Old 06-17-2017, 10:23 AM   #15
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Originally Posted by Gforce View Post
Most likely caused by the pads moving around slightly and touching the no wear ridges at the outer and inner limits of the pads as they wear the rotor. Modern asbestos free brake pads wear rotors quite aggressively. I note that the rotor surface rusts quite quickly if you do not drive regularly. That causes the rotors to wear a little faster then if you drive regularly. Rust can also make noise but only for the first brake application or two after the car has sat for a few days. Not likely your front brakes are worn out just yet even if you drive like a maniac, these are light cars with big front brakes for their size.
Rotors are designed to last only for about one set of pads with a bit of extra thickness to allow for variation in braking habits.
Seizing calipers make a knocking sound and you can feel the rotor runout through the brake pedal as well. It is unlikely your calipers are seizing at this young age.
I recommend you brake harder than you are accustomed to, at least a few times a month. This will help reduce brake noises
Very interesting, thanks so much!
Jfheisenberg is offline   Reply With Quote
Old 06-17-2017, 10:28 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Generally speaking many get through five sets of pads per disk. So worth to be more careful with stating such "truths".
The Following 5 Users Say Thank You to churchx For This Useful Post:
Cole (06-17-2017), gramicci101 (06-17-2017), soulreapersteve (06-18-2017), strat61caster (06-17-2017), x808drifter (06-17-2017)
Old 06-17-2017, 07:59 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Jfheisenberg View Post
But no budget for tires right now so thats gonna have to wait until next spring so i can do the wheels/tires and possibly brakes.
Unless you plan on putting another 30k miles on this year or starting to track/autox I doubt you'll need brakes next spring.
Brake fluid would probably be a good idea though.
ineedyourdiddly
Old 06-17-2017, 09:01 PM   #18
Jfheisenberg
did the brake fluid already at 29k. We'll see hows the budget for next spring, i might want to upgrade brakes and pads.
Old 06-17-2017, 11:38 PM   #19
Gforce
Drives: 2013 Subaru BRZ
B. S.
Gforce is offline   Reply With Quote
Old 06-18-2017, 01:39 AM   #20
The surface on cast rotors shows surface rust very quickly. That rust has zero effect on the wear or life of a rotor. None. Zip.
Rotors for some cars are indeed small and light enough they should be replace with each set of pads. Ours are not those. You should easily get 3 sets of pads or more out of a set during normal driving.
Cole (06-18-2017), navanodd (06-18-2017), nikitopo (06-19-2017), soulreapersteve (06-18-2017), strat61caster (06-18-2017)
Old 06-18-2017, 01:52 AM   #21
So took the car to AZP yesterday and they did not found anything abnormal. They took the car for a ride and they claim its just road noise. The only thing that they found is that my front tires pressure was set to over 50psi. I did not think of checking that before, but when i got my summer tires installed those idiots must have over fill the tire pressure.
Anyway, i do think the sound is not as bad as before (although i still need to drive the car a bit more), however AZP did also mentioned that my tires are starting to get 'road dry' meaning that i should start thinking on replacing my tires at some point. But no budget for tires right now so thats gonna have to wait until next spring so i can do the wheels/tires and possibly brakes.
Thanks for the update. So the original tech was full of shit.
Cole (06-18-2017), strat61caster (06-18-2017)
Old 06-18-2017, 06:06 AM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
B. S.
Excellent argument.
Cole (06-18-2017)
Old 06-18-2017, 12:14 PM   #23
Cole
Not a troll
Cole's Avatar
Excellent argument.
Yeah, well, stock suspension and alignment is best.
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
gramicci101 (06-18-2017), strat61caster (06-18-2017)
Old 06-18-2017, 12:20 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
Just add MCA kit in, and it's like F1 formulas.
The Following 3 Users Say Thank You to churchx For This Useful Post:
Cole (06-18-2017), gramicci101 (06-18-2017), strat61caster (06-18-2017)
Old 06-18-2017, 01:48 PM   #25
Ernest72
When a shop tells you to get tires, you should probably get them. AZP would not lead you in the wrong direction. Tires are all you got when it comes to grip. Old tire = unsafe.
Old 06-18-2017, 08:55 PM   #26
Gforce
Here's some actual expert information about disc wear:
https://textar-professional.com/brak...-service-life/
And some older advice given to brake service technicians:
http://www.tomorrowstechnician.com/t...ce-or-replace/
Old 06-18-2017, 08:59 PM   #27
Gforce
Not zero, obviously. If you're getting three sets of pads on one set of rotors you should trade your BRZ for a Prius.
Old 06-18-2017, 09:32 PM   #28
"For normal usage conditions, the design*life of the front wheel brake discs should be equivalent to the useful life of two sets of*corresponding brake pads. Some discs may have a shorter useful life, because they*have been designed to achieve specific targets."
NORMAL driving. That does not mean driving it as a Prius it means driving it as it should be on the public streets.
You said one I said 3 your own link puts it in the middle.
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 05:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 06:53 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 05:52 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 01:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
