Old 05-28-2017, 07:27 PM   #1
brehio
brehio's Avatar
Drives: 2014 Subaru BRZ
Locking lug nut?
I bought my car at an auction and it had these locking lug nuts on it but the key is nowhere to be found. Does anyone have a way to take these off without the key? Or maybe know the brand of this lug nut so I can buy the key?
Any help is appreciated.
Thank you
Austin Brehio Racing
My build thread
brehio is offline   Reply With Quote
Old 05-28-2017, 08:52 PM   #2
Thank you
Did you check under the spare? Mine is in the tool kit but it is a bit of an escape artist.
Any decent tire shop should be have a key which will remove it.
You can do this as well but it is sort of hit and miss if it will work.
[ame="https://www.youtube.com/watch?v=mJUUyjJqk5A"]How To Remove Wheel Locks Without a Key - EricTheCarGuy - YouTube[/ame]
brehio (05-28-2017)
Old 05-28-2017, 08:54 PM   #3
wparsons
wparsons's Avatar
Stock locking lugs are McGard, but unfortunately unless you have the key code for the locks you won't be able to get the right key. They're all different, so there's no universal one for them.
That said, you can buy a locking lug extractor that'll probably ruin the lock, but will get it off.
flickr
brehio (05-28-2017)
Old 05-28-2017, 08:54 PM   #4
brehio
brehio's Avatar
Thank you!
Sent from my XT1650 using Tapatalk
My build thread
Old 05-28-2017, 09:38 PM   #5
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
My son is a used car tech for a dealer and runs into this all the time. He usually hammers a cheap socket on and uses a breaker bar. When that doesn't work, it's air hammer time and lug stud replacement.
Yal is offline   Reply With Quote
The Following 2 Users Say Thank You to Yal For This Useful Post:
brehio (05-28-2017), VIP BRZ (09-14-2018)
Old 05-28-2017, 09:56 PM   #6
Gunman
Drives: 2019 Mazda Miata RF
I had some removed with an air chisel, and the guy never messed up a stud.
The Following User Says Thank You to Gunman For This Useful Post:
brehio (05-28-2017)
Old 05-28-2017, 10:20 PM   #7
ermagawd
ermagawd's Avatar
Drives: Crystal White Pearl
This cheap socket method worked for me on another car. Lug nut somehow cracked and broke off
ermagawd is offline   Reply With Quote
The Following User Says Thank You to ermagawd For This Useful Post:
brehio (05-28-2017)
Old 05-29-2017, 01:07 AM   #8
brehio
brehio's Avatar
Thanks for all the help!
My build thread
Old 05-29-2017, 09:42 PM   #9
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Go to the dealer, most have the master set of keys. I went to mine, they brought out a case and we tried them all until we found the one that fit. I wrote down the code so I could order a new one and was one my way.
Sent from my Nexus 7 using Tapatalk
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
brehio (05-29-2017), Tcoat (05-29-2017)
Old 05-30-2017, 06:03 AM   #10
PeterFRS
PeterFRS's Avatar
Drives: FRS
this.
although they are "unique", there is only a handful of these key designs.
so if you are willing to open up however many wheel lock pkgs and hope that you won't have to go through too many.
this would be the best bet
must be friends with parts guy or service guy..lol
they can always use the opened pkgs for new car wheel lock installations anyways
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 09-14-2018, 01:17 AM   #11
FTCLUB_USER_0086
Drives: C450
If you're going to order new ones anyway, you should just order aftermarket ones. As PeterFRS mentioned, factory sets don't have many combinations.
Here's some good info on wheel locks:
FTCLUB_USER_0086 is offline   Reply With Quote
Old 09-14-2018, 01:30 PM   #12
re-animator
if it is oem subaru you can get it taken off at a dealer. thats what i had to do when the previous owner lost the key.
re-animator is offline   Reply With Quote
Muteki locking lug key boxer_boy Northwest 7 02-04-2015 09:55 AM
Center locking M.I.A Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 09-06-2013 10:36 AM
Keyless Locking bdbx18 Electronics | Audio | NAV | Infotainment 4 12-16-2012 06:38 PM
modify when locking car. DriftEightSix AUSTRALIA 2 09-30-2012 09:30 PM
Locking the door.... huma BRZ First-Gen (2012+) — General Topics 15 08-19-2012 05:56 PM
