Old 05-26-2017, 09:41 AM   #4467
Tokay444
Anti stance.
Tokay444's Avatar
Originally Posted by dattran86 View Post
When im braking very hard from 150KM down to 100KM before the turn. my steering wheel would shake, the car feel off balance.
Is this normal under hard braking? or my tires are not good enough?
Please educate me if you know the problem.
You could have some uneven pad material build up on your rotors. That's the most likely cause anyway.
Old 05-26-2017, 10:14 AM   #4468
dattran86
Driver
Drives: 2013 Whiteout FRS
currently running Hawk HP+. The first 3 track days with them, it was fine. after the 4-5 track day the problem started.
But i am getting new pads soon, i will see if the problem occur again
Thanks
dattran86 is offline   Reply With Quote
Old 05-26-2017, 10:16 AM   #4469
Tokay444
Anti stance.
Tokay444's Avatar
It's likely not going to be the pads themselves.
Old 05-26-2017, 10:28 AM   #4470
Icecreamtruk
Drives: Track preped NA FRS
The problem is hardly ever the pads. Check the rotors. Dont just check from 10 feet away and be like "they look good enough". Get really close and look at the surface where the pad is touching. You might see very small cracks on the rotor, these will get worse over time and eventually your brake pedal will start to pulsate and should you choose to keep running them they will crack completly.
If the rotors are fine, you might have an alignement issue. Toe-ou in the front will create that "unstable" feeling during hard braking. Have you checked your alignment lately?
Icecreamtruk is offline   Reply With Quote
Old 05-26-2017, 10:31 AM   #4471
redlined600
redlined600's Avatar
Drives: Fr-s
Thanks
Probably a good time to upgrade. Do you set your parking brake in paddock?
redlined600 is offline   Reply With Quote
Old 05-26-2017, 10:33 AM   #4472
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Thanks
I found the Hawk pads to be no good. After 7 or 8 laps on track they started fading. I switched to Powerstop Track Day pads. I'll test them out tomorrow. Got a track day at Willow Springs. Got some HPS 5.0 for sale cheap.
Lunatic is offline   Reply With Quote
Old 05-26-2017, 10:34 AM   #4473
dattran86
Driver
I had the car up on jack stand and check the pads and rotor after the track day, rotor was fine but there was uneven wear from the brake pads.
I will do another double check when i get a chance on the weekend.
and I just got my alignment about 3 months ago when I installed my RCE Yellow, it should be 0 toe in front.
Thanks
Old 05-26-2017, 10:35 AM   #4474
dattran86
Driver
nope, i put 2 piece of wood and try to back into the wood when i park in the pit. and put the car in gear
Old 05-26-2017, 10:37 AM   #4475
dattran86
Driver
thanks for the info,
And i can feel they starting to fade on the 5th track day.
Im looking into Project mu or Ferodo.
Old 05-26-2017, 10:46 AM   #4476
Tokay444
Anti stance.
Tokay444's Avatar
Shouldn't matter. It's a drum/shoe setup.
Old 05-26-2017, 10:47 AM   #4477
Tokay444
Anti stance.
Tokay444's Avatar
Thanks
Did you check the rotors for flatness with a dial indicator?
Old 05-26-2017, 10:56 AM   #4478
dattran86
Driver
Unfortunately no, do you think the rotor could be slightly warp?
Old 05-26-2017, 11:07 AM   #4479
Tokay444
Anti stance.
Tokay444's Avatar
Or it has uneven pad buildup on it.
Old 05-26-2017, 11:33 AM   #4480
86league
Drives: '13 BRZ Limited
I had pretty bad brake pulsation on my BRZ after several track days - I had read that warping was unlikely, it was much more likely uneven pad transfer. I took all the rotors off and sanded the he** out of them with garnet sandpaper such that there was no pad material on the rotors.
Pulsation still present.
Bought a runout gauge and found there was a fair amount of runout - can't remember the #'s, but it was out of spec - so either warped or thickness variation. I replaced the rotors and the pulsation went away, but came back after another 3 weekends. I've added some brake cooling to see if that keeps it from happening again.
86league is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
