Old 04-27-2017, 12:27 PM   #1
stevesnj
stevesnj's Avatar
Do I need to have my track tires balanced?
I just bought a set of NT01's and I'm also new to the circuit trackworld. So do I need to have track only tires balanced?
My 2016 Build thread
Old 04-27-2017, 12:29 PM   #2
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Absolutely. Usually who ever installs your tires on the rims, will balance them for you.
Sent from my SM-N915T using Tapatalk
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
The Following User Says Thank You to FRSToyota86 For This Useful Post:
stevesnj (04-27-2017)
Old 04-27-2017, 12:30 PM   #3
stevesnj
stevesnj's Avatar
Thanks, what about bead sealer? I am using the OEM wheels.
Old 04-27-2017, 12:45 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've never even heard of that. You've got decent tires going on stout wheels, you should be fine as long as the shop does a decent job, they should be able to just treat them like normal tires.
ineedyourdiddly
Old 04-27-2017, 12:53 PM   #5
stevesnj
stevesnj's Avatar
It's mostly used on tubeless tires and in the 4x4 rock crawling world i'm in. Prevents bead separation due to extreme use.
Old 04-27-2017, 01:10 PM   #6
jasonojordan
Drives: 2013 satin white brz limited
If you end up in a situation where you are able to separate a tire from the bead you likely have bigger issues. IE you left the track at a high rate of speed.
jasonojordan is offline   Reply With Quote
The Following 3 Users Say Thank You to jasonojordan For This Useful Post:
15limited (04-27-2017), JoeC (05-16-2017), stevesnj (04-27-2017)
Old 04-27-2017, 01:13 PM   #7
M0nk3y
I don't balance my tires for autox and haven't when I've been to the track in the past.
Couple sessions and your balance will be off on the tire anyways. Unless you like extra weight on the wheel and want to spend more money balancing the tires I don't see the point
Old 04-27-2017, 01:13 PM   #8
stevesnj
stevesnj's Avatar
Haha, definitely not a plan to do so.
Old 04-27-2017, 01:14 PM   #9
stevesnj
stevesnj's Avatar
Well I don't do AutoX just circuits with one straight that's 120 mph plus
Old 04-27-2017, 01:16 PM   #10
M0nk3y
I've been on Mid-O in my former Z4M going 135+ on the back straight on non-balanced tires.
Track tires, like the ones you're getting will wear unevenly. Unless you believe that a stock tire off of the balancer is going to maintain that SAME balance throughout the life of the tire, then go ahead and keep on assuming that.
The Following User Says Thank You to M0nk3y For This Useful Post:
Old 04-27-2017, 01:17 PM   #11
stevesnj
stevesnj's Avatar
I like lots of data and try not to assume, thanks for the info
Old 04-27-2017, 01:18 PM   #12
M0nk3y
I like lots of data and try not to assum, thanks
lol. Okay.
I don't know anything then.
Enjoy your balanced tires and bead sealer then. Stupid for me to comment on a thread you clearly already know the answer to.
Old 04-27-2017, 01:20 PM   #13
jasonojordan
lol. Okay.
Troll? He thanked you for your input. He simply asked the question to see if it was a thing based off previous experiences he has had. Did I miss something here?
The Following User Says Thank You to jasonojordan For This Useful Post:
Old 04-27-2017, 01:20 PM   #14
stevesnj
stevesnj's Avatar
lol. Okay.
You took that totally the wrong way. I posted the thread because I wanted opinion through data and experience. Maybe it will help someone out too. Jeeze
Are my wheels improperly balanced? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-11-2016 03:54 PM
Engine swap that will improve the car in a balanced way? DVNARC Scion FR-S / Toyota 86 GT86 General Forum 2 09-04-2015 02:01 AM
Brand New FRS/BRZ Tires and Rims (mounted, balanced) Hamza7 Canada Classifieds 1 05-16-2015 02:12 PM
perfect balanced wheels BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-06-2014 12:27 PM
Got Corner Balanced and Aligned track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-10-2012 01:35 PM
