Old 07-01-2012, 08:02 PM   #113
jeebus
I just wanted to thank you all for a great read. Keep it up
jeebus is offline   Reply With Quote
Old 07-01-2012, 08:58 PM   #114
arghx7
Drives: car
Does not run closed loop during WOT.
-John
Is there a flag/bit you are logging in the ECU that tells you when it is open loop? Is there an open loop delay timer you are logging?
Old 07-01-2012, 09:05 PM   #115
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
They have already cracked the ECU so I would believe that they have identified the throttle threshold, andload threshold tables that define the transfer from closed to open loop, what is weird is how the AFR ratio with the stock intake oscillated around the command AFR, which appeared it was being change by a fuel trim table. Thus I thought maybe we had full time closed loop.
I doubt John will be able to comment as EcuTek hasn't released anything yet.
Arghx7: I also logged catalyst for my dyno runs if you want the *.csv file I can zip it and attach.
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-01-2012, 09:42 PM   #116
arghx7
Drives: car
We'll have to wait and see about this. I'm sure they've figured out what buttons to push to lean it out and advance the timing, but beyond that we'll see how well the logic is understood.
I looked through it. Max estimated cat temp was 850C, which is totally unsurprising. You'd have to hook up a thermocouple to the cat to see how accurate their model is, but 850-950C is the max range you can operate a catalyst without excessive aging. If you lean out the engine for more power, the cat will deteriorate faster, although you'd probably never notice it in the real world.
Old 07-01-2012, 10:40 PM   #117
Visconti
Drives: 05 STi
No but just like other subarus the fuel trim can be carried over during WOT. This is most likely seeing.
The EcuTek software is a done software / tuning package.
The tuner doesn't get to see the raw address's or lookups.
Just a working product that gets updates on a daily basis.
John
Visconti is offline   Reply With Quote
Old 07-01-2012, 10:41 PM   #118
jedibow
Another interesting fact was the stock enrichment at high RPM's, if it was not there more power could be made up top, the AFR where in the low 11's, could this be to protect the cats? or do you think it is only a safeguard built into the factory tune for reliability? Another aspect that I failed to bring up to this point, during the torque dip the actual AFR was 13.3 (kind of explains the advance timing in this area however), which correlates to the command AFR, if what John (visconti) said was true, what is the advantage of running a lean AFR during open loop, especially whe 12.5 produces the best power, if anything it is creating a hot spot in the rev range. Maybe I will take the EGT out of the evo to get some readings. I cannot log it as it is a cheap autometer gauge, but I could atleast observe the difference between the torque dip, and once the AFR get down to 12.5 like it should be.
Old 07-01-2012, 10:44 PM   #119
Visconti
Drives: 05 STi
Leaning out the high rpms alone picked up power.
Cam timing also plays a huge roll on the power band of this car
Old 07-01-2012, 11:54 PM   #120
jedibow
John,
When you adjust cam timing does it move the torque dip further forward, or backwards in the rev range, or does it stay consistent as far as RPM is concerned?
Old 07-02-2012, 08:18 AM   #121
Visconti
Drives: 05 STi
Originally Posted by jedibow View Post
John,
Dip doesn't move , always in the same spot
Old 07-02-2012, 11:49 AM   #122
arghx7
Drives: car
I'm sure the biggest reason for that level of enrichment is to protect the cat(s). Remember how the max estimated cat temperature was about 850C near redline? If you lean the mixture out, power goes up to some extent and so does cat temp. The estimated cat temp calculated in the ECU may not reflect that (it depends how the model was designed), but it will definitely get hotter. There are a few different places you can measure cat temp. You would want to put your K-type thermocouple in there and use a high speed data acquisition system.
To further clarify the issue it would be nice to see a chart of commanded AFR, measured AFR coming from the stock Denso limiting-current type wideband o2, measured AFR on a Bosch pump-cell type wideband o2 in the exhaust stream, and measured AFR from a Bosh sensor at the tailpipe.
