Old 04-17-2017, 02:23 PM   #5895
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
The Following 2 Users Say Thank You to wireman957 For This Useful Post:
Dadhawk (04-17-2017), p1l0t (04-17-2017)
Old 04-17-2017, 02:32 PM   #5896
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
5024 With C130
SG02WRX is offline   Reply With Quote
The Following 2 Users Say Thank You to SG02WRX For This Useful Post:
Old 04-17-2017, 03:15 PM   #5897
JD001
JD001's Avatar
Drives: Subaru BRZ
...no idea what it contains ...
Old 04-17-2017, 03:26 PM   #5898
Dehydrated Swiss Fighter, just add jet fuel?
actually...
Originally Posted by hsh-rail.com
WATER RINSABLE, NON CRAZING STRONG CLEANER
The INTERCOACH 5025 is our strongest soap/cleaner. It can be applied on many different substrates.
It is water rinsable, non-crazing for use inside passenger cars.
It was developed to remove graffiti from plastics, metals and painted substrates. Also can be used as a general purpose cleaner.
For degreasing or removal of persistent dirt or stains you can use IC5025 not diluted. For cleaning of painted surfaces, a 50-50 mix with water will give good results.
IC5025 may be diluted up to 10 times its volume with water.
IC5025 is a high performance cleaner and will in most cases replace hazardous aromatic hydrocarbon or trichloroethylene cleaners.
Packaging in 5L and 25L cans.
JD001 (04-17-2017), wireman957 (04-17-2017)
Old 04-17-2017, 03:28 PM   #5899
p1l0t (04-17-2017)
Old 04-18-2017, 03:36 PM   #5900
wireman957
wireman957's Avatar
The Following User Says Thank You to wireman957 For This Useful Post:
Dadhawk (04-18-2017)
Old 04-18-2017, 03:41 PM   #5901
First saw this I thought it had "baby toy" written on it!
Old 04-18-2017, 03:54 PM   #5902
wireman957 (04-18-2017)
Old 04-22-2017, 08:59 AM   #5903
roddy
roddy's Avatar
Drives: '13 Ultramarine
Old 04-22-2017, 09:10 AM   #5904
Boomerang
86
Boomerang's Avatar
Old 04-24-2017, 11:50 AM   #5905
wireman957
wireman957's Avatar
Old 04-24-2017, 12:50 PM   #5906
SG02WRX
SG02WRX's Avatar
Turbo Powa!
Old 04-24-2017, 01:04 PM   #5907
Old 04-24-2017, 04:29 PM   #5908
I've had days like this...
Tcoat (04-24-2017)
