Old 05-15-2017, 12:36 AM   #1
403
Drives: 2013 FRS
What coilovers should I purchase?
So im not too sure what kind of coilovers to get for my '13 FRS. I daily drive my car and don't participate in any track or drift events, so im not looking at coils that are too expensive, maybe in the range of 1000-1300CAD. I was looking at BC Racing ER Coils and the TEIN Flex Z's but im not too sure im even looking at the right coils
403 is offline   Reply With Quote
Old 05-15-2017, 12:38 AM   #2
e1_griego
e1_griego's Avatar
Drives: Many
Why are you buying coilovers if you're just daily driving?
Generally: the cheaper the coilover, the worse the ride. It's an easy way to ruin the ride quality of your car by buying cheap pick-your-favorite-color coilovers.
e1_griego is offline   Reply With Quote
The Following 4 Users Say Thank You to e1_griego For This Useful Post:
strat61caster (05-15-2017), TheWhiteWizard13 (06-18-2017), wparsons (05-15-2017), Yardjass (05-17-2017)
Old 05-15-2017, 12:42 AM   #3
403
Drives: 2013 FRS
im trying to fit bigger wheels on my car and to simply lower it
The Following User Says Thank You to 403 For This Useful Post:
TheWhiteWizard13 (05-18-2017)
Old 05-15-2017, 02:12 AM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=67345
If you're still determined to do whatever it is you were planning on there's lots of name brand stuff out there in your budget that gets good reviews and vendors that will help out if something goes awry, best of luck.
ineedyourdiddly
Old 05-15-2017, 07:53 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Personally I think the ride in the flex z is more compliant than bc
tyler_win_photo is offline   Reply With Quote
Old 05-16-2017, 01:31 AM   #6
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Tein Flex Z / end thread.
Joe-G is offline   Reply With Quote
The Following User Says Thank You to Joe-G For This Useful Post:
Old 05-16-2017, 11:36 PM   #7
Niko-Fab
Drives: '86 ESi-R
PM'd you
Niko-Fab is offline   Reply With Quote
Old 05-17-2017, 08:14 AM   #8
MeisterR
MeisterR's Avatar
Drives: BNR32
The MeisterR ZetaCRD+ Coilovers is another one that is close to your budget due to the recent group buy.
http://www.ft86club.com/forums/showthread.php?t=117150
There are lot of options, so this is just another one to consider.
Jerrick
MeisterR is offline   Reply With Quote
Old 05-17-2017, 08:46 AM   #9
Tokay444
If that's your budget, just buy a couple sets of really good tires instead. Look at coilovers when you can triple your budget and buy something worth buying.
You can't even replace the mass produced OE parts, which are the most cost effectively made option available, for that budget.
Old 05-17-2017, 08:51 AM   #10
Gforce
Drives: 2013 Subaru BRZ
Not enough money. That will get you four Bilstein B6 from the Canadian retailer (google Bilstein) and a 20 mm front roll bar including installation. Factory springs are fine with these shocks.
If you want to improve both the ride and handling drop down to your Subaru dealer and buy a pair of 2017 rear springs. You will get better performance over the bumps and better balance front to rear. Cheapest and most effective spring upgrade you can make is install just a set of 2017 rear springs.
With 2017 rear springs even the Primacy tires will be ok.
Gforce is offline   Reply With Quote
Old 05-17-2017, 08:56 AM   #11
Gforce
The car doesn't benefit from larger wheels.
If you want to lower the car just buy a set of lowering springs compatible with the factory shocks. The factory offers a set of Eibach made springs. There are other suppliers.
Coilovers are total overkill for this car unless you intend to actually adjust them for different purposes. The car is actually low enough to perform very well without shorter springs but Subaru/Toyota designed it from the start to be compatible with a one half inch to one inch drop which they then offered a spring set for. There was even a factory special offered either lowering springs in some market.
Forget coilovers.
The Following User Says Thank You to Gforce For This Useful Post:
Tcoat (05-17-2017)
Old 05-17-2017, 09:27 AM   #12
WRBrzRX
Drives: runs&drives
what
STOP POSTING
WRBrzRX is offline   Reply With Quote
The Following 2 Users Say Thank You to WRBrzRX For This Useful Post:
sugoi (05-17-2017), TheWhiteWizard13 (05-18-2017)
Old 05-17-2017, 09:30 AM   #13
StraightOuttaCanadaEh
Wes
Tein Flex Z is what I'll be going for most likely, they're $1169+tax at FT86motorsports.com, which is within your budget. If you take it to a shop, you're looking at 4 hours of labour to install them and another 2 hours or so (this can vary) to do the alignment. So your total would run up to about 2K cad.
Old 05-17-2017, 09:31 AM   #14
KnightRyderx2
Drives: 2014 FR-S
The MeisterR ZetaCRD+ Coilovers mentioned up top, are going to be a great buy in your price range. Especially with the group buy going on right now, but you have to get on it before they run out. Also the Tein Flex Z are a great buy for there price, CSG Mike did a great review of them. There is review of all these all over this forum. Also there is a thread in the suspension section on coilovers, check it out.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
coilovers, daily driven, help please, question, suspension
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Free SS Brake Lines with Purchase of any Coilovers!!! BC Racing, KW V3, Stance, Tein Dustin@Dynosty Brakes, Suspension, Chassis 24 09-17-2013 02:19 PM
First purchase? cncnjn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-21-2013 04:41 PM
Where to purchase TRD KIT? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 1 04-26-2013 02:08 AM
Special Purchase price-TEIN FLEX FR-S/BRZ coilovers Stav Canada Classifieds 5 04-21-2013 05:41 PM
