Old 04-14-2017, 08:13 PM   #1
Kiwman
Drives: Scion FRS
Clank coming onto driveway
Alright guys, its about time I post a thread. Unfortunately it is because I feel I need some help from someone who knows these cars before I go to a mechanic.
Just coming home from work I roll onto my driveway, but as I get over the hump I hear a loud CLANK. Thinking this might be a one time thing I reversed and re-entered my driveway, CLANK. Did a quick lap around the street, no noises when driving, just a clank when i get over the hump of my driveway. Also I guess I should mention I enter my driveway on an angle.
I vaguely remember seeing a post with another member having a similar issue but I can't seem to find it. I'll continue looking for it after I post this but if not I'm wondering what could be making that sound and if I should not drive the car until I get it sorted out (currently do not have pics of anything, can get some if requested). All help is appreciated.
EDIT: I should note it was coming from the front left side.
Kiwman is offline   Reply With Quote
Old 04-14-2017, 08:20 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Are you on aftermarket LCA's?
VIP BRZ is offline   Reply With Quote
Old 04-14-2017, 08:22 PM   #3
cat94
Drives: '17 86
I have to awkwardly drive small hill at an angle in my parking lot. I once heard a loud "clank" doing so. It definitely did not feel like I hit the ground, and to this day I have no idea what caused it.
cat94 is offline   Reply With Quote
Old 04-14-2017, 08:27 PM   #4
Kiwman
Drives: Scion FRS
No, my suspension is all stock.
@cat94 Has the noise ever repeated itself? or just the one time?
Old 04-14-2017, 08:33 PM   #5
cat94
Drives: '17 86
Only once. I made sure that I didn't run over any cans or anything too. It almost sounded like something under tension suddenly uncompressed and hit something?? I don't think I'll be able to help much in diagnosing your issue =/
Old 04-15-2017, 02:47 AM   #6
It could be a lose rear axle nut, if so, tighten it.
It could be a rear axle universal going bad, inspect it to see if its leaking around the boot.
That's all the guesses I have now.
Old 04-15-2017, 03:02 AM   #7
Bach415
Bach415's Avatar
Drives: Whiteout FRS
You might want to make a video of it so we can get a better description. I'm guessing you are angling the car to make a left into your drive way? If so then depending on your angle of attack, it might have just decompress the rear left suspension fast enough to make a noise. Try entering your driveway the other way (I.E entering as a right turn rather than left, vice versa) and see if the noise occurs on the other side.
Bach415 is offline   Reply With Quote
Old 04-15-2017, 11:19 AM   #8
Kiwman
Drives: Scion FRS
Thank you for your replies! I had to leave for work early today so I will put my mechanic hat on right when I get home.
@Bach415 Yes I angle to get onto my driveway. Ill try to get a video of the sound/scenario of the clank when I get home and post it.
No sound when I was reversing out of my driveway, or any different sounds while driving, so I guess that's good.
Old 04-15-2017, 10:32 PM   #9
Kiwman
Drives: Scion FRS
Alright! Finally able to update a little. So after jacking the front up and removing the tires I noticed this.
(This one is front left)
This is in comparison with the other side(ultra lens flare, I did not notice before I put the wheels back on)
(This one is front right)
Everything else on each side looked relatively similar, the ball joints look drastically different. I'm a bit nervous to take it on the road after this little inspection.
Old 04-15-2017, 11:51 PM   #10
Sorry, I have no idea of what I'm looking at ..... ??
Old 04-15-2017, 11:58 PM   #11
Bach415
Bach415's Avatar
Looks like the tie rod bushings in the front.
The Following User Says Thank You to Bach415 For This Useful Post:
humfrz (04-16-2017)
Old 04-16-2017, 01:22 AM   #12
Kiwman
Drives: Scion FRS
My apologies.
Front left
Front right
Close ups of the ball joint, nothing else seemed out of place.
Old 04-16-2017, 02:00 AM   #13
If you can't feel any excessive play in the ball joint, I'd suggest you look elsewhere.
Are you sure the sound is coming from the front ......and not the back .. ??
I have to enter my driveway at an angle also ...... and I don't hear any clank, so, I reckon that sound isn't "normal".
However, if I don't hit the driveway at exactly a 45 degree angle, I do get a sickening "crunch" sound ...... as the exhaust mid pipe scrapes .....
I'd suggest you have someone stand outside the car, while you enter the driveway, while your car is making that clank sound, and see if they can help isolate where the sound is coming from.
Old 04-16-2017, 11:15 AM   #14
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
My apologies.
Front left
Attachment 152269
Front right
Attachment 152270
Not saying this is the problem, but your right side is missing the cotter pin on the castle nut, it must have been taken apart before. Could it be that this car may have had a problem previous of your purchase and it may have came back? Maybe it wasn't repaired completely/properly?
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Clunk/ Clank on Engagement with 2nd and 3rd DaBoBo21 Issues | Warranty | Recalls / TSB 49 03-23-2017 03:14 PM
Loud clank when taking off in first Da Brz Issues | Warranty | Recalls / TSB 10 03-15-2017 10:35 PM
Automatic Transmission: Loud Clank Moshpit37 Engine, Exhaust, Transmission 5 05-23-2015 08:21 PM
Clank from suspension/give in steering wheel over bump Shady195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-09-2014 09:15 AM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-05-2014 12:26 AM
