#127 | |
Drives: Crystal Black BRZ(Sophia)
| The Following User Says Thank You to Yoda For This Useful Post: | Kris86 (05-05-2017) |
#128 | |
Drives: RHD Gt86
could my EBCS be hooked up in a way to cause a vacuum leak? if I remember correctly, the EVAP solenoid is now disconnected and my EBCS is plugged into the plug that the EVAP was once plugged into, also the hose coming from the intake manifold is then plugged into the EBCS. its a three port so one is vented to atmosphere I think. how do I check my MAF? Thank you for your support !
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#129 |
Drives: Rb25 neo brz
Did you preform a leak-down test on the motor before it was installed? If so what was the %?
| The Following User Says Thank You to -Phil For This Useful Post: | Kris86 (05-05-2017) |
#130 | |
Drives: RHD Gt86
Yes we did a leak down test, not before but after the motor was installed in the vehicle. two were 9% one was 6% one was 7%gl
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-05-2017 at 03:14 PM. |
#131 |
That's fairly normal before the valves and rings seat, i would run the car for a bit and give it a chance to seal up. Let the motor cool and get the number. if those are your numbers after already doing that then its a different story. generally motors we build are 1-2% leak-down while on the engine stand and that drops to 1 or less once the motor is ran.
#132 | |
Drives: RHD Gt86
#133 | |
Drives: RHD Gt86
#134 |
Drives: RHD Gt86
Sooo, this is what I've found so far
Not sure if this will cause my vacuum leak issue tho
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-06-2017 at 05:07 PM. |
#135 |
Drives: RHD Gt86
Looks like we are gonna be pulling the motor :-( @FRS Justin @GsxrMe @Yoda @Moto-Phil
My mechanic thinks maybe the rings could have been cut to wide possibly, so he said he will get the rings and replace them. We have no vacuum leak, we have back check everything possible. We did the compression test and came up with this Piston 1 - 95 Piston 2 - 90 Piston 3 - 98 Piston 4 - 93 Even though I'm running 9:0:1 compression I shouldn't be seeing such low results
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-08-2017 at 01:28 PM. |
| The Following User Says Thank You to Kris86 For This Useful Post: | Yoda (05-08-2017) |
#136 |
Did you do the compression test on a warm engine with the throttle held wide open? 90psi is barely enough compression too fire off. If your rings were leaking down you would've seen that in the leak down test. Is there a lot of crank case pressure? Is it pushing coolant at all?
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Kris86 (05-10-2017) |
#137 | |
Drives: RHD Gt86
not sure about the crank case pressure tho :-S, would you mind explaining to me how to go about checking this?? I have in the Radium DUAL catch can set up, which are vented to atmosphere. it has not pushed any coolant out what so ever. ive been suggested that it would either be bent valves ( when engine wasn't timed correctly first) or maybe rings ground to much. :-( I appreciate your help
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 05-10-2017 at 09:48 AM. |
#138 |
What do you mean by just swinging the engine over?
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Izzyboost1 (05-11-2017) |
#139 |
Drives: RHD Gt86
Put my foot flat on the throttle and swung the engine a few revolutions with starter
We did not run the engine and warm it up before doing so
#140 |
Take the intake pipe off and hold the throttle open and try again. Make sure you take all the spark plugs out to save your battery.
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Kris86 (05-11-2017) |
| Who's tired of the "Pedal Dance" and wants to be in real control of their car? | FT-86 SpeedFactory | Tracking / Autocross / HPDE / Drifting | 61 | 10-01-2015 08:44 PM |
| I drive fast because the car feel "slow" | fang_gt86 | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 05-04-2015 02:06 PM |
| Most effective ways to make a "fast" NA car | Kronos | Engine, Exhaust, Transmission | 68 | 02-16-2014 02:59 PM |
| XSXV: Nissan R34 Skyline from "Fast and Furious" | goat_cheese | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 10-25-2012 05:15 PM |
| come and hoon they say.... it will be "like Fast and the Furious", they say... | davey90 | AUSTRALIA | 5 | 10-23-2012 01:11 AM |
