#15 | |
Drives: FT86
Yes you could adjustt the waste gate duty cycle electronicly to adjust boost but you would be obly able to limit boost to the waste gate spring pressure. Ie the boost control can be increased above the waste gate spring pressure but not below. Also overboost protection is mainly their to guard against a wastegate failure or malfunction causing too high boost, so you want an independant system as a failsafe. Ecutek guys will just use a custom maps to do similar process but you can get more adjustability and fancy Last edited by steve99; 05-19-2017 at 08:20 PM. |
#16 |
Drives: 2014 BRZ
| The Following User Says Thank You to jerseymike1966 For This Useful Post: | Sportsguy83 (05-19-2017) |
#17 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Besides tuning..... is the OFT, i guess, good enough to make accurate readings on AFR, Boost, Oil pressure through 3 bar map sensor for JDL kit? or am I better of getting getting wideband (aem) or other gauges?
May be a little bit of thread jack but its slightly related
Instagram: Gabe.it.the.ole.college.try |
#18 | |
Drives: FT86
OFT will read/log data from the standard sensors available on car as good as anything else. The car doesn't come with an oil pressure sensor so you need to provide your own . (its only a simple switch at about 2 psi to light the dash light should read replace engine light) car only has oil temp sensor the stock o2 sensor can be recalibrated to read richer afr quite successfully down to about 10.5 If you want to implement automatic failsafes in tune for oil pressure loss and afr then you will likely need ecutek. oft only has overboost cut based of map sensor. different map sensor just need to be scaled in tune can do that with all tune systems |
| The Following User Says Thank You to steve99 For This Useful Post: | ShadowReaper (11-24-2017) |
#19 | |
Indulgent Tormenter
So Im not actually tuning the kit through OFT. I have been planning on selling the tablet but then I thought about all the readings the it makes, so I'm just seeing whats the better option as far as boost / afr / oil temp/ press
#20 | |
Drives: FT86
oft would read boost afr and oil temp, but pressure no as it would be external sender. you would probably be better selling tablet and buying the ecutek blutooth dongle then using the ecutek android or apple app to monitor ecu it can be set up with custom dash gauges. tuner could intergrate oil pressure sender and failsafe cut in ecutek custom maps. http://www.ecutek.com/ecu-connect they could feed oil pressure signal into ecu then you could use it for failsafe and display in blutooth app |
| Forced Induction | James The Giant | Mid-Atlantic | 4 | 03-17-2017 12:00 PM |
| Forced Induction HELP! | surfuxalot | Forced Induction | 22 | 06-20-2015 12:56 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 07:50 PM |
