Old 05-17-2017, 06:56 PM   #99
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
First product photo:
They are selling the kit *only* with the crash beam, there will not be an option to order it without the beam. I personally think this is really reasonable for a bolt on oil cooler kit.
I'll keep the thread updated as it is fully released and ready for purchase. Should be very soon.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 05-17-2017, 07:10 PM   #100
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
Any mounted photos?
Sent from my XT1575 using Tapatalk
Old 05-17-2017, 08:15 PM   #101
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
We test fit on my car. So i dont think the production kit has been fully mounted yet. If i get my hands on it, ill post pictures mounted up.
Sent from my SM-G955U using Tapatalk
djwishbone is offline   Reply With Quote
Old 05-17-2017, 09:18 PM   #102
Ashikabi
Ashikabi's Avatar
Cool. Does it sit behind the fog or crooked by the radiator?
Old 05-17-2017, 11:14 PM   #103
VerusEric
VerusEric's Avatar
Any mounted photos?
This should help. Please note that these are prototype/mock-up images when we were working on the kit and figuring line lengths.
The Mocal adapter fits and does not need banjo bolts, which is a huge plus IMO. We found that the Grimmspeed, IIRC, oil cap did not fit with the Mocal adapter and turbo... *So if you have an aftermarket oil cap, you *may* need to revert back to stock.*
Thanks,
Eric
Old 05-17-2017, 11:49 PM   #104
Ashikabi
Ashikabi's Avatar
Thanks, that's what I was looking for. Look forward to seeing it with the bumper cover installed. Any idea why the oil call wouldn't fit?
Old 05-17-2017, 11:52 PM   #105
djwishbone
Last Starfighter
If you mean the cap? Look at the clearance between it and the sandwich plate. It has to do with the tight fitment next to the turbo
Old 05-17-2017, 11:53 PM   #106
Ashikabi
Ashikabi's Avatar
Oh, so only if you have the turbo ALSO. My mistake for misreading that
Old 05-18-2017, 02:29 AM   #107
choi0706
Drives: t
is there space to put in a larger core? where will the air exit?
choi0706 is offline   Reply With Quote
Old 05-18-2017, 02:36 AM   #108
djwishbone
Last Starfighter
The core they chose is definitely larger than the mock up one in the last photo. A 19 row setrab fits fine. The air can escape up if you use hood vents. If not, some holes in the fender liner vehind would work nicely.
Old 05-30-2017, 09:53 PM   #109
arthur93
Drives: Toyota 86 GTS
What exhausts are everyone running with this kit (from mid pipe back). Looking at getting the Tomei 60s and a 2.5" mid pipe with a cat as I want to reduce the weight of the exhaust system as much as possible, but will the smaller diameter hinder performance a lot? I am not aiming to be pushing anything over 280-300hp initially, and once I go e85, nothing over 350. Also, may sound stupid, but would a 2.5 inch front pipe connect to the full race 3" over pipe without any issues?
arthur93 is offline   Reply With Quote
Old 05-30-2017, 10:15 PM   #110
choi0706
Drives: t
3inch xforce.. its really quiet and nice.
The Following User Says Thank You to choi0706 For This Useful Post:
arthur93 (05-30-2017)
Old 05-30-2017, 10:16 PM   #111
choi0706
Drives: t
Thanks,
Eric
do you have these in stock?
Old 05-30-2017, 10:22 PM   #112
VerusEric
VerusEric's Avatar
I would recommend sticking with 3". When recirculating the wastegate (internal WG EFRs), you don't want a bottleneck further down the line. Will it make a massive difference? No. Will it reduce efficiency, yes.
Last I was told, there are 3 in stock.
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2637 12-27-2020 04:44 PM
Full-Race Motorsports White_Lightning Forced Induction 259 04-11-2017 02:04 AM
best turbo kit - currently Full Race? TEAM SCION Forced Induction 41 10-14-2016 09:41 PM
Full Blown Motorsports turbo kit exhaust question. Jtbirchfield Forced Induction 2 09-09-2015 05:19 PM
Full blown turbo kit owners Joeycokeboy Engine, Exhaust, Transmission 2 09-02-2015 10:49 PM
