Old 05-23-2017, 05:47 PM   #1
FRSH86
FS: 10:1 Ptuning Built Motor, MAKES NOISE, VIDEO!!!
Looking to see if there is any interested and what offers I can get for a built motor that is making noise. Not 100% sure on what the issue is. Listen to video (keep in mind that is a cold start inside a concrete garage).
It was build by Ptunning in December 2014 and had their Turbo Kit on it. Had wideband, failsafe, injector kit, etc and was tuned by Ptuning to 420HP.
3 thousand miles later in August of 2016, during a 4th gear highway pull, the noise appeared and the car was trailered home immediately.
I purchased the car as is last year. Started it up once and recorded a video. It was not smoking and I did not see any metal shavings or coolant in the oil.
I have different plans for the car so the motor is for sale.
I have all the receipts from Ptuning build.
Here are some details:
#SC7405CP Pistons, 0.5mm overbore, 10:1 compression, 86mm.
Biran Cower I-Beam Rods.
Cleaned block
Square decked 2 sides
Honed Block
Re-grind rods journal 25mm
Straightened crank
Balanced
Set Clearance
OME Rod bearings
OEM Main bearings
ARP Head stud kit
AP case bolts set
OEM Bearing set-connecting rods
OEM Engine Timing Cover
OEM engine gasket kit set
Disassemble cylinder heads
Check cylinder heads
Cleaned cylinder heads.
Decked cylinder heads.
PM me or text me with offers or if you want more info
(612)229-1797.
Thanks, Stan.
*****VIDEO*****
[IMG]http://i531.photobucket.com/albums/dd360/figak/IMG_9831_zps2mq8v***.jpg[/IMG]
FRSH86 is offline   Reply With Quote
Old 05-23-2017, 05:53 PM   #2
FRSH86
Moderators, I totally forgot. I will get a photo with the date and my username today.
Thanks.
Old 05-24-2017, 10:29 AM   #3
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
Sounds like a spun bearing; were you turning in the highway during the pull? I can't imagine losing oil pressure in a straight line... What kind of oil pan were you using?
elitegunslinger is offline   Reply With Quote
Old 05-24-2017, 11:36 AM   #4
FRSH86
This is what I got from the previous owner, so I don't know for sure. I bought the car like this. No oil light was on. Stock oil pan.
Old 05-24-2017, 12:02 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
2. You must post AT LEAST ONE picture of the item(s) for sale with a sign included in the photo. On the sign, should be your username, date and the words FT86Club.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Thanks,
ichi
Old 05-25-2017, 12:08 PM   #6
FRSH86
Sign added. Thanks.
The Following User Says Thank You to FRSH86 For This Useful Post:
ichitaka05 (05-25-2017)
Old 05-29-2017, 11:08 PM   #7
FRSH86
No one is interested?
Old 05-30-2017, 09:58 AM   #8
elitegunslinger
I bid $350
Old 06-08-2017, 12:48 PM   #9
FRSH86
BUMP
Old 06-08-2017, 12:55 PM   #10
Teseo
Drives: frs
Dibs on turbo
Old 06-08-2017, 04:23 PM   #11
FRSH86
Originally Posted by Teseo View Post
Dibs on turbo
Sorry, that's not available!
Old 06-08-2017, 09:14 PM   #12
VABeachBRZ
VABeachBRZ is offline   Reply With Quote
Old 06-09-2017, 12:55 PM   #13
Coltonscool
Drives: WSP FRS, S13 240sx
Bid: $700 shipped.
Coltonscool is offline   Reply With Quote
Old 06-09-2017, 05:34 PM   #14
FRSH86
Thanks for the offers! But I'll have to decline.
Full blown turbo kit on built motor e85 VIDEO 3rd 4th gear pull Anthony7515 Off-Topic Lounge [WARNING: NO POLITICS] 3 03-31-2017 01:47 AM
Full blown turbo kit on built motor e85 VIDEO 3rd 4th gear pull Anthony7515 BRZ First-Gen (2012+) — General Topics 0 03-31-2017 12:30 AM
Full blown turbo kit on built motor e85 VIDEO Anthony7515 Forced Induction 0 03-31-2017 12:27 AM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 04:52 PM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 03:57 PM
