Old 06-08-2017, 01:50 AM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Intec 3rd Brake light falling
Any suggestions for my Intec 3rd brake light falling off? I've attempted to re-use the stock double sided tape, and it eventually fell off again.
Replaced it with 3M Scotch doubled sided but it's starting to droop again. Even put some in other spots to help lift it but no help. Prepped service area with some invisible glass also so it's not sticking to random dust bits.
Taking suggestions. I've tried looking for other threads but I can't seem to find them again.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 06-08-2017, 08:15 AM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I had the same issue. Instead of only one strip of double sided tape in the rear, I added another to the front as well. No issues now even in Texas heat.
malubawla is offline   Reply With Quote
Old 06-08-2017, 08:32 AM   #3
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
https://www.amazon.com/3M-Tape-5952-.../dp/B01EOEW25S
This stuff can hold a spoiler on the trunk.
Old 06-08-2017, 09:28 AM   #4
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Use 3m adhesion promoter, and use alcohol to prepare the surface.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
zeal86 (06-09-2017)
Old 06-08-2017, 01:34 PM   #5
SmartedPanda
Did that didn't help, I put 3 small strips (size of a half dollar) on the front (towards the spoiler). California heat isn't as bad as Texas heat
Thanks! I'll try this, and probably some on my side skirt.
Hrm, didn't think of that, any negative effect on tint or glass?
Old 06-08-2017, 08:01 PM   #6
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
yeah i cleaned the window with alcohol and used my own 1" strips of 3m double sided tape
Old 06-08-2017, 09:09 PM   #7
thatfilipinoguy
No, shouldn't have a negative affect. I would also recommend prepping the surface of the high mount housing as well.
Old 06-08-2017, 09:13 PM   #8
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I've had this happen to me with the original 3m that was on the brake light. All I had to do was remove and replace the old 3m with any other stronger 3m and haven't had any problems yet. I live in CA too and probably have the same heat.
Instagram: trevor.parque
Old 06-08-2017, 09:56 PM   #9
Cole
Not a troll
Cole's Avatar
I fixed it by throwing mine in the trash and buying a CDC brake light.
Cole is offline   Reply With Quote
Old 06-09-2017, 12:37 PM   #10
thatfilipinoguy
I personally have the high mount brake light that they sell for mustangs, and it hasn't failed me yet. Plus, it was like $50!
Old 06-10-2017, 02:45 AM   #11
SmartedPanda
I'm using my own 3M, the original one fell off after a hot summer day.
Old 06-10-2017, 02:49 AM   #12
byun
byun's Avatar
Drives: 2015 BRZ CWP
I got the extra heavy duty 3m tape supposed to hold like 25lbs or something. Hasn't fallen since.
byun is offline   Reply With Quote
Old 06-14-2017, 06:27 PM   #13
BRZedsDeadBaby
BRZedsDeadBaby's Avatar
Drives: 14 BRZ
http://www.ft86club.com/forums/showp...1&postcount=62
BRZedsDeadBaby is offline   Reply With Quote
Old 06-16-2017, 12:03 PM   #14
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Originally Posted by BRZedsDeadBaby View Post
@geezerbrzeezer
Care to share more info/pics about your solution here?
Cockatoo is offline   Reply With Quote
Intec Exterior Items FRS/BRZ | Carbon Antenna, Rear Brake Light, etc. Kami Speed Exterior Parts - The Rest 43 09-06-2017 01:30 PM
***SOLD***INTEC high mount 3rd brake light Husker BRZ Interior Parts (Incl. Lighting) 9 04-07-2017 09:02 AM
FS: Intec 3rd Brake Light Jordan Silveira Interior Parts (Incl. Lighting) 4 11-21-2016 05:23 AM
