Old 06-02-2017, 10:17 PM   #113
DarkSunrise
DarkSunrise's Avatar
No time associated with the CR article, and the only thing I can find on the Sport Auto test is the forum post here which has zero information like if the compared laps were even done on the same day so as far as I'm concerned bunk, sorry. Unless I'm missing something?
Don't get me wrong, I don't doubt >1s can be gained with a tire swap to a streetable tire, my MPSS are about 2s slower than my RE71R's around a 40-50s autox course without changing anything else.
The thing I doubt is "oh the Miata does so well because the Primacy's are shit *priustyrememes* and the Bridgestone were on the LFA so they must be great"
The CR article wasn't a laptime test, just objective handling tests. The improvement was significant, 2.6 mph faster in the double lane change (CR record) and 9 ft shorter in braking (2nd best ever). That's just from a tire change. Also I wouldn't be so quick to dismiss the Sport Auto track test for possibly being on different days. We don't know that for sure and regardless that'd invalidate pretty much every major track comparison there's ever been (or time attack for that matter).
Anyway enough bench racing for me. There's no way to tell how much faster the Potenza S001's would be (if at all) until someone actually tests it, and the 86 already set a faster laptime than the RF so it doesn't even really matter in this case. I just think Toyota/Subaru offering a set of max performance summer tires would satisfy a lot of people's curiosity whether they think it'd make a difference or not.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Capt Spaulding (10-06-2017), DAEMANO (06-11-2017)
Old 06-02-2017, 10:30 PM   #114
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I mean... we have that test, it was worth 0.2s on Streets of Willow...
ineedyourdiddly
Old 06-02-2017, 10:52 PM   #115
DarkSunrise
Or 2 seconds depending on test I guess what I'm saying is if it was an OEM factory option we'd have many more data points (i.e., comparison tests) to draw from and probably argue about lol.
2022 BRZ Build
2013 FR-S Build
Old 06-02-2017, 11:02 PM   #116
strat61caster
Hehe on a track on the other side of the world with no knowledge of conditions differences between tests? Come on, you know that's not any better than my anecdotal estimate of 1s between Primacy and MPSS.
ineedyourdiddly
Old 06-02-2017, 11:12 PM   #117
DarkSunrise
If Sport Auto had a reputation for botching lap times I'd be inclined to dismiss the results but I haven't seen any odd results from any of their other track tests. Actually it seems their Nurburgring lap times are widely accepted even by OEM manufacturers.
2022 BRZ Build
2013 FR-S Build
Old 06-02-2017, 11:14 PM   #118
strat61caster
If Sport Auto had a reputation for botching lap times I'd be inclined to dismiss the results but I haven't seen any odd results from any of their other track tests. Actually it seems their Nurburgring lap times are widely accepted even by OEM manufacters.
You hold on to your two seconds then, whatever helps you sleep at night.
Wish I could have gotten two seconds out of switching to Max Performance summers over an 80s course with a bunch of straightaways, even my ZIISS weren't giving me that much over a ~50s autox. Which is consistent with R&T's experience on ZISS giving them 2s over 90s course...
ineedyourdiddly
Old 06-02-2017, 11:44 PM   #119
DarkSunrise
Haha I sleep just fine thanks I'm agnostic at best on this. If it's 0.2 sec faster or 2 seconds faster or somewhere in between, it doesn't really matter to me. It just seems disingenuous to accept the 0.2 sec result as gospel and wholly ignore the 2 sec result without explicit reason.
2022 BRZ Build
2013 FR-S Build
Old 06-03-2017, 12:17 AM   #120
strat61caster
The explicit reason is that that level of speed differential is as good as what R&T and my personal experience garnered on a 200TW Extreme performance summer and Auto Sport made no claims that the two tires were tested back to back.
Hell, there's >3s between the BRZ Primacy/S004/RE11A video and the 86 vs MX-5 RF video on the same track with the same tires with the same driver. The '17 86 on Primacy was faster than the '14 BRZ on RE-11A's. I think we'd both agree that on the same day the '14 BRZ with RE11A's would be faster.
Sorry I just don't believe that a Max Performance Summer tire (~300TW) is worth 2s over a ~90s course when tested back to back with the Primacy and it's counter to everything I've figured out about tires. I know it's irrelevant but you know how it is.
Wish I had gotten video of my fast session at Laguna with the Primacy to compare to my ZIISS The only video I have is me being held up by a lot of pretty cars driven slowly and like 1 clean lap which is like 2:03
ineedyourdiddly
Old 06-03-2017, 12:57 PM   #121
DarkSunrise
That's a results-driven elimination process based on two other data points (one of which is yourself on a different class of tire and extrapolating from that result) I'm all for eliminating outliers but there simply isn't enough hard data for that just yet.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
strat61caster (06-04-2017)
Old 06-03-2017, 06:18 PM   #122
Celica00
Celica00's Avatar
Drives: 86
I built both of these cars on their respective websites and made them similarly optioned out. The difference was the Miata being around $7500 more expensive. Even if the Miata is better, is it really $7500 better? That's a big hang up for me.
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
Tcoat (06-05-2017)
Old 06-03-2017, 08:13 PM   #123
fatoni
How much was the power retractable roof on the brz?
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
Old 06-04-2017, 12:30 AM   #124
Celica00
Celica00's Avatar
Drives: 86
What?
Old 06-04-2017, 12:38 AM   #125
StraightOuttaCanadaEh
Wes
I always thought the miata was a cheap car and I remember when I found out how much it cost and thought to myself how I would never pay that money for it.
Old 06-04-2017, 11:24 AM   #126
Gforce
Drives: 2013 Subaru BRZ
What?
Exactly, I'm pretty sure you cannot "similarly option out" these two cars. I know which one I'd rather be found upside down in. In my BRZ it would be an EMT with a useful ride. In the MX5 it would be a different time if professional entirely with a vehicle not useful to me.
Gforce is offline   Reply With Quote
OEM BRZ Head Unit tofurun Audio/Visual, Electronics, Infotainment, NAV 11 08-08-2016 10:28 PM
WTB OEM head lights raven1231 Want-To-Buy Requests 5 08-07-2015 04:38 AM
BRZ head lights -> JDM 86 head light conversion BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 6 08-02-2013 11:47 AM
Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) M-17 FR-S / BRZ vs.... 96 03-05-2013 03:40 PM
Motortrend Head 2 Head: MX5 vs FRS jenzan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 03-01-2013 11:59 AM
