Old 06-11-2017, 05:30 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
How long does your battery last?
My battery just died last week 42000 miles.
Changed to Duralast
http://www.autozone.com/batteries-st.../4474_929283_0
What about you guys?
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
Clipdat (06-12-2017)
Old 06-11-2017, 05:33 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
My battery died after approximately 4,500miles. The new one replaced under warranty is now about 2,500miles in, and seems to be stronger, holding its charge longer.
The Following User Says Thank You to JD001 For This Useful Post:
FR-Sky (06-12-2017)
Old 06-11-2017, 06:47 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
My battery died after 2500 miles, but it was my fault. I left a device on the car that drained it and afterwards it was completely dead. I am using now a Yuasa battery which is based on a more advanced Ca/Ca VRLA (deep cycle) technology. Additionally, it is 30% lighter. A month ago I forgot the car's internal light on and saw it the next day! The battery could crank up the engine without issues and could be recharged full.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
FR-Sky (06-12-2017), why? (10-01-2019)
Old 06-11-2017, 12:48 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Car batteries don't care how many miles are on them. Time, vibration, heat and cycling kill batteries.
-In the north I'd change out batteries regularly that were 6+ years old. Here in FL, 3+ is normal. Heat kills batteries.
-if you have vibrations in your car or drive regularly on a rough road or don't have the battery properly tied down, you'll get less life from your battery. So if you have modified your car and have more NVH, you're reducing the life span of your battery. Catless exhaust, solid engine mounts, hard trnsmission bushings etc all lead to shorter battery life. If you have modified your car and have more NVH, use an AGM battery. They also deal with cycling a lot better.
-cycling is when you run the battery voltage down (like for ex leaving a light on too long) and have to recharge it. If you don't recharge properly- on a dedicated battery charger and disconnected from the car- you'll kill the battery that much faster. If you just run the car and recharge the battery with the alternator not only is it bad for the battery but it's bad for the alternator too. Abuse is the #2 battery killer. Time is #1.
guybo is offline   Reply With Quote
The Following 5 Users Say Thank You to guybo For This Useful Post:
avishenoy1 (06-26-2017), Clipdat (06-12-2017), FRSapex (02-07-2019), Gforce (06-11-2017), humfrz (06-11-2017)
Old 06-11-2017, 12:52 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly! A dedicated battery charger is needed in such cases.
guybo (06-11-2017), mikko86 (06-11-2017)
Old 06-11-2017, 03:33 PM   #6
It's been 4 years for the OEM battery in my FR-S, and it still starts the car just fine.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Clipdat (06-12-2017), FR-Sky (06-12-2017), Scrappydoo (06-11-2017)
Old 06-11-2017, 05:17 PM   #7
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
You need to start a separate thread
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
nikitopo (06-12-2017)
Old 06-11-2017, 11:47 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
My OEM Panasonic battery lasted a little over 3 years. Near the end of the life cycle, the car sounded like it struggled to start (extra second to turn over). It's pretty scary to hear in a push to start car because you can't really force a car to keep cranking like with a key.
I switched to a O'Reilly Super Start Extreme. I was debating against the Duralast Gold, but the Super Start Extreme had a 20 dollar rebate. Though, the next time I need a battery I'll go to Costco and get an Interstate. 42 Month free replacement compared to Duralast Gold or Super Start Extreme with both Max out at 36 months.
Plus, the Interstates at Costco are about 80 bucks each, compared to 140.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
FR-Sky (06-12-2017)
Old 06-11-2017, 11:50 PM   #9
Gforce
Drives: 2013 Subaru BRZ
Changed to Duralast
Subaru specs an undersized battery in the manual shift cars.
Always fit the automatic transmission version as a replacement, it's bigger.
And yes, cold does not kill batteries, heat cycling kills batteries. Deep discharging is very bad for car batteries because it increases heat stress.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
FR-Sky (06-12-2017)
Old 06-12-2017, 02:11 AM   #10
qqzj
Drives: MDX, Camry
Do you happen to the size groups for both manual and auto cars? If we want to upgrade to AGM batteries, which one is the best choice? Thanks.
qqzj is offline   Reply With Quote
Old 06-12-2017, 02:48 AM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Echoing this. Got my car in the first week of December, 2012 - battery still cranking the car nice and strong middle of June 2017 @ 19k miles.
Originally Posted by humfrz
I'm old and lazy
Old 06-12-2017, 04:10 AM   #12
FR-Sky
FR-Sky's Avatar
Yea, I was debating too. The guy offered me duralast gold for 5 years warrenty. But I didnt think I needed that haha.
Old 06-12-2017, 10:25 AM   #13
Gforce
This thread is about battery specs:
http://www.ft86club.com/forums/showthread.php?t=5990
Old 06-12-2017, 11:28 AM   #14
surfwaxsmitty
Drives: '14 BRZ 6MT
Manual transmission, battery lasted until about 37k and about 3 years. Down in a hot climate. Didn't expect much better.
Replaced with a costco interstate brand. Their batteries have always done fine for me. Good price, good specs, with easy 3 year free replacement.
surfwaxsmitty is offline   Reply With Quote
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 10:58 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
