#141 | |
Drives: 2013 Subaru BRZ
Clutch type LSD react only to wheel speed, that's how they engage. Torsen do not react to wheelspeed, ever, not in any way. Torsen do not wear when biasing torque although it is tempting to think that they must due to the internal friction. Friction reduces wear if of it is static friction, which it generally is inside a Torsen. Only sliding friction causes wear and there is very little of that when a Torsen is biasing torque and not very much when it is differentiating. But, I concede it is difficult to understand how this ingenious device actually works. Thinking it gives progressive limited slip is the biggest misconception and affects how you drive these cars. You either know, or you don't. |
#142 | |
I also point out that the space saver spare, of any size, would be completely worn out and down to the belts long before the slightest wear could have occurred inside the Torsen. Clutch type LSD use a centrifugally activated clamping system of clutch plates, which is why electronically controlling these is preferred. Edit, the clamping system relies on the wedging action of the spider gears or of the spider drive pin in a shaped slot. The effect is as if centrifugal force pushes the side gears apart. Wave type use interlocking circular ramps to achieve the same effect, again as if there is centrifugal force pushing the side gears against the clutch plates. These wave type are speed sensitive in that there must be a faster moving axle to activate the clutch plates. These LSD are only wheelspeed sensitive and do not engage unless a difference in wheelspeed is experienced. They react to that. They do not limit slip until a preset wheelspeed difference is achieved. Then they lock pretty firmly and any differentiation results in wear and heat. Edit. Clutch type spin up one wheel as they lock. Torsen never do. Clutch type LSD "bias torque" by braking the spinning wheel against the wheel with grip. This is why electronic systems for limiting slip operate just like a clutch type LSD until both drive wheels lose grip. Torsen do not do this and cannot do this. Most of the heat inside a open differential comes from the gear speed, nothing to do with limiting slip. Clutch type LSD heat up because they must allow the clutches to slip to permit differentiation. Torsen do not. Torsen bias torque immediately and are not delayed by waiting for the lower grip wheel to turn more quickly. They react to the torque that the wheel with less grip can actually handle. Clutch type only react to wheelspin. Like haldex, they limit slip but only when there's slip to limit. Torsen do not limit slip, and cannot. They transfer torque away from the tire that might slip but only do so until it does slip. This is the complete opposite of the clutch types. And Torsen do not wear when they are biasing torque. On the contrary, they simply differentiate as would an open differential while transferring torque. Friction does not necessarily cause wear. Only sliding friction can cause wear and not much sliding goes on inside a Torsen when it is biasing torque. Last edited by Gforce; 06-08-2017 at 09:48 PM. |
#143 | ||||||||||
Drives: '23 BRZ
Clutch type will have some breakaway torque, so it's already locked to some degree before anything even happens. The clutch type then locks up more with applied torque. Even a "plain" clutch-type without ramps does this due to the spider gears being forced apart harder with increased torque at the carrier, which increases clamping force on the clutch pack. A Salisbury clutch type will do this to a greater degree and is tunable with ramp angles. So without any wheel motion (in unison or differential), the clutch-type already has some lock, and with torque applied it has even more lock. Clutch type does not rely on wheelspeed to apply bias or lock! Quote:
However I think the whole idea of the "TORque SENsing" Torsen is that it acts open when no torque is applied, and applies increasing lock or bias with greater applied torque. So when you're accelerating while cornering the diff can be both differentiating and biasing. So there is sliding friction while under load. Which generates heat and causes wear. Granted this wear may be slow enough that the diff doesn't wear out within the design lifetime of the vehicle. Anyway, that's been my understanding of it... Quote:
There will generally be some breakaway torque which gives some lock or bias right off the bat. Then you get increased clamping with increased *applied torque*. Wheelspeed has nothing to do with it! Quote:
AGain, viscous and gerotor types *are* activated by differential wheelspeed, but definitely NOT the clutch type, whether "plain" or Salisbury. Quote:
![]() Again, it may last the life of the vehicle but wear and heat do occur under load when there are different output speeds., Last edited by ZDan; 06-08-2017 at 09:08 PM. |
| The Following User Says Thank You to ZDan For This Useful Post: | WRBrzRX (06-09-2017) |
#144 |
Got it.
