Old 04-22-2017, 12:52 AM   #29
Originally Posted by Sarlacc View Post
Mine twitches a little sometimes when the AC kicks in at idle. The idle RPM fluctuates a little, too.
I seem to remember old threads about it; consensus was that it's normal, I think?
However, my old Legacy (with a similar Subaru flat 4 in it) got it worse.
It flashed dash lights and even stalled when the AC kicked in at idle.
The dealer fixed it by tickling the throttle body and resetting the ECU.
Mine as well but he said "comes back up to 700" so just how far is it dropping? It will be interesting to see if the problem goes away when he flashes back to stock
Old 04-22-2017, 01:23 AM   #30
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Flash back to stock and re-check.
Old 05-11-2017, 02:38 PM   #31
snk828
snk828's Avatar
Drives: raven FRS
update: The car got flashed back to stock tune and drive couple miles, the vibration still there. I did take the car into the shop check for engine mounts, but the mounts still holding fine. I also did some research in the forum, ppl are having uneven engine vibration from the early model year, but didn't mention anything about steering vibration. Does anyone owns a 2013 model year have the same steering vibration? I hope this is normal for our car.
snk828 is offline   Reply With Quote
Old 05-11-2017, 02:59 PM   #32
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I have had one 2012 and one 2013 GT86 and never had any vibration.
Just to confirm, does this happen when standing still? (Excluding tires and wheels)
What is your idle RPM when this happens?
Does it stop vibrating of you rev up in neutral?
Old 05-11-2017, 04:11 PM   #33
snk828
snk828's Avatar
Drives: raven FRS
It's only happening at idle, idle RPM about 700, it does go away when I rev up in neutral. now I'm thinking the header contacts the steering rack or something.
Old 05-11-2017, 04:15 PM   #34
I've driven many different flavors of the 86. Other than the occasional little *ahem* when the AC compressor engages, this thing idles pretty smoothly.
snk828 (05-11-2017)
Old 05-11-2017, 04:58 PM   #35
snk828
snk828's Avatar
Drives: raven FRS
I drove a 2015 BRZ and a 2014 frs, both steering wheels don't have any vibration that's why I start to worry about mine.
Old 05-11-2017, 09:13 PM   #36
BRZnut
Drives: BRZ DGM Limited
I have a 2013 and no steering vibration (bought it fall 2012 , so one of the early ones)
Old 07-07-2019, 08:20 PM   #37
drift8686
Drives: gt86
same model same problem.
please update the reason
drift8686 is offline   Reply With Quote
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-07-2017 12:20 AM
My steering wheel is stuck: Cusco steering wheel norcalpb Cosmetic Modification (Interior/Exterior/Lighting) 4 01-01-2017 05:48 PM
WTB after market steering wheel set up . Steering wheel, hub and quick release. Vroomin86 Want-To-Buy Requests 1 11-05-2015 07:44 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Vibration feedback through steering wheel. Jayde Issues | Warranty | Recalls / TSB 5 07-25-2013 11:19 AM