The data to me is still a little murky as far as closed loop at lambda 1, closed loop at lambda 1 with a delay timer incrementing (like on the current WRX/STi), closed loop in a partially enriched state, open loop at an enriched state, always being in closed loop at an enriched state... there are so many ways this could be handled and it may be shifting into different modes under different conditions. I'd like to see more data to interpret for myself, either directly from ECU RAM addresses or from the Universal CAN diagnostic protocol. Specifically, I'd like to see the Fuel System Status PID over the bus or specific flags/bits from the ECU RAM addresses.
The issue here is CO emissions on the US06 test cycle. A WOT pull on a chassis dyno is not the same as a driving a US06 test cycle, but the strategies used to meet CO emissions tend to affect WOT control as well. The US06 test cycle doesn't have WOT, but it does have heavy acceleration that can be difficult for low torque small engines that run at high loads. The current standard for this vehicle should be around 8.0 grams per mile, but in a few years when LEV III emissions comes out that may be cut in half. The vehicle still has to meet certain in-use testing requirements 1 year and 4 years from now. So you can't tune the thing on the ragged edge of the emissions standard, or there will be fines and recalls in a few years if enough of the cars fail.
That's why you go as lean as you can during transients without exceeding targets for cat temperature and knock. As I mentioned above, there are a lot of ways you can do this depending on how accurate your sensors are and how much manpower you want to put into developing software and engine calibration. I would be surprised if the FA20 just goes from closed loop lambda=1 to open loop enriched based on a couple look up tables while still meeting emissions. These days some kind of intermediate step usually occurs--delay timer, closed loop enriched, etc. I don't want to make some kind of judgment based on insufficient data.
FJO makes a two-channel converter box that allows you to convert a K type thermocouple to a 0-5v analog signal. I've had pretty good luck with this system on my own projects; but you would be spending time and money to merely satisfy curiosity. The Autometer EGT gauges read too slow. They are useless for this, don't even waste your time.
The Following User Says Thank You to arghx7 For This Useful Post:
jedibow (07-02-2012)
Old 07-02-2012, 12:35 PM   #123
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The intake did smooth out the MAF readings, and according to visconti the ECU runs open loop at WOT, so the only reason the command AFR and actual AFR ratios would be the same is whoever tuned the factory MAF scalings and compensation were spot on, kind of cool.
What this means is once tuning is available you will not have to arbitrarely assign values to the independant cells in the fuel map, what you enter is what you will see in the external wideband gauge. It will make life easier.
I would also like to comment that the oscillations between AFR on the dyno were +/- 0.2 points in AFR, after the intake, it did not oscillate at all.
BTW max hp 171, max torque 146. these values are SAE corrected ofcourse for my being at 5500 feet above see level, however uncorrect it was 136, and 117 almost exactly what evoscan predicted, awesome.
Thats how the Impreza's have been in the past.
Ranatsu is offline   Reply With Quote
Old 07-03-2012, 08:07 PM   #124
jedibow
I will be tracking my car this weekend, so I will post new datalogs after, anything in particular you would like to see?
I was planning Intake air temperature, and absolute load would be a good place to reference, I think right now we have a good grasp on timing, and as it is an open track day I will get her nice and hot (I will include Cat temp)
G
Old 07-04-2012, 11:52 PM   #125
arghx7
Drives: car
Get fuel system status and stock wideband reading working if possible.
Old 07-05-2012, 12:20 AM   #126
jedibow
I have fuel status, the wideband still wants to time out? Evoscan issue? I be working on it tomorrow, and Friday. I'll post the csv.
The Following User Says Thank You to jedibow For This Useful Post:
bambbrose (07-05-2012)
Great dealership in NE Ohio.. (still has multiple pre-order slots open) eikond BRZ First-Gen (2012+) — General Topics 15 03-02-2012 02:03 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-02-2012 12:01 AM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 02:00 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 11:21 PM