Torsen never locks up but it also biases torque immediately. The torque bias line is straight. Clutch type torque transfer line has two slopes, shallow until lock up and steep after lockup. We have the same understanding of the differences, at least I think we do. We differ about the friction and heat aspects. Torsen themselves, and Quaife, and Eaton all claim no internal wear occurs when their diffs are operating. The key is to appreciate just how little gear tooth sliding is actually going on and anynthat us occurs at low face loads and low speeds. The hypoid bevel pinion gear is making much more heat, has very high tooth loads and a lot of continuous gear face sliding. There's nothing going on in the differential gears of a Torsen that can come close to the heat loading delivered by the pinion engaging and driving the crown gear. We may have to just agree to disagree on this point about different tire sizes presenting an unusual wear risk to the Torsen type diff. If the manufacturers of the devices themselves do not warn against this that is conclusive enough for me. As I have previously said, there is nothing going on inside a Torsen that can generate significant additional heat from either differentiating or torque biasing. That is not true of clutch type which generate a lot of heat until they actually lock, at ehich time they can no longer differentiate. Viscous couplings, which are speed sensitive as you say, can quickly be damaged by forced differentiation. However, generally speaking other components first bear the brunt of a heated up viscous coupling because they can cease differentiating, one of the main drawbacks. Eventually the heat buckles the drive plates inside the coupling. |
#145 | |
#146 | |
Clearly I am referring to the makers of the diffs in this post. |
#147 | |
Drives: '23 BRZ
Torque bias of a clutch type starts at a positive value because of the breakaway torque. How much steeper it gets is dependent on tunable factors like ramp angle, active clutch plates, and in the case of the OS Giken I got for the FD, preload springs. I had mine specifically tuned to have minimal breakaway torque and a shallow slope to avoid rapidly increasing lockup with torque. |
#148 |
I think it's worth one more try at making my point.
Torsen will not torque bias just because one wheel is smaller. It does not and cannot torque bias just because one wheel turns faster then the other. It just differentiates. If traction differs left to right it doesn't matter what size wheels are fitted the Torsen will bias torque in exactly the same way as it would if the wheels were the same size. I mean this is just the physics of how they work. Clutch type using preload springs always wear the clutch plates a little if only because they are preloaded. Non pre loaded disc type LSD shouldn't care if the rear wheel sizes are different either. |
#149 |
Your denying that they are torsens does not make that fact. The best example was the Civic Si which does indeed have a torsen. I don't suppose you even bothered to look at the list I linked for you since you just "know".
#150 | |
#151 | |
Drives: '23 BRZ
Torsens DO slip, if they didn't they wouldn't be in OEM applications. The whole idea is that they slip and act like an open diff under low load, and progressively lock up with applied torque. |
#152 | |
So, yes, technically Torsen "slip" but that misuses the word slip. Torsen always differentiate, they do not lock. However, if the wheel with less grip still grips then the Torsen "locks" completely, transferring all the "spare" torque. Torque transfer is immediate. They are not progressive, they bias torque at a fixed ratio all of the time. Torsen are unaffected by different wheel sizes. Completely unaffected. |
#153 |
Helical and Torsen are not the same. Don't you ever get tired of constantly being wrong?
| The Following User Says Thank You to Gforce For This Useful Post: | johan (06-09-2017) |
#154 | ||||
Drives: '23 BRZ
| loose rear-seat latches | hyperpunx | Issues | Warranty | Recalls / TSB | 34 | 02-22-2017 06:19 PM |
| what bushing should i get for better handling | nearvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-15-2014 05:26 PM |
| Outside Rear View Mirror Housing Loose | tonytduc | Issues | Warranty | Recalls / TSB | 3 | 10-01-2014 04:20 PM |
| Help! Trd rear bumper loose :( | FaNtaSy | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-25-2013 09:01 AM |
| Best handling car? | gt8613 | FR-S / BRZ vs.... | 154 | 10-07-2013 10:57 PM |
