#575 | |
Drives: FT86
Don't worry about rescaling pi/di unless you have changed injectors You will often get a bump around 3v as that's the cl to ol transition. just manually smooth that area. Then recheck the ol fueling |
#576 |
The Dictater
Drives: '13 Red Scion FRS
Thanks steve99. Mind taking a look at what I have right now?
Below are the adjustments the application wants me to make from open loop logs. This is after I've re-scaled and smoothed in open loop and closed loop. The current MAF in the 3-3.5 region already shows a bit of a dip in the graph (hard to see in the picture). Also attached the %difference of my current scale (From Kodename47's tool). Any thoughts or recommendations? It looks weird to me that it is so bumpy, but it could just be resonance, etc. Im thinking I might use one of the smoothed outputs from Kodenames tool and leave it at that. |
#577 |
Drives: FT86
Yes definitly smooth out the lumpy bits
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (04-29-2017) |
#578 |
![]() ![]() I can't seem to figure out how to get the trims needed for data logging Sent from my iPhone using Tapatalk |
#579 |
Drives: FT86
Try updating oft to pick up new template file, if that doesnt work manually update template file from here
http://www.ft86club.com/forums/showp...79&postcount=2 |
#580 | |
Updating happens when you open up openflash manager with oft plugged in right? Sent from my iPhone using Tapatalk |
#581 |
MAF Scaling - Open/Closed Loop Fueling info
Nevermind just did it manually thank u!!
Edit @steve99 it still displays nothing even after manual update. Sent from my iPhone using Tapatalk |
#582 | |
Drives: FT86
Is it just that screen of parameters ? What avout other screens of parameters What shows up in the log files ? Looks like you need to talk to oft guys |
#583 |
#584 |
Drives: FT86
#585 | |
Wouldn't I know which data is which by just getting the names from a picture that has the names for those tables? The pids still fluctuate and give a reading Sent from my iPhone using Tapatalk |
#586 |
Drives: FT86
#587 | |
GT86 Customized 8.zip |
#588 |
![]() ![]() ![]() What else should I select? This could help those who have the oft ![]() Sent from my iPhone using Tapatalk |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
