Old 07-02-2012, 01:29 PM   #71
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Detonation is most likely to occur near peak torque when cylinder pressures are at their highest.. Which, because of it's fairly flat torque curve is 143 lb-ft from 2,800 rpm all the way through to 6,500...
Knowing these points you can see why it's not good to run less than recommended octane. It is 12.5:1 CR ... Which is pretty high for a production motor.
ill86 is offline   Reply With Quote
Old 07-02-2012, 01:58 PM   #72
DeeezNuuuts83
Drives: 2006 Evo IX SE
I don't understand why people even think about running less than premium octane on any performance-oriented car. It's only a 20 cent difference per gallon. If you drive 12,000 miles a year, it might save you around $100 in gas, which isn't worth the risk of detonation while likely being outweighed by the cost of tuning your car for 87 octane (if you go that route). Oh yeah, it'll be slower too.
DeeezNuuuts83 is offline   Reply With Quote
Old 07-02-2012, 02:19 PM   #73
frsinpa
Drives: fr-s!
I run 93/94 in my FR-S. Never would think about putting in anything lesser.
Why run the risk of ruining a $26K car all in an effort to save $5-10? Not worth it for me.
frsinpa is offline   Reply With Quote
The Following User Says Thank You to frsinpa For This Useful Post:
ill86 (07-03-2012)
Old 07-02-2012, 04:33 PM   #74
kidgogeta
Drives: FRS
I only use chevron 94, (only go to chevron or shell for all my cars). There is no point at all to choose a lower quality fuel, you lose power and mpg. You save money in the end by getting more mpg and cars runs better.
kidgogeta is offline   Reply With Quote
The Following User Says Thank You to kidgogeta For This Useful Post:
moniz (07-02-2012)
Old 07-02-2012, 06:32 PM   #75
moniz
moniz's Avatar
Drives: 2010 Mazda5 GT,2012 Honda Fit Sport
Another person who actually gets it!! Glad to see I'm not alone!
Past-'89 Civic Si ('93-'99)-'94 Civic Si ('99-'07)-'07 GTI(Lease)('07-'10)'98 Acura EL ('03-'13)Current-'12 Honda Fit Sport'10 Mazda5 ('10- Family car)No FR-S for me Kids in car seats still and just wouldn't work in an FR-S especially in winter.
moniz is offline   Reply With Quote
The Following User Says Thank You to moniz For This Useful Post:
kidgogeta (07-02-2012)
Old 07-02-2012, 06:39 PM   #76
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by drifter View Post
OK, SO WHAT IF YOU'RE NOT A CHEAP BASTARD AND YOU WANT TO PUT THE BEST GAS IN, BUT YOU LIVE IN CA AND YOU CAN'T GET MORE THAN 91??? NO ONE HAS YET ANSWERED THE QUESTION OF (or I missed it) WHAT DO YOU ADD TO 91 OCTANE?
Toluene is commonly used to raise the octane level. However, as long as you are putting in 91 from a good top-tier station (NOT Thrifty or USA gasoline) then you should be fine.
Old 07-02-2012, 10:01 PM   #77
drifter
Drives: truck and old car
Thanks. So, you mean like a Chevron or Shell. Also, I live 5 minutes from Laguna Seca race way and I heard they have 100 octane there. I was thinking to add a gallion of that to my tank when I fill up. Still looking into it though
drifter is offline   Reply With Quote
Old 07-02-2012, 10:09 PM   #78
MrFRsLa
MrFRsLa's Avatar
Drives: 2012 Camry SE, 95 Honda Civic
I guess the question is what did your dealer put in it when your rolled it off the lot?
You should use Premium.
MrFRsLa is offline   Reply With Quote
Old 07-02-2012, 10:20 PM   #79
DeeezNuuuts83
This. My dad told me decades ago to not get gas at those places. That might be fine for your average, run-of-the-mill cars, or if there are just no other gas stations around, but I will avoid them ten times out of ten.
Going to a cheaper place rather than a Shell or Chevron in the same area usually won't save you much anyway. Where I always go, there is an Arco (soon to be USA Gas) on one corner and a Shell on the other, and their prices for premium are usually within three cents of one another. I don't mind paying a tiny bit extra, especially when you can use cards all you want, while places like Arco usually will charge you a flat 45 cent fee to use a card, which is usually more than what you save unless you are getting a lot of gas or just paying cash.
Old 07-02-2012, 11:57 PM   #80
Lonewolf
Lonewolf's Avatar
Drives: Moped
Running 100 without being tuned for it is just going to be a waste of your money.
While I do believe the car will run best as intended on 93-94 octane
(hence why all the other states with 93 refer to Cali Premium (91) as "piss water", anything above that without a tune for higher octane will just put a bigger hole in your wallet.
Running 100 octane will most likely result in a less efficient burn, and you will see no benefit without tuning for it.
Old 07-03-2012, 12:27 AM   #81
Night
Drives: '11 Tacoma
Even if you buy a new vehicle that runs regular I would run premium. Hell my taco is getting the premium gasoline!
Night is offline   Reply With Quote
Old 07-03-2012, 12:33 AM   #82
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
My recipe..BP Ultimate fill up then add 1 additional gallon of Sunoco GT Plus. Should give a strong 93 + octane rating
tonystewart is offline   Reply With Quote
Old 07-03-2012, 01:57 AM   #83
drifter
Even if you only mix in 1 or 2 gallons of 100 octane with 91? I thought that makes 93 and that's what it's tuned for? fuck this, i'm moving out of California.
Old 07-03-2012, 03:35 AM   #84
SFTiofoso
Drives: '10 Civic Si Coupe
Yeah, California sucks. Gas is expensive, no 93, can't own a gun, etc.
Anyways, if you have a 100 octane gas available to you, and you only add 1 gallon of 100 octane that would only bring your octane to like 91.7. You probably need to add 3 or 4 gallons to get it to 93. A pretty expensive proposition to do it regularly.
With my Si, I knew the dealer would put 87 on that car, and even-though that's not detrimental to an Si like it would be to an 86, I still wanted to make sure the octane was always 91+ in my tank. So what I did, was let whatever the dealer put in there run nearly dry, and then I went to a 76 station that sold 100 octane. Bought nearly a full tank of that, to bring the average octane to 91+. And from then, my car has always been filled with 91 Shell, Chevron, or 76 only. If you live in CA I would recommend you do the same.
If you have any doubts about what the dealer put in your car, just play it safe and assume it was 87.
SFTiofoso is offline   Reply With Quote
BRZ Premium Photos Only bimmerboy BRZ Photos, Videos, Wallpapers, Gallery Forum 47 05-15-2012 10:15 PM
FR-S vs BRZ premium seats? karbon BRZ First-Gen (2012+) — General Topics 26 03-29-2012 02:40 PM
HKS Premium Event DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 3 03-15-2012 02:49 PM
Premium Fuel riceracer8888 Scion FR-S / Toyota 86 GT86 General Forum 64 12-16-2011 11:27 AM
GT5 Premium wish list OldSkoolToys Other Vehicles & General Automotive Discussions 13 04-26-2011 02:17 AM
