Old 05-09-2017, 01:08 AM   #1
Lysdexia
Drives: Subaru Forester :-(
Thinking about buying a used FR-S (or BRZ)
I'm planning on buying an FR-S or BRZ. My plan is to get the car, spend some time learning how it drives, and then to spend some more time (and money) modding it to be a capable occasional track car (suspension, breaks, wheels, tires). Ultimately, I plan to do an LS swap.
My question is this: Given this plan, should I be concerned with buying an older (say 2013) model that has mileage around 60K? It seems that I can pick up a car with about 30K miles for approximately $17k, and one with about 60K for approximately $14k.
Obviously the extra $3k I save would go nicely towards some modifications. But am I making a mistake buy trying to save $3k on a car that I will ultimately spend a lot more money on (for the LS swap)?
Any feedback or thoughts are greatly appreciated!
Thanks
Lysdexia is offline   Reply With Quote
Old 05-09-2017, 01:35 AM   #2
Thanks
Hello Lysdexia and welcome to the forum .......
I don't think the mileage matters as much as how the car was cared for.
I'd suggest you pick one that hasn't been messed with and has the transmission you prefer and the color you like.
You may find that with some good tires and a modified exhaust, that the car is enough fun and you won't need an engine swap.
Old 05-09-2017, 01:50 AM   #3
Lysdexia
Thanks, that's good advice, and the welcome! I've been lurking for a couple of years, and finally had something to write about.
I definitely want to go with a manual transmission, as that's what I've driven most of my life. I also want to get a bone stock car. That's also a good call out about how it has been cared for mattering a lot.
On the engine swap - you may well be right that once I get the right tires on I might not actually want to change it. I used to drive a Honda CRX some years back, and that was absolutely insanely fun. One of the reasons I want one of the twins is because I see them as the only current equivalent of the CRX (yes, yes, I know they're quite different).
But that said, the idea of an LS in a twin is just too rad! But time will tell!
The Following User Says Thank You to Lysdexia For This Useful Post:
humfrz (05-09-2017)
Old 05-09-2017, 02:49 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Agree completely with the above. 60k miles is nothing for a modern car if it was cared for properly. Though keep in mind that's when the spark plugs are due for replacement as I recall. And that's a PITA.
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (05-09-2017)
Old 05-09-2017, 07:55 AM   #5
Riftur
Riftur's Avatar
If I was positive I was going to do a swap on the car I would buy the one with the best body and interior. Since you need to change everything else under the hood for the swap to happen. If you still aren't sure then you buy a stock one that has been cared for the best. You can usually made a pretty good educated guess when you look at oil change intervals and how many times its been in the shop for certain issues.
Riftur is offline   Reply With Quote
Old 05-09-2017, 11:20 AM   #6
stevesnj
stevesnj's Avatar
I think the 13 has the most issues engine wise than the other years looking at the maintenance forum, maybe a 14+ would be better piece of mind.
My 2016 Build thread
Old 05-09-2017, 04:06 PM   #7
Lysdexia
Thanks for all the responses, folks. I'll keep this all in mind when I finally make a decision.
Hopefully I can pull the trigger on something in the next month or so!
Old 05-09-2017, 10:51 PM   #8
Ah ....... springtime driving a twin .......
Before you decide to swap engines, I suggest you take a trip around this loop ..... and see how many other vehicles can keep up with you.
http://cascadeloop.com/
A mustang type car may pass you on a straight stretch ... but, at the end of the day, I'll betcha you pull into the motel first ...
Old 05-10-2017, 03:53 PM   #9
Lysdexia
Thanks for the pointer! I'm relatively new to Washington (well, almost 3 years in), and haven't had a real drivers car, so I am definitely excited to find some great roads, too.
humfrz (05-10-2017)
Old 05-10-2017, 10:17 PM   #10
If you make that loop and stop for the night in Leavenworth, make sure you have reservations ...... that whole place fills up fast.
Also, I recommend you stop in Winthrop, which is a neat little cow town.
Old 05-10-2017, 11:36 PM   #11
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Ooooh yes! That looks just like the routes I like to take here in Norway.
After 4 years of ownership I will not do anything to upset the weight distribution of my car. The center of gravity is exactly where I like it.
The Following 2 Users Say Thank You to Sarlacc For This Useful Post:
humfrz (05-11-2017), Tcoat (05-11-2017)
Old 05-11-2017, 01:46 PM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
My '13 FR-S passed 57k yesterday. Still running quite sweetly.
No warranty issues nor broken shizz.
Took a midweek drive in the nice weather.
SEATAC area to Lewiston ID on Tues. then WA129 south on the Rattlesnake Grade
to Enterprise OR. and back home last night.
I got pictures. Will put up a new drive report in a bit.
Didn't crash.
The Following 4 Users Say Thank You to bcj For This Useful Post:
Brayden_23 (05-12-2017), Sarlacc (05-11-2017), soulreapersteve (05-15-2017), Tcoat (05-11-2017)
Old 05-11-2017, 11:32 PM   #13
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
any teething issues with the early twins should be noticeable during most test drives...but who cares if ultimately you want to do an engine swap anyways..i say go for the cheapest one, beat the shit out of it till it blows then racecar
HKz is offline   Reply With Quote
Old 05-12-2017, 09:46 AM   #14
D_Thissen
D_Thissen's Avatar
If you're going to LS swap it, get the cheaper car. If you want to mod the FA20 I would go for the one who has less km, or was a later 2013 car. I think most of the issues were in cars produced in late 2012 and the first half of 2013. If you can find one with a production date of say July 2013 or later, you should be okay.
Thinking of buying a BRZ, need help! AutoNewb BRZ First-Gen (2012+) — General Topics 42 09-27-2016 07:22 PM
Thinking about buying this Fastbrz Cosmetic Modification (Interior/Exterior/Lighting) 22 03-02-2015 06:05 PM
How about a innovate thread for those who are thinking of buying one regal Forced Induction 46 03-20-2014 01:26 PM
How are the p&l equal headers thinking about buying them Anthony7515 Engine, Exhaust, Transmission 1 11-30-2013 12:23 PM
Thinking about buying a red car for V-Day? Look what made the list. Saab2Frs Scion FR-S / Toyota 86 GT86 General Forum 3 02-14-2013 06:51 PM
