Old 05-31-2017, 01:57 PM   #1
Gumberculies
Drives: 2016 BRZ Limited
Quick Question Regarding Problems that might arise with UEL Headers
Hello everyone,
I know there are other threads about these problems, but none of them really seem to answer the questions I have.
My brz is currently at the dealership and I'm being told that installing my UEL header has voided my warranty. This is w/e to me, but I want to make sure that the issue I'm experiencing is indeed being caused by the UEL header or not. If it's not I may try to argue the warranty bit, but seeing as my OFT apparently failed to flash my ECU back to stock (even though it said it was successful) I don't think it will really matter. More details are bellow.
The only mods I currently have on my vehicle are a JDL Catless UEL header and an Invidia N1 catback exhaust.
The issue I'm having is the P000B fault code with my CEL and SL on. I'm also occasionally experiencing rough idles, and extremely rarely having the car stall when pushing the clutch in. The code for this has only appeared twice, the P000B code is consistantly on. even if I clear the fault code, it will pop back up within 5-30 minutes of driving. This has happened on both the Stage 2 UEL 93 Oct tune from OFT and with the stock ECU tune. I flashed the stock tune back onto the car before taking it to the dealership, but after speaking with the dealership they said the ignition count ( I think that's what he said, was a little hard to hear) had a value of 20 stored and that that isn't stock .
I checked for exhaust leaks after installing the header and used new gaskets to install. Torqued everything down to the proper spec and didn't notice any leaks at the time.
I started seeing this issue after I had the headers on my vehicle for about 6 days. Was on my way to do a dyno pull when I started experiencing the issues.
So can anyone say one way or another whether or not this UEL header I installed is actually causing these issues?
Gumberculies is offline   Reply With Quote
Old 05-31-2017, 05:02 PM   #2
Gumberculies
Please Ignore this Question. It was moved to another tread.
Old 05-31-2017, 05:34 PM   #3
steve99
Drives: FT86
Originally Posted by Gumberculies View Post
Hello everyone,
the header wont cause cam codes like P000B.
however the dealer will blame aftermarket parts and/or tune.
Cam issues are difficult to resolve and involve replacement of many expensive parts and labour including ECU.
Best to return vehicle to completely stock with stock tune and unmarry your oft.
Then take back to dealer or different dealer.
Jayhoang's Black Swan: Arise Sport x Voltex jayhoang Member's Car Journals 149 07-20-2017 07:54 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
Quick question regarding aftermarket headers in Washington state Rafiee Northwest 22 06-04-2016 05:36 AM
Quick question Carnewbee Scion FR-S / Toyota 86 GT86 General Forum 28 10-12-2015 01:55 PM
Transmision Problems Question kombatlion Engine, Exhaust, Transmission 4 05-14-2014 12:59 PM
