CANADA Canada
Old 06-03-2017, 03:18 PM   #1
Dragon780
Drives: Scion FRS
Can I recharge a non dead battery
Hi guys,
Since last winter when my battery was dead for a week since I didn't turn it on
After I recharged it it still seems kinda weak at times.
Is it ideal to charge it when it's not dead and what kind of charging method if any should I use
Thanks guys
Dragon780 is offline   Reply With Quote
Old 06-03-2017, 03:26 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Remove from the car and stick it on a trickle charge using a good quality battery charger/conditioner. It takes a battery through various cycles to charge it properly.
The Following User Says Thank You to JD001 For This Useful Post:
guybo (06-03-2017)
Old 06-05-2017, 05:06 PM   #3
dcfr
dcfr's Avatar
Drives: Ultramarine FR-S
Mine was dead too last winter and I used the NORCO battery charger from CT and back in action again after 2 recharge cycle each 8 hours long.
dcfr is offline   Reply With Quote
Old 06-05-2017, 05:12 PM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Dragon780 View Post
Hi guys,
Thanks guys
I would suggest to buy a new one.
Old 06-05-2017, 07:03 PM   #5
ls1ac
ls1ac's Avatar
If you let a normal car battery (lead acid) fully did charge, it will never charge to full capacity. It will often have full voltage but not the amp-hr of a new battery.
Often it will work in good conditions but in the dead of winter it will fail when you need it most. ie. leaving work at 7pm when it has started to snow and you are expected home.
You could find someone with a load tester to find out its current state. Some auto parts stores will do it for free.
Old 06-05-2017, 08:36 PM   #6
cjny
Drives: 2016 BRZ
Lead acid batteries do not react well to being fully discharged, especially if it sits around fully discharged for any length of time. You have probably damaged your battery, diminishing its capacity. There's probably no way to fix it.
cjny is offline   Reply With Quote
Old 06-05-2017, 11:33 PM   #7
Dragon780
Drives: Scion FRS
Ya cause sometimes when I turn my car on
My left light like blinks then turns on and just started not long ago
And if I were to get a new battery
What type of battery is of better quality
Old 06-24-2017, 02:34 AM   #8
Andr3w
Andr3w's Avatar
Drives: Corolla
I had the same issue last weekend when I took my car out of storage after being parked for 6 months in the cold.
Did a jump, and tried charging it with another car for 15 minutes. After doing some reading online, I decided to replace it. From what I gathered, completely discharging a lead battery ruins it and it will never retain the same capacity as it was before.
There are some batteries that allow for deep cycling, which from my understanding means you can run through a sequence of charging and discharging to return the battery to original state.
Then there's the option of going with a light weight battery for weight saving because race car. However, those tend to have a smaller capacity (less material, different material? I don't know) and require frequent driving to keep the battery running.
In the end I went with a Kirkland battery from costco. From what I read, the supplier for the Kirkland brand is actually a really well known battery manufacturer that also produces the AGM Exide batteries. Don't quote me on that. Brand name or not, the warranty was too good to pass up on. For $105+tax vs oem honda $170+tax, the costco battery has a free replacement for the first 3 years, then each year after the initial 3 years has a reduced % of refund.
Edit: lesson learned - start up car occasionally to keep battery alive or use a trickle charger.
"Initial D and chill?"
Andr3w is offline   Reply With Quote
Old 06-24-2017, 06:15 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
Starting a car occasionally during storage does not help. As each time you start the car it drains the battery then leaving idling for a period won't allow enough charge therefore it's best that the battery is connected to a trickle charger as this will keep the battery in a healthy condition.
The Following 4 Users Say Thank You to JD001 For This Useful Post:
Andr3w (06-24-2017), cjny (06-25-2017), nikitopo (06-24-2017), Ultramaroon (06-24-2017)
Old 06-29-2017, 12:47 PM   #10
Gforce
Drives: 2013 Subaru BRZ
The battery fitted to manual transmission BRZ is too small for our conditions. At the first sign of trouble fit the larger size that is specified for the automatic transmission cars. Or even bigger if you can find a bigger one that will fit.
Gforce is offline   Reply With Quote
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 05:17 PM
Car WON'T START dead battery? AnthonyArcaro Issues | Warranty | Recalls / TSB 17 01-19-2016 01:00 AM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 10:58 AM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 02:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 05:06 PM
