steve99
Old 05-16-2017, 10:38 PM   #589
steve99
Drives: FT86
Have a look in the first pist mate.
Dont log o2 volts log AFR
Log throttle not absolute throttle
Log load not absolute load, load will be number from 0 to 1.5 not a percentage
Old 05-16-2017, 10:42 PM   #590
allowe
allowe's Avatar
I did but I can't find maf volts or ol/cl
allowe is offline   Reply With Quote
Old 05-17-2017, 12:04 AM   #591
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by allowe View Post
What else should I select? This could help those who have the oft.
Looks like you are missing parameters if those are the only options you have.
Old 06-08-2017, 11:33 AM   #592
srscion
srscion's Avatar
Drives: 2016 FRS
Disable DTC code P0068 is not in the list
MAF Scaling - Open/Closed Loop Fueling info
MAF (mass Air Flow) Sensor Scaling - Open/closed loop Fuelling
Omni 2.5 Bar MAP
The OFT300 (Vortex supercharger) map uses the 2.5 BAR Omni and has CEL-P0068 disabled in the map
ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR
Manifold Pressure Sensor multiplier in bar per volt. = 0.500
Manifold pressure sensor offset. Value is measured in bar. = 0.100
MAP Sensor voltage max = 5.0v
MAP sensor Voltage min = 0.0v
Omni 3 Bar MAP Sensor (Metric in Bar)
0.617 - MULTIPLIER
0.03 - OFFSET
scaling limits 0 - 4.75v
Omni 4 Bar MAP Sensor
Manifold Pressure Sensor Scaling - (imperial PSI)
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
Manifold Pressure Sensor Limits - (CEL still comes on )
High Input CEL Above - 5.00v
Low Input CEL Below - 0.00v
Disable CEL P0103 and P0068
srscion is offline   Reply With Quote
Old 06-08-2017, 01:58 PM   #593
steve99
Drives: FT86
Hopefully it wont ever trip P0068 if min max values set and map scaling is good
Old 06-11-2017, 07:35 PM   #594
Tor
Tor's Avatar
Drives: Toyota GT86
Before doing a hopefully final attempt at scaling my MAF I want to do it right this time... So I have quite a few questions.
- Besides from zeroing out the IAT comp, I understand I should zero out the Load comp as well?
- Anything else that needs to be zeroed out?
- If I adjusted my AFR with OL fueling should I restore POL to "normal" values?
- Even with the IAT comp zeroed out, should I aim to find a day where I can get IAT's around 20 deg C?
Also, seeing that my car never reaches more than approx. 4.1v I would like to rescale the current MAF. What are good values to use for an NA car? 4.2v max for some headroom? And if using the tab that @Kodename47 contributed to Vgi's tool, what are good values for "Min V" and "Max Unchanged"?
Also, as I am tired of fuel trims jumping up and down I am considering if I should venture into injector scaling. Could injectors that are off cause LTFT swings? Given that the injector ratios are different in CL and OL?
I watched @jamesm's screencast and it was very helpful in understanding how to collect the data.
Am I understanding it correctly that to do so I should zero out all 3 "Total Injection Ratio Port" tables and do a CL MAF scale only?
I assume, that I shouldn't attempt to run at higher rpm for OL due to insufficient fuel from the direct injectors? Any other precaution that I need to follow (e.g. reduce timing)?
If correct, what is the process afterward to get the port injectors in line with the new direct injection MAF? I assume I should now set all 3 "Total Injection Ratio Port" tables to 100% and collect data as if I would do a CL MAF scaling again. @jamesm says to adjust the port injectors to the new direct injection MAF using Injection Flow Scaling ("BRZ" or the other one or both?) and Latency. How exactly is this done?
Thanks for bearing with all my questions once again!
Tor is offline   Reply With Quote
Old 06-11-2017, 11:19 PM   #595
srscion
srscion's Avatar
Drives: 2016 FRS
It happens and I have the correct values
Old 06-11-2017, 11:52 PM   #596
steve99
Drives: FT86
Try swapping MAP sensor, they are known to fail
Old 06-12-2017, 04:06 PM   #597
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Tor as you haven't changed the injectors doing the PI/DI separately is probably not worth the effort. The issue is that the DI fuel system runs at different pressures when fully used to when switched off so you can't tune it for just fully on or fully off. The PIs are also the limiting factor, not DI.
4.2/4.25v would work as the MaxV, I leave the OEM minimum and the min unchanged should be the lowest voltage you see.
As for zeroing things out, you could do the ELC but it's not necessary. You'll just reverse the normal compensations but they might make things more accurate as they are. You could also do the same or not for IATs. I now calculate a new ELC table using the same data as adjusting the MAF, kills 2 birds with one stone.
Also, if you're really that bothered about the MAF, set all your open loop fuel target to one value in the region of 12.5-13 and that way you're not chasing a changing fuel target.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-12-2017, 09:15 PM   #598
Tor
Tor's Avatar
Drives: Toyota GT86
Since my stock tune, I had issues with my LTFT. Especially with the stock injector ratios where at 5000 rpm port injection come back at 20%. This usually caused a huge split in LTFT once the ECU started learning (different tunes, different MAF scales).
Now I am running an adaptation of the K00C injector ratios with 20% port injection from 2000 rpm and have good flat AFR and a uniform LTFT throughout the rpm range. Only I'm annoyed that the LTFT is so inconsistent causing the AFR to swing up and down.
