fit rotors that are designed to minimum safe weight intended for one set of pads. If you fit new pads to worn rotors you are wasting money and putting up with second rate brakes. Up to you, of course. |
| gc8 4 pot brakes | wholeeoh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 05-15-2022 05:38 PM |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 06:53 PM |
| Brakes for looks mostly | ofuts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 11-25-2014 05:52 PM |
| GT to GTS brakes? | Turdinator | AUSTRALIA | 30 | 01-12-2014 01:33 AM |
| OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 11:26 PM |
