Old 06-08-2017, 03:02 PM   #1
execute1902
Drives: 2014 BRZ
Replacement camshaft sensor plug?
Hello everyone, I have been lurking through these forums for the 9 months I have owned my 2014 BRZ and I appreciate all the information out there that this wonderful place has provided. There is one issue I could not find and look for your help to better understand what exactly I am looking for, if you could...
A few weeks ago I had a small fire that started due to a bird building a nest within two days, and the heat of the engine igniting the nest. This fire took place near my camshaft sensor (B- passenger side) and it burned the insulation off of the wiring to the camshaft. The three wires had their copper touching which I didn't realize until I got home to inspect the damage further. I wrapped each wire with electrical tape to prevent them from touching and then put the wires in heat resistant loom. I had a check engine light which I pulled codes P0365 P0366 and lastly P0013. My first thought was that the camshaft sensor itself was damaged so I replaced the part, and the CEL went off for 10 seconds, but quickly returned and now I am at a stump. I only figure I could repair the wiring harness further and replace the plugs, as the current plugs are still very damaged(without the clip) I attached multiple picture if you could offer your assistance and knowledge to point me in the right direction I would be very appreciative. Thank you for your time and help!
Pictures of wiring harness and codes: https://imgur.com/gallery/pZFoJ
execute1902 is offline   Reply With Quote
Old 06-08-2017, 04:05 PM   #2
steve99
Drives: FT86
See attached wiring diagram
Page 103 shows Camshaft position sensors.
Check continuity of the red and blue/red wires to other cam sensors.
Check continuity of wire to Connector AC-1 in engine bay see page 46 and 400
Old 06-08-2017, 08:10 PM   #3
execute1902
Drives: 2014 BRZ
Thank you for your response Steve, but I am not sure if that is what I am looking for, and if it is I apologize.
What I am wanting to do, basically, is to cut the current plug and re-attach a non burnt plug end, so it will click into the new oem camshaft position sensor. I am just not sure the name of the plug in question, or if it is even possible to buy one beside a junk yard cutting one off of a vehicle. Nonetheless thank you for your time
Old 06-08-2017, 08:28 PM   #4
execute1902
Drives: 2014 BRZ
Sorry I see now what you were saying, I am at work at has a lot going on when I read that. I will ensure continuity of the wire when I get off, I appreciate the response. Still though if some one knows the name of the plug or a part number to replace the piece that actually connects to the camshaft position sensor it would be greatly appreciated
Old 06-09-2017, 02:52 AM   #5
steve99
Drives: FT86
Unfortunatly toyota probably doent sell the plug as a separate part, you might have to buy the entire loom section. Maybe see if you can get one from a wrecked car
Spark Plug Replacement Dacfrs Rocky Mountains / Great Plains 4 03-21-2017 01:16 AM
FS: o2 sensor extension harness, o2 bung with plug, o2 spacer B-R-Z Engine, Exhaust, Bolt-Ons 1 11-29-2014 03:44 PM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 03:54 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 05:04 PM
Is there a Direct Fit Map Sensor replacement sw20kosh Forced Induction 10 07-04-2013 09:21 AM
