Old 05-10-2017, 06:46 PM   #15
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Originally Posted by Gunman View Post
Needle nose pliers won't fit up in there?
Holy shit that's a long plier. I tried regular pliers but it just seemed to squeeze the outer part of the piece instead of pushing in the flaps that are slightly recessed.
Drambeenie is offline   Reply With Quote
Old 05-10-2017, 06:49 PM   #16
spike021
spike021's Avatar
Originally Posted by Drambeenie View Post
Yes. We're going to be using industrial 3D printers. This isn't a HomeKit 3D printer. There are many 3D printing processes and machines and materials. We'll test the parts thoroughly and build it for structural considerations. Given the amount of wind resistance that can be generated at high speeds, we'll be very thorough.
My cousin is a robotics engineer so we're going to make sure it's structurally sound, sturdy, durable and most importantly safe!
If you don't have an IG or similar for your car you should set one up! Would be interesting to follow the progress of this, unless you guys are going to keep it relatively quiet till it's done.
spike021 is offline   Reply With Quote
Old 05-10-2017, 07:10 PM   #17
Drambeenie
Drambeenie's Avatar
I'll post the progress on my main IG account. This is really just a fun project more than anything else, and if people are interested in it and would like it too then great!
www.instagram.com/StephenMarkLevi
The Following User Says Thank You to Drambeenie For This Useful Post:
spike021 (05-10-2017)
Old 05-10-2017, 07:18 PM   #18
Gunman
Drives: 2019 Mazda Miata RF
Put some tape on the ends, to make "high spots" to push in more on the clips. Sort of like this:
Old 05-10-2017, 07:40 PM   #19
Drambeenie
Drambeenie's Avatar
Very clever. I'll give that a shot!
Old 05-10-2017, 11:43 PM   #20
Drambeenie
Drambeenie's Avatar
Got it! This was the pic that did it and super easily too.
I continued with the rest of the disassembly. I took measurements, but we're also going to 3D scan the pieces to create a CAD model we can modify to be taller. The pylons are definitely plastic with metal reinforcement for the screws to attach to. Pretty easy to disassemble actually.
Removed the little pieces that sit ontop of the wing. They pop right off with a plastic panel tool.
Little rubber piece. Not sure if this will be necessary with the higher spoiler.
spike021 (05-11-2017)
Old 05-11-2017, 05:22 PM   #21
Seasaw
Drives: 2017 WRB BRZ
Please post the results! I really like the 17 wing, yet I also had the idea of having it raised a little bit higher. Exited to see how this turns out!
Seasaw is offline   Reply With Quote
The Following User Says Thank You to Seasaw For This Useful Post:
Drambeenie (05-11-2017)
Old 05-11-2017, 05:28 PM   #22
DrButtDrugs
yerp
Drives: 2015 WRX
Kind of a long shot but I'm guessing the MY17 spoiler doesn't match up properly with the 13-16 spoiler bolt pattern, does it?
DrButtDrugs is offline   Reply With Quote
Old 05-11-2017, 07:10 PM   #23
Drambeenie
Drambeenie's Avatar
It looks like the two bolts on both sides of the trunk match up pretty close, but the 17 spoiler has an additional clip above the bolts, whereas 13-16 has additional clips that run down the width of the trunk.
In my rough estimation you could attach a 17 wing to a previous year BRZ if you patch the trunk clip holes
Old 05-11-2017, 07:17 PM   #24
johan
Drives: '14 981CS, '99 NB1
I'm in for following this. I've been talking on/off with engineering friends about this over the last 6 months. I just haven't pulled the trigger on any development yet.
A side note. Subaru strengthened the '17 trunk lid on the sides to help support the weight/downforce of the new spoiler. So while you could retrofit it to an older trunk, it might deform.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Old 05-11-2017, 10:36 PM   #25
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
They specifically designed the new spoiler to complement the car aerodynamically with what's going on up front, not sure why you'd wanna mess with that too much.
Borchert97 is offline   Reply With Quote
Old 05-12-2017, 01:25 AM   #26
johan
For fun.
Drambeenie (05-12-2017)
Old 05-12-2017, 12:28 PM   #27
Drambeenie
Drambeenie's Avatar
This car was made to mod
The Following 3 Users Say Thank You to Drambeenie For This Useful Post:
johan (05-12-2017), spike021 (05-12-2017), Tcoat (05-12-2017)
Old 05-12-2017, 05:22 PM   #28
Drambeenie
Drambeenie's Avatar
Initial sketches - not CAD yet. Let me know if you guys like any in particular. It's hard to judge without seeing it in physical form or on the car, so we're going to narrow it down and prototype just a few of them. Happy friday!
Here is what the 2.5x looks like from the back (roughly)
The Following 2 Users Say Thank You to Drambeenie For This Useful Post:
derekbrz24 (05-13-2017), johan (05-12-2017)
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
