Old 04-21-2017, 12:56 PM   #15
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
No, it's good for launching in reverse.
#fwdstatus
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-21-2017, 12:59 PM   #16
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
I was running a slight chassis rake for a bit, mostly for the aero benefits listed above, and the slight aesthetic benefits 😉. Got rid of it though, cause it was causing the front of the car to be just low enough that I was scrapping more then I liked coming in and out of some driveways. Car isn't crazy lowered either, maybe a hair over 1" from stock.
Oh and I'm running a square tire setup.
D18 is offline   Reply With Quote
Old 04-21-2017, 02:33 PM   #17
Racecomp Engineering
Rake can also be used to alter suspension geometry in a way to reduce understeer. That can be a benefit if done right. It should still be kept fairly subtle though.
I don't recommend different size tires front vs rear for most people.
- Andrew
Old 04-21-2017, 02:41 PM   #18
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
- Andrew
As a follow up, if you were to prepare a car that had some rake, (say a spirited DD or something,) how much of a differential in height would you use? a couple mm at most I'd imagine, (3 or so?)
JazzleSAURUS is offline   Reply With Quote
Old 04-21-2017, 02:51 PM   #19
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
If we're keeping it theoretical, the roll axes on the Lotus Elise were set up such that having a positive rake of 5mm [front 5mm lower than rear] gave the best overall balance; roll center axis and aerodynamic effect with its flat floor.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-21-2017, 03:10 PM   #20
Looks like a little rake on these:
As long as you don't go nuts it should look OK.
Mind you I come from a generation that did this to our street cars:
Old 04-21-2017, 03:13 PM   #21
JazzleSAURUS
That's about the difference I have on my Forester XT, it helped keep things from touching on launch at autox and kept the rear gripping and the COG down.
Old 04-21-2017, 03:15 PM   #22
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
That sounds like it'd be REALLY bumpy...
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-21-2017, 03:34 PM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's an old pic of mine:
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-21-2017, 04:26 PM   #24
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I think that top picture is along the lines I'm looking for, with the height of the release series below. Not looking to go much lower than stock.
DaBoBo21 is offline   Reply With Quote
Old 04-21-2017, 04:28 PM   #25
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
This is almost exactly what I'm going for stance wise. It's subtle.
Old 04-21-2017, 06:31 PM   #26
Gunman
Drives: 2019 Mazda Miata RF
Come on....go gasser style
Old 04-21-2017, 06:50 PM   #27
Gent
Gent's Avatar
Drives: 2017 Toyota 86
I have a bit in mine. Not a tonne.
Gent is offline   Reply With Quote
Old 04-21-2017, 07:33 PM   #28
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
It looks good!
Best Steering Wheel Column for Feel - Rake and Reach brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-21-2015 09:24 PM
Lowered, but want thoughts on rake. DrDuquette Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-31-2014 10:49 PM
Rake TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-03-2013 10:24 AM