I am just wondering if the problem could be this:
Originally Posted by jamesm View Post
I actually apply this process even when tuning cars with stock fuel systems, because I've found the stock calibration to be imbalanced by as much as 10-15%, and at that point there is a drivability win associated with correcting it.
I should add my car runs great. It never ran smoother, I run a large amount of timing and it feels extremely powerful and willing. However, with LTFT up to +4.56, it runs in the low 11s or even slightly below. I suppose I could just ignore it and enjoy the way it drives but I am curious if there is a way to correct it. LTFT fell back to +3.76 during the last drive. It's almost as if it's responding to the way I drive too, lot's of WOT and the LTFT goes up. Drive like a grandpa and the LTFT falls back down. Could this be because it sits in different cells and with different injector ratios where the LTFT is set and again because the port and direct injectors are off of each other?
Back to the MAF:
The value in Vgi's tool is called max unchanged and is required to be above "Min V". If I set a value lower than 2.5 it produces weird results. It even created cells with negative voltages in some cases of low values. Could there be a bug in there? Or did Vgi make a wrong implementation somehow if it really should have been "min unchanged" and not "max"?
Do understand correctly that you mean I could leave the MAF as it is, and use a "MAF scaling log" to instead make adjustments to ELC? And that this would reduce the fuel trims in CL and hence make my LTFT in OL smaller?
You mean to do this for the MAF scaling only?
Thank you so much once again!
Old 06-13-2017, 03:52 PM   #599
Kodename47
Kodename47's Avatar
Drives: UK GT86
I tried to do the rescale from memory, just put an OEM scale into it and:
MaxV is the maximum voltage
Max Unchanged should be left as 2.5v
MinV is the lowest reading you see when running, or just below.
Is the AFR swinging even an issue? Could it be the result of something else? If it bothers you that much and you are always keeping an eye on it, you could just disable the LTFT..... If it's just LTFT is open loop then maybe adjust the fuel trim boundaries. I never found the reason why the split injectors caused odd LTFT at higher RPM
That is correct about the ELC, you could adjust that and see what happens. I use the same log to rescale the MAF and then adjust the ELC after.
Flat AFR targets, yes just for scaling. The leaner the better as the O2 sensor will be slightly more accurate.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-13-2017, 10:40 PM   #600
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks, from playing around with it, exactly like that seemed to give the most even spacing.
The only issue is that it's running richer than I intended (down to 11 when the LTFT are at their highest). Maybe it's not even a problem, I can't really feel a difference when the AFR is 11 or 11.5 and subjectively this feels like the best and most powerful I've had flashed so far. So to be honest I am starting to wonder if the performance difference is even measurable if making it leaner. Still for the learning experience and to satisfy my OCD tendencies I would like to continue and see if I can get it in control.
What would happen if I reduced "AF Learning #1 limits" from +/-40% to e.g. +/-2%? Would that mean I would never see LTFT beyond those limits? And would it pose a problem for CL operation or would it just apply more STFT as needed beyond the limits set, as required?
I assume "AF correction #3 limits" are the STFT? They are +/-50% so I assume this should be plenty to control AFR in all situations anyway?
I like the idea of the ECU still having some control of OL AFR, in case I am forced to use some other brand/quality of fuel than I usually do. If setting the limits as low as +/-2%, does it even still have a reasonable effect, or could I just as well disable LTFT all together?
This would probably be what I'll try next then. I like the idea of having that table based on my actual mods and not a generic stock table anyway.
Tactrix logs MAP as XX.XX to XXX.XX. Eg. low 22.68 or high 100.29 (tuning engine off). I can't figure the unit out. But it looks like I should just divide them with 100 to get bar (0.2268 and 1.0029 in the examples) to make it compatible with the ELC table?
Ok, then flash a tune with zeroed out ELC and IAT Comp and 12.3 OL in all rpm above load 0.9 to collect data to do it all in one go. I suppose it would be a good idea to reduce the timing a bit to avoid it knocking when doing pulls?
Thanks again!
Old 06-14-2017, 12:10 PM   #601
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you take a little timing out, you could run AFRs of 13:1 no issue. AFRs of 11.0:1 compared to 11.5:1 is likely to cost you a few HP max. If 11.0:0 allows you to run more timing advance, you'll make better power than 11.5:0 with less timing.
Have a look here:
[ame="https://www.youtube.com/watch?v=Zzn3-ygH-v8"]Haltech Technically Speaking: Ignition Timing vs Air Fuel Ratio - YouTube[/ame]
You could reduce the LTFT range, not sure whether it works or not but could be worth a shot. STFT will still operate as normal so no issues in CL. AF #3 is compensations from the rear O2 and are separate from the LTFT/STFT.
Sounds like the pressure is in kPa, so dividing it by 100 would give Bar. Just make sure you have MAP/MRP correct depending on what you're logging (looks to be MAP) and the defined x axis on the ELC table. I wouldn't bother zeroing it out, you've probably got a better starting point from it with the OEM settings.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-14-2017, 01:17 PM   #602
Tor
Tor's Avatar
Drives: Toyota GT86
Have a look here:
Thanks for the link. The Honda K20 even has a lot lower compression ratio, so would it be reasonable to assume that the range he mentions of 11-13 would probably even be lower for our engines?
The ELC unit says "Manifold Abs Pressure (Bar)". I assume the logs are Absolute too (MAP)?
Ok, I'll leave the stock compensation in there then. I think I will convert and use the Euro MY17 K00G tables and use their values. Since it's the same header and manifold, they must have had a plan with the changes.
If the above doesn't help I'll look into either disabling or lowering the limits of LTFT or live with it as it turns out.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 09:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
