#15 | ||
Drives: brz
And yeah, shorter final drives concentrate torque to the first portion (the first half, if my maths are right) of a gear's travel through the RPM band. After that portion is run, it'll slouch off speed-wise, in comparison to longer final drives. It sounds like a decent compromise, for what I'm trying to achieve. Quote:
#16 |
Drives: 2014 GT86
In his descibed case it looked not so much if 'can handle the load', but if 'have enough grip', no? IIRC clutch type diffs can improve traction on track above that of torsen's. Of course in return for more maintenance/noise.
| The Following User Says Thank You to churchx For This Useful Post: | botbs (01-11-2022) |
#17 | |
Drives: '23 BRZ
You don't have more options to choose gears in corner. Actually, fewer... OP, if you want to know the effect of changing to 5.1 gears at just about any speed, just drop down a transmission gear. If you can't, then know that at that speed you'd most likely have to be in a higher transmission gear with 5.1. I'll say it again, if it's not 0-XX acceleration you're interested in, but just want more oomph in general that you think diff gears will get you, just wind out the engine more and delay upshifting with stock diff and get the same effect for free. Last edited by ZDan; 04-13-2017 at 05:58 AM. |
#18 | |
Drives: 2014 Toyota GT86
In my case , the FD itself is loud and the CF shaft make aircraft noise after 140km , the lsd itself have no change in noise , I can only hear very little bit chatter noise if I turn my steering wheel full lock and accelerate together . I had a cusco rs lsd in S2000 , it last too long and I sold the car with it , over 30K+ mix with daily , autoX and track duty . |
| The Following User Says Thank You to kingkenny For This Useful Post: | jcw99 (06-02-2019) |
#19 |
Here is two of my record video ,
[ame="http://youtu.be/tnrY4rrxaRE"]http://youtu.be/tnrY4rrxaRE[/ame] The sudden loss of grip was cause by the lsd act up weird over bump and in wheel lift . [ame="http://youtu.be/7qPlyFXZotk"]http://youtu.be/7qPlyFXZotk[/ame] It was 5.1 FD , OEM diff. , Tein SRC with Super Pro sway bar front and rear , Tomei EL & over pipe + nameless muffled track pipe , 235/40R17 NT01 . Just for you to get a idea . I drive the car around if it is the day i work alone , i don't see any issue . Last edited by kingkenny; 04-13-2017 at 08:32 AM. |
#20 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I suppose you could achieve the same effect by revving the engine mid shift - but that is not something I want to do on a regular basis. |
#21 |
Drives: GT86 Harrop S/C
Has anyone used increasing the whee size to slightly lower the final drive?
#22 |
Drives: 2015 Scion FRS - Raven
#23 |
#24 |
The diff makes a lot of noise when it's cold under low speed and tight turns. More so when releasing. I've only had the diff on the car for about 2000km. It's mostly just for track use and driving to and from the track. Overall I wouldn't go back to a helical LSD for tracking. I also have the Whiteline diff and subframe bushings so the noise is transmitted to the chassis more so then without them.
| The Following User Says Thank You to TRAKRAVN For This Useful Post: | jcw99 (06-02-2019) |
#25 | |
I guess these may have to do with the lsd configuration , mine cusco is set to 1.5 way , minimum intial torque and lock , with motul 75W140 . More lock up = more noise ? Those solid diff. & frame mount and diff. brace both make noise , with or without the FD or LSD , i have them and i like it very much , the noise just make the drive more exciting . That me only , other may hate it ... Back to kbraun94 question , the car feel pull harder , more torque , more shifting , it is more fun for me but can't argue if it is actual faster . |
| The Following User Says Thank You to kingkenny For This Useful Post: | jcw99 (05-23-2019) |
#26 | |
I completely agree, the car "feels" like it pulls harder, more shifting, more fun but I don't think the car is actually faster on the street. On the track it does make a difference though as you can hold different gears for different corners now but that's track dependent. |
#27 |
Drives: 2019 MX-5 RF
Smash the 4.3 and hit past 4.55.
if you cant floor it in 6th gear and get pressure, your FD is not too low. 4.3 fixes it and makes it able to daily drive and go on long trips still. Racing? rip that mofo. Crank it up. It cannot hurt with a 7400 RPM redline engine right? |
#28 |
Platinum Member
Drives: 86
Currently have a jrsc w/ hbp on 6AT frs. I'm thinking about going Cusco 5.1 FD w/ Cusco RS 1.5 way. Hopefully this setup will help me get off the lines faster and quicker corner exit speeds.
| Tags |
| brz, fdr, final drive |
| How-To: Change final drive ratio (relatively) cheaply | PantsDants | Engine, Exhaust, Transmission | 84 | 03-22-2020 04:58 PM |
| MFactory Final Drives & Close Ratio Gears | YCW | Transmission and Driveline | 0 | 09-29-2016 01:28 AM |
| 4.556 final drive with TRD gear ratio change - good or bad idea? | nzer | Engine, Exhaust, Transmission | 51 | 12-26-2015 10:15 PM |
| taller final drive ratio | SuperDave | Engine, Exhaust, Transmission | 17 | 10-26-2014 04:37 PM |
| About track cars' final drive ratio | immo | Tracking / Autocross / HPDE / Drifting | 4 | 09-23-2014 10:04 AM |
